Question about Archos 605 WiFi Digital Media Player
Message appears saying buttons temporarily disabled
Every time i connect my605 is to my laptop this message allways appears .what does this mean and how do enable the said buttons
  • 3 Answers
It just means that you can't use the device while it's connected to the computer. The buttons are enabled again when you disconnect the device.
Posted on Feb 10, 2009
Receive message "Folder in your mailbox have name conflict". Not sure what that means nor how to correct. Do not understand instructions.
What mail client you have is saying that there is more than one folder like "inbox" etc that have the same name.
Apr 21, 2017 | Computers & Internet
My ipod touch 4th generation says -ipod is disabled connect to itunes- tried that and itunes wouldnt open unless unlocked my ipod and i cant. I tried restoring it and itunes said ipod can not be restored...
"iPod is disabled - Connect to iTunes" . This is because someone(or something?) has tried to crack your password too many times, which causes Iphone/Ipod to automatically disable itself to protect your data.
To restore your iPod, you must connect your iPod to iTunes with your iPod connector table. Make sure it is on and has this message when you connect it to your computer. Once connected, iTunes should detect it as usual.
Once connected, make sure you have all the proper sync settings enabled - for example, applications, music, photos, etc. Change something so that the Sync button in the bottom right appears in the iTunes window. Then sync the data.
When syncing is finished, turn on your iPod / iPhone and you should notice that the message is gone. Type in your password and the disabled message should be gone.
If the message is still there, try holding the sleep and home button at the same time until the iPod turns off, then continue holding the sleep and home button until a screen with the iTunes logo and a picture of the connector cable appears. This will put your iPod in Restore mode. With this option, you must click the Restore button in iTunes, which will delete all your data on the iPod.
Jan 13, 2011 | Apple iPod touch
My mouse causes me to have to gets in the retype all the time cause it goes back up in my sentence or highlights my words blue
This is a very common issue with mouse pads build into laptops computer and can be avoid by moving your hands away from the mouse pad (meaning to open more) during the typing process. You might also want to try to disable temporarily the mouse pad by pressing the mouse button sometimes located on top of your mouse cell or pad or, by pressing FN key along with "F's" key(from F2 to F12). There should be a pad with a hand meaning to either disabling or enabling your mouse pointer.
Finally, try to use and external mouse.
Good Luck!!
Jan 11, 2011 | Computers & Internet
A message keeps coming up on my Dell laptop saying the AC power adaptor cannot be determined, this will prevent optimal system performance...what does it mean and what can I do?? Nipper
Dell portable systems use a sensor wire (Thin wire in center of power connector of AC adapter) to allow the system to identify the wattage of the adapter connected to the system. If the wire is bent or broken, then that message will appear and the battery charger is disabled.
If the issue still occurs with a replacement or known good Dell AC adapter, replace the motherboard.
Oct 18, 2009 | Dell Computers & Internet
8GB iPod Touch Disabled
you will have to restore your ipod to factory default settings in itunes.
or you can jailbreak the ipod with software like quickpwn.
Here is how to restore your ipod in itunes.
You will need to put the itouch in DFU/Recovery mode to get it to connect.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Plug the usb cable into the Ipod and NOT into the computer.
Hold the Home Button down for 5 second (do not release it)
Then Press and hold the Power Button for approx 10 secs (count them out)
Your iPod will reboot.
Release the power button and continue holding the Home button for an additional 27secs.
You may see the screen go blank or not.
Plug the USB end into the computer with itunes open.
Your ipod will mount in recovery mode.
Restore it and Your all set.
if you need any further help let me know.
Good Luck
Jun 01, 2009 | Apple iPod touch
I dont know what to do please help me my ipod touch is disabled.
press and hold the home and power buttons, when it turns off DO NOT let go of the home button continue holding until it restores itself then connect it to your computer and restore it. unfortunately it will erase everything.
Feb 02, 2009 | Apple iPod touch
ARCHOS 405
The buttons are ALWAYS disabled when you connect it to the PC in "mass storage/hard drive" mode. This doesn´´t mean malfunction.
Sep 14, 2008 | Archos 405 Digital Media Player
Laptop only works with mains power supply connected
When you power your system up do you get a message saying battery charge failure or some other disappointing driver message? Try powering down, removing the battery, and look for a little button on the underneath of the battery. You should be able to press this button and a series of lights will or won't appear. If they light up it means the battery is truly charged. If not there is something wrong with the connection. Try wiping the surface off and replacing the battery. Also make sure the pin that you place into the laptop to charge the battery is free of dust, etc.
Aug 30, 2008 | Compaq Armada M700 Notebook
Toshiba flash cards not working ??
It means what it says. There have been mentioned problems of this. You can disable the flash cards (>Start Menu-->All >Programs-->Toshiba-->Utilities-->Settings for >Flash Cards-->Disable Flash Cards) but you then apparently lose the function keys (therefor cannot change the brightness.) First off though you should perhaps state the model of your laptop. If it is the Toshiba A10/700 then I believe there is a Value Added Pack for download on the Toshiba's Canadian website - but has problems. I have also heard of programs causing such problems, such as Photoshop CS2. Is this message appearing after hibernate? If so what programs do you leave running?
Jun 15, 2008 | Toshiba Satellite A135-S4527 Notebook
Archos 605 WiFi Digital Media Player Logo
63 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
