Question about Sharp AL 1631 Copier
Replaced the drum - light won't go out, not accepting new drum
1. Replaced the drum, made sure the old one was discarded before putting in the new drum.
2. Not recognizing the new drum - just to costly to throw away.
HELP!!!!!!!!
  • 1,602 Answers
MORE THAN THE DRUM JUST NEED TO BE SERVICE, THE ROLLERS NEED ADJUSTMENTS, TOLERANCES NEED TO BE SET, PHOTO PRINT TEST SHEET AND ALINGMENT AND ADJUSTMENTS, CONNECTION TEST, CLEAN MACHINE OF FORIERNG MATTERAIL, OLD TONER REMOVED AND OVERFLOW TONER REMOVED AND THE CORONA WIRES NEED TO BE SERVICE SO THE ELCTRO STATIC WORK PROPERLY. AND SO ON , IF YOU DO IT YOURSELF AND YOU BRAKE IT IT MAY COST YOU MORE IN THE LONG RUN BUT THAT IS UP TO YOU
ROD GANDY THE CANDYMANGANDY
Posted on Feb 09, 2009
How do I reset drum error message
These machines need to have their drum units replaced every 12000 pages. If you have replaced it then it needs to have the machine reset. Normally the instructions are included in the box with the new drum unit but not many people read these.
  1. Open the front cover (Where you put the cartridge and drum unit in)
  2. Press the Back Button
  3. Display reads "Replace Drum 1. Yes 2. No"
  4. Press the number 1
  5. The display reads "Accepted"
  6. Close the Front Cover
If you have not replaced the drum unit and you reset the drum counter you will see a noticeable degradation of the printouts coming from the machine.
Oct 06, 2014 | Brother MFC-7420 Printer
How can I remove the drum from the printer?
Replace the drum unit.
Description:
Follow the procedure below to replace the drum unit.
The Brother machine has separate consumables the toner cartridge and the drum unit. Verify you replace only the drum unit and not the toner cartridge. If you want to know their difference, refer to "What is the difference between the toner cartridge and the drum unit?"
Caution Do NOT use flammable substances near the machine. Do NOT use any type of spray to clean the inside or outside of the machine. Doing this may cause a fire or electrical shock.
spray1.gif Caution
  • While removing the drum unit, handle it carefully because it may contain toner. If toner scatters on your hands or clothes, wipe or wash it off with cold water at once.
  • After you have just used the machine, some internal parts of the machine will be extremely hot. When you open the front or back cover (back output tray) of the machine, DO NOT touch the shaded parts shown in the illustration. If you do this, you may get burned.
  1. Open the front cover.
  1. Slowly take out the drum unit and toner cartridge assembly.
replacedrum_02.gif Caution
  • We recommend that you put the used drum unit and toner cartridge assembly on a clean, flat surface with a sheet of disposable paper or cloth underneath it in case you accidentally spill or scatter toner.
  • To prevent damage to the machine caused by static electricity, DO NOT touch the electrodes shown in the illustration.
  1. Push down the green lock lever and take the toner cartridge out of the drum unit.
Note Discard the used drum unit according to local regulations, keeping it separate from domestic waste. Be sure to seal up the used drum unit tightly in a suitable bag so that toner powder does not spill out of the unit. If you have questions, call your local waste disposal office.
Caution
  • Wait to unpack a new drum unit until immediately before you put it in the machine. Exposure to direct sunlight or room light may damage the drum unit.
  • To avoid print quality problems, DO NOT touch the shaded parts shown in the illustrations.
  1. Unpack the new drum unit.
  2. Put the toner cartridge firmly into the new drum unit you hear it lock into place. If you put the cartridge in properly, the green lock lever will lift automatically.
Caution Make sure that you put in the toner cartridge properly or it may separate from the drum unit.
  1. Clean the primary corona wire inside the drum unit by gently sliding the green tab from right to left and left to right several times.
Caution Be sure to return the green tab to the home position (1). If you do not, printed pages may have a vertical stripe.
  1. Put the new drum unit and toner cartridge assembly in the machine.
  1. Press Clear/Back.
    For MFC users:
    To confirm you are installing a new drum, press 1.
    For DCP users:
    To confirm you are installing a new drum, press the Up Arrow key.
  2. When the LCD shows Accepted, close the front cover.
Jan 09, 2012 | Brother MFC 7840W Printer
Intellifax 2800 does not register new drum. I put in new drum and it is extremely light copies and is stll telling me to replace drum soon
If you replaced the drum with a new one, then a special plastic piece with slots in it will be ejected. This will reset the "Replace Drum" message. Now the light print is probably due to the toner needing replacing. When you put in a new drum, it needs new toner too. Unfortunately, most people replace the toner into the old drum, which does no good and becomes wasted. NEW DRUM NEW TONER. Now if you have replaced the old drum with another old drum, you won't get the reset done properly and the new drum won't load any toner either. Perhaps you accidentally removed the plastic sheet when you replaced the drum? Well then, find the piece and run it through the paper feed, it will then reset. Best of luck
Oct 06, 2010 | Brother IntelliFAX 2800 Laser Fax
Faded printing down center of page
You may need to change your drum unit. The replacement part number is DR400
To replace the drum unit follow the instructions listed below:
Caution
    Do NOT use flammable substances or any type of spray to clean the inside or outside of the machine. Doing this may cause a fire or electrical shock.
spray.gif Caution
    Just after you have used the FAX/MFC, some internal parts of the machine are extremely HOT! When you open the top cover of the FAX/MFC, never touch the shaded parts as shown in the diagram below:
  2. Remove the old drum unit. Place the drum unit on a drop cloth or large piece of disposable paper to avoid spilling and scattering the toner.
  1. Remove the toner cartridge by holding down the lock lever on the right and pull the toner cartridge out of the drum unit assembly.
  1. Wait to unpack the new drum unit until immediately before installing it. Place the old drum unit into the aluminium bag.
  2. Reinstall the toner cartridge into the new drum unit.
  3. Reinstall the new drum unit, keeping the front cover open.
  4. Press the Clear key to display drum status.
  5. Press 1 on the telephone keypad.
  1. When the display shows "ACCEPTED", close the front cover.
Note
    Discard it according to local regulations. If you are not sure of them, call your local Sanitation Department. Be sure to seal the drum unit tightly so toner powder does not spill out of the unit. When discarding used drum units, keep them separate from domestic garbage.
Jun 18, 2010 | Brother IntelliFAX 4100 Laser Fax
Hi! the drum light on my Brother HL-2170 laser
1. Open Cover.
2. Press the Clear key to display drum status.
3. Press 1 (hold) on the telephone keypad.
4. When the display shows "ACCEPTED", close the front cover.
PRESTO!
Oct 19, 2009 | Brother HL-2170W Laser Printer
Ink cartridge full but won´t print
This might need to be reset.
Here' how...just follow the instructions..
moz-screenshot.pngThere's two ways to reset it
First: Soft Reset
1. Open front cover.
2. Hold down button located under LED's until all LED's are lit.
3. Release button and make sure drum LED is off, then
4. Close cover
Second: Factory Reset
1. Turn the printer off.
2. Hold in the circular button on the front panel of the printer.
3. Turn the printer back on.
4. When the DRUM light is lit by itself let go of the button.
5. Hold in the circular button on the front panel again.
6. Once the Alarm light comes on, let go of the button.
This will perform a factory reset on the printer.
I hope that's everything you want.
Please accept this answer if this will help you.
Thank you for using Fixya.
Oct 02, 2009 | Brother HL 1440 Laser Printer
Drum light on HL2030 won´t go off!
Open the front door, and press the go button until the lights flash, after closing, press the go button 3 times for a printout showing the drum as full again. The instructions come with the new drum...
Jul 30, 2009 | Brother HL-2030 Laser Printer
Replaced Drum still says "Replace Drum Soon". How do I reset on a Brother 7420?
Reinstall the new drum unit, keeping the front cover open. Press OPTIONS. Press 1 when the display shows REPLACE DRUM? 1.YES 2.NO ACCEPTED. Close the front cover.
May 28, 2009 | Brother MFC 7420 All-In-One Laser Printer
Replaced drum fax 2820
Hi, #'s 6, 7 and 8 below explain how to reset the drum indicator.
Hope that helps...
Lbcoaster
How do I replace the drum unit?
Description:
Follow the procedure below to replace drum unit.
CautionDo NOT use flammable substances or any type of spray to clean the inside or outside of the machine. Doing this may cause a fire or electrical shock.
spray1.gif Caution
    Just after you have used the machine, some internal parts of the machine are extremely HOT! Never touch the shaded parts shown in the illustration.
  1. Open the front cover and pull out the drum unit and toner cartridge assembly.
Caution
    To prevent damage to the printer from static electricity, do not touch the electrodes shown below.
  1. Hold down the lock lever on the left and pull the toner cartridge out of the drum unit.
Note
    • Discard the used drum unit according to local regulations, keeping it separate from domestic waste. Be sure to seal the drum unit tightly so toner powder does not spill out of the unit. If you have questions, call your local waste disposal office.
    • Wait to unpack the new drum unit until immediately before installing it. Place the old drum unit into the plastic bag.
  1. Reinstall the toner cartridge into the new drum unit. If you put it in properly, the lock lever will lift automatically.
all-ug-16.gif Caution
    To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
    If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
  1. Install the drum unit and toner cartridge assembly in the machine.
  1. Press Options.
  1. To confirm you are installing a new drum, press 1.
  1. When the LCD shows Accepted, close the front cover.
Related Models FAX-2820, FAX-2910, FAX-2920, MFC-7220, MFC-7225N
Aug 02, 2008 | Brother IntelliFax-2820 Laser Fax
Brother MFC-8840C
Centre of machine is not one door but two, the first is the maual bypass tray but you can open the whole front. Then you are where you can put toner and drum in/out. Once front is open just pull entire black insides of printer slightly up and towards you, whole unit now removed is drum and toner, unclick ((blue tabs) toner from drum unit ..fit it to new drum, reinsert it, before you close the door, turn on the machine and Clear, 1. Now close the door.
LInk if paste fails
Title:
Description: Follow the procedure below to replace drum unit.
Caution
spray1.gif Caution
    Just after you have used the MFC, some internal parts of the MFC are extremely HOT! So please be careful.
  1. Press the cover release button and then open the front cover.
  2. Remove the old drum unit and toner cartridge assembly. Place it on a drop cloth or disposable paper to avoid scattering toner.
    zl2mfc_037.gif Caution
  3. Hold down the lock lever on the right and pull the toner cartridge out of the drum unit
    zl2mfc_03964.gif Note
  4. Wait to unpack the new drum unit until immediately before installing it. Place the old drum unit into the plastic bag and discard it according to local regulations.
  5. Reinstall the toner cartridge into the new drum unit
    Caution
  6. Reinstall the new drum unit, keeping the front cover open.
  7. Press Clear/Back.
  8. Press 1 and when the LCD shows Accepted, and close the front cover
Dec 20, 2007 | Brother MFC-8840D All-In-One Laser Printer
Sharp AL 1631 Copier Logo
76 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
