Question about Sony Playstation 3 (PS3) Console
I turn on my ps3 but nothing appears on tv
At first when i turned it on, only the line on the back of the ps3 default would come up but nothing else. Now when i turn it on, nothing appears on the TV (and its not the TV.)
  • 89 Answers
Maybe u have the wrong cables hooked up if your tv does not have HDMI hook up then you are forced to use the cables that came with it. Make sure that they are correctly hooked up it should be color coded.
Posted on Feb 10, 2009
I turn the ps3 on but the video doesn't appear. i checked the tv and cords and nothing was wrong with them.
Did you check that the AV cords are plugged in right? Red to Red, White to White, Yellow to Yellow? Are they properly connected in the back of the PS3 not loose connections? It could also be that the PS3 display settings are at a really high resolution for your T.V. Try reset the PS3 resolution settings back to factory settings by turning the PS3 off and then hold down the power button for 3-5 seconds and you will hear some beeps it will load your PS3 resolution at 480i. Should give you your screen back.
Feb 27, 2011 | Sony Playstation 3 (PS3) Console
When i turn on my ps3 it displays a black screen with a fuzzy green line at the bottom. it beeps 3 times when i try to turn it of after and if held longer it will turn off. whats wrong with my ps3?
Note this will reset you user prefaces,
1- Turn the standby switch off so the red light turns off too, then you turn the system back on
2- Then place your finger on the power button for a total of 4 beeps to access the recovery menu. It might not work on the first attempt but it will on the second.
3- The display will instruct you to connect your controller to the PS3 and press the enter button. A list of menus will appear on your display. The choices are as follows: Restart System, Restore Default Settings, Restore File System, Rebuild data base, Restore PS3 system, System update
4- Select Restore Default Settings.
Nov 24, 2009 | Sony PlayStation® 3 (60 GB) Console
, i put the disc in and i hear it working, but it dosent start up, no icon appears on the menu. the menu turns on, but nothing else works please help, thanks.
1- Disconnect the PS3 from the internet.
2- Turn the standby switch off so the red light turns off too, then you turn the system back on
3- Then place your finger on the power button for a total of 4 beeps to access the recovery menu. It might not work on the first attempt but it will on the second.
4- The display will instruct you to connect your controller to the PS3 and press the enter button. A list of menus will appear on your display. The choices are as follows: Restart System, Restore Default Settings, Restore File System, Rebuild data base, Restore PS3
5- Select Restore Default Settings.
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
My sons ps3 is displaying he message: can not find the correct hard disc. it dose nothing else
Ps3 will not display start up or allow any game or more to display ont tv?
Try a video reset on the system, turn the system off so just the red light is on then hold your finger on the power button till you hear two beeps and it shuts. Then turn the system back on. If this does not work try.
My ps3 doest display anything nor makes any sounds please help
Just a gander, but your PS3 may be set for HD output thus not displaying on your non HD television, your best bet in this case is to find an HD television, friend, coworker, etc, connect to it and switch the settings back to regular. Also if I understand correctly leaving the ps3 completely unplugged for 72 hours may also reset all settings. Good luck!
Jul 03, 2009 | Sony Playstation 3 (PS3) Console
When i turn on my ps3 nothing appears on my television!!!
ok, put your ps3 in standby mode(solid red light) then hold the power button. Just keep holding it until the picture shows up, asking you if you want to set in to optimal video settings, in which you say yes. if it turns of before saying this, try again and again. if after a few tries it doesn't work, check the cables in the back of the system and tv to make sure they're plugged in fully. then check to make sure your tv is on the right video setting (video 1, 2, 3, digital output, etc.)
Jun 04, 2009 | Sony Playstation 3 (PS3) Console
Turn power on with a steady green light but nothing appears
Try it on another TV if nothing shows up then your PS3 or the video plug is broken.
Feb 21, 2009 | Sony Playstation 3 (PS3) Console
Pic
if you have a SD TV. ( standard display, not HD ) but chose the HD display option on system settings you wont see picture but hear sound. and same goes if you've chosen SD display but own a HD TV. so try to reset your system somehow or take it in for inspection.
Jul 13, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3
try using the composite cables as well.....with your tv set to the composite input go back into the settings and select the HDMI output switch your tv's input back to your HDMI input and remove the composite cables....it should work fine...
Jan 11, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
62 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
