Question about Sharp BDHP20U Blu-Ray Player
Door won't open
Just opened up my player and I can't even get the door to open and try to play a disk. it seems to make a funny noise and the two circle lights come on then it just shuts down. Thing has never been used. any ideas how to fix this problem
  • may jones Mar 27, 2009
    I tried this solution. Perhaps I didn't do it correctly. I removed the screws from the cover. I removed the 2 screws from the base and the 2 screws from off the inside side of the unit.I then removed the 2 screws from the outside side of the unit. I powered the player up. I Made several attempts to open the carriage with the remote and manually, to no avail.
    If you have any other ideas please email them to me at mjones200540@yahoo.com.
    Thank you very much, Mary Jones
    Novelist:
  • 140 Answers
Those kind of problems just require that the door open one time. However, to do that you will have to take the cover off the player with the power off of course. Once you have take the cover off ( only a few screws ) you will be able to see the disk player well enough to see the back part of it. There are two ways you can do this, first, is to power the player back on, press the power button on. Then when you press the open door button or use your remote whichever, have your finger on the very back end of the carriage that holds the disk and push to the front gently as it tries to open the door, you will know because you will hear a short click from a relay. If you cannot open it after a couple of tries then power it off again and unplug it. There are only four screws that hold the disc player part in itself. Take those four screw off so you can lift it far enough to get to the bottom front of the disc player. Once you can do that, without the power on, there is a white neoprene part that moves from left to right or right to left to open and close the door. You will be able to see it and you can manually slide the part to whichever side it will move and that will open the door. You can gently push the door back closed and open it again a few times. Then place the disc player back in place with the screws in and power it up and open the door with the remote or button. It should open. What happens is that depending on how long the player has set on a wharehouse shelf or just around even if it is new, the lithium grease that they use for the moving parts dries out and it needs a little push and use to work properly again. Let me know if I can help in any other way.
Posted on Feb 09, 2009
Bang & Olufsen Beosound 3200 CD Door won't open
Could be the PCB9 light and motor control have the problem its on the upper left side of the player.
Feb 25, 2013 | Audio Players & Recorders
DVD player doesn't work
you can open the top cover and take the cd out.
Jun 04, 2008 | Sony SLV-D350P DVD Player/VCR
Tip
If disk door wont open - stays locked
I called Samsung who suggested pushinhg the play button on the panel and the power button on the remote together. "No disc" eventually showed on the screen and pushing the open/close door button worked.
However, my remote wouldn't work, even after changing batteries.
The machine did play. Unfortunately, later that night I tried another DVD and it locked up again. The next day I tried the above 2-step and it worked again, so maybe the other DVD caused trouble. But I cant get my remote to do anything except the 2-step listed above.
I don't use the player very often.
on Aug 02, 2010 | Samsung DVD-P241 DVD Player
Tray's sticking on vocopro 8000 pro
Sounds like belts are slipping under tray. They can be cleaned or replaced or new ones of course.
Dec 23, 2007 | Vocopro CDG-8000 Professional Dual CD/CDG...
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
WHY MY PORTABLE DVD WON'T PLAY
It won't play for one of two reasons:
1. There is something inside the DVD player, which keeps it from playing.
2. The DVD player's battery has run out of juice and can no longer play, meaning the player needs to be replaced.
Aug 06, 2012 | Curtis Sylvania SDVD7037 7-Inch Portable...
I have a Samsung DVD R160 recorder. A few days ago the recorder was not on and it was making a noise like it was trying to read a disk. This went on for quite a while. I then turned it on and it would...
Try this, look for a small hole on the front of the unit.Use a pin and press in to see if it opens,ejects the disk .If no hole try seeing if you can press ,lift,pull at the door/slot while pressing the open door/eject either on the unit or with the remote control.It sounds like you may have a bad CD/DVD (copy) that the unit is trying to read/load but can't. keep trying to eject CD/DVD if this doesn't work unplug unit for 5 minutes,try open door again do press and hold open repeatedly I know it's frustrating but it just may eject.Don't use this recorder for playback of DVD buy a $30 DVD player the cheaper the better they play anything.GOOD LUCK
Jan 04, 2011 | Samsung DVD-R160 DVD Recorder
The disk door couldnot open
On the front of most DVD players there is a button with EJECT printed under it.
The same button is normally on remotes.
Try pressing this button.
May 04, 2009 | Televison & Video
RCA RS 1285 5 disk audio system won t show or play
When you turn on the unit the cd draw seams to open. I hear it making a noise like if it is trying to get ready to play. When you shut the draw it won't play, change tracts, or the disc thing to put in more disc wont work. Someone please help me
May 01, 2009 | RCA Audio Players & Recorders
DVD DOOR AND VCR DOOR WILL NOT OPEN, DOES NOT EJECT TAPES OR DISK
I have had some luck in unplugging the machine for five or ten and then trying again. I have spent five to ten minutes trying to get the darn thing to spit out the disk and it refuses. Unplugging either gives me time to cool off or it helps the machine :)
Apr 30, 2009 | Panasonic PV-D4745S DVD Player/VCR
Sharp BDHP20U Blu-Ray Player Logo
205 people viewed this question
Top Sharp Televison & Video Experts
Dave Naylor
Dave Naylor
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
