Question about Sony KP-51HW40 51" Rear Projection Television
My cable works but theres no picture
A have a new tv and i just need like a code to activate the cable cause were i got my tv they had satelite
  • Jim London
    Jim London May 11, 2010
    Hi, I'm not sure exactly what you mean by needing a code for cable. Did you mean you need to change the input from satellite to cable? Can you give a better description of what you need. Thanks
    Genius:
  • 2,920 Answers
You dont need codes for cable. even if they had satelite where you bought it you still wouldnt need a code for the cable
Posted on Feb 09, 2009
I'm not sure if this is a TV problem or a satelite problem. We removed the HDMI cable from our 32' Dynex flatscreen for a few minutes, re-connected it and now the TV says "Perform Channel Auto...
Seu problema parece ser do receptor de sinais via satelite. Programa?ao de canais no receptor de satelite; Verifique se seu cartao (chip card) esta bem conectado.
Dec 13, 2010 | Dynex Televison & Video
Tip
Direct TV states "Not available" on screen.
When your Direct TV based units say that a channel is "not available" when you know that you had been receiving them on a regular basis you probably have a problem with the activation card. Sometimes the unit will lose it's communication with the satelite and it will not restore it when the signal reappears. This is probably a software issue but happens so rarely no one wants to fix it.
If all the other menus and parameters of the system appear to be working the problem probably lies with the activation card. For many reasons the card can become unusable and cause the system to not work. Generally though it is caused by a glitch in the software. As the unit continually reacquires the satelite or satelites, it must execute instructions just like your computer. We all know that computers are prone to failure so why not satelite dish receivers.
The solution involves removing the card then reinserting it and hitting the reset button near the card slot. This will cause the unit to reboot and re-acquire the satellite and all the programming. By forcing the unit to reboot it must read the information from the card and reload the software. Once reloaded the software will no longer have any glitches in it and should work as it is supposed to.
This should solve your problem. If it does not you may need to call your satelite provider.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank You.
hardrocko
on Nov 13, 2010 | Televison & Video
After hooking up my new vizio, and checking the set up with dish, there is a glitch in the picture every 30 seconds or so.
Glitches in tv display are usually caused by an irregularity in the cable this irregularity could be in the form of poor connection somewhere or partly broken cables or even partial contact. get an expert to examine the cables which are used to connect the satelite from end to end as well as the RF input to the TV.
Hope this solution has been helpful?
Nov 29, 2010 | Vizio L37 Television
LCD TV IS CONNECTED TO CABLE USING SATELITE. CABLE IS RUN APPROX 150 FT FROM SAT DISH TO TV. RECEPTION IS VERY GRAINY,,,IS IT THE LENGTH OF CABLE? THE CABLE IS 100FT CONNECTED TO 50FT CONNECTED TO TV....
Is the satellite receiver HD or standard?
If it is standard you should hook up the box to the tv via RCA cables (Yellow/Red/White) and this will help with the picture quality.
If it is a HD receiver then hook up the box to the tv using a component video cable and this will drastically change the quality of the picture.
Using a coax cable to attach from the box to the tv essentially is connecting an analog signal to the tv and this will produce a lower quality picture...
Good Luck!!
Jan 02, 2010 | Samsung LN32B360 32 in. LCD HDTV
How can i get the code for starchoice satelite? i lost my remote to the satelite cable.
HOW CAN I GET THE CODES FOR MY SANYO T.V TO WORK CAUSE I CANT SEEM TO GET IT WORKING WITH MY PX-RC1 ROMOTE IF ANY ONE KNOW WHO TO HELP ME CAN YOU PLZ TELL ME HOW ITS DONE THANKS
Jun 09, 2009 | Universal Remote Control MX-500 LCD Remote...
TV ''Dish'' not working on second TV
check sat in cable, if cracks or breaks in line can cause sfss. also on back of receiver you want to make sure that sat in cable has a little copper wire sticking straight up and that its getting a good connection on the back of the receiver.
Apr 23, 2009 | RCA DISH Network(r) 311 Satellite System
NO CLOSED CAPTION VIA BOSE LIFESTYLE 20 SYSTEM
CC is a function of your cable box in this case. TV's have the feature as well, but Bose is right about not all HDMI devices supporting CC through HDMI, especially converting from component to HDMI before hitting your TV. The solution: call your cable provider for this. Start at the source. The cables you use or the TV won't 'take away' closed caption if it's already there.
Feb 19, 2009 | Toshiba MW20FM1 20 in. Combo
New Sharp Aquos LCD 46 TV
If you hooked up the satelite box to your tv Automaticly the Satelite box is the one who pick up the channels (from the satelite)
In this case your tv is acting as a monitor only. Try to connect your tv with HDMI cable or COMPONENT cable for best picture. Don't use RF antenna input to hook up your Satelite Box. Hope this Helps
J
Dec 28, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Green screen
I have never seen this tv have a problem that turns the picture all green. What is signal source, (cable or satelite) and are you using component cables? Make sure your cables are good and that they are plugged in properly on both ends as a defec or loose component cable or a bad cable or satelit receiver can cause this problem.
Oct 14, 2007 | Zenith D52WLCD 52" Rear Projection...
Picture problems
This could be an unshielded cable problem. Also magnetisam from speaker(s)(i.e. subwoofer) could affect signal from satelite antenna, or could affect satelite receiver if it's near.
Oct 01, 2007 | Panasonic SC-HT40 System
Sony KP-51HW40 51" Rear Projection Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
