Question about Panasonic PT-47WX49 47" Rear Projection Television
Replace stk392 on panasonic tv
Can the average person with no repair experience replace a 391-110 on a panasonic tv? Where is it located?
    Sergeant:
  • 250 Answers
Yes.u can easily replace the stk ic.but you should be perfect in soldering the ic.thats the main thing necessary in replacing the ic. to get the full instructions step by step with diagrams just click this link and follow http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
please do rate the solution . thanks.
Posted on Feb 09, 2009
Possuo uma tv kp51ws510 posso usar o stk392150
no - stk392-560 can only be replaced by the same or a stk392-570
when buying replacements make sure they are not the junk generics...anything under 20.00 each are generics....the real sanyo versions are 20-40 each on average but worth it since they will last
Oct 03, 2012 | Sony KP-46WT510 46" Rear Projection HDTV
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Picture distorted, bowed in with shadows on text. Cannot adjust convergence using direction on menu guide.
This is a very common problem with all projection tv's2.gif it is the stk392 ic's in your set have failed. You can attempt the repair yourself as long as you understand the risks involved when working inside a tv, otherwise you can get it repaired by a pro and i would guesstimate it will cost somwhere between 250 to 300 to fix. the ic's are located on a big heatsink and the number stk392-xxx xxx If xxx is beteween the numbers 110 and 180 you can use the stk392-180 for the repair, and i would recomment doing this. if it is stk392-560 or another number replace only with the same ic.
Sep 03, 2009 | Panasonic PT-53TW53 53" Rear Projection...
My sony projection tv has bouble image. can i
Well repair of TV depends on your own skills and if you have any experience of electronics stuff repair then it would not be difficult. This kind of repair requires good parts soldering in PCB expertise.
Your Sony KP-51HW40 seems have problem with convergence out ICs (two ICs) that would be replaced. Both ICs STK392-560 are located on D Board and available in Part Store.
Thanks.
Aug 21, 2009 | Sony Televison & Video
My PT-53TW53 Panasonic
Be aware:-
There is electric shock risk involve in TV repair.
You should have strong electronics repair knowledge / experience and good soldering skills. Repair your TV at your own risk.
Mostly 3 blinks in this model shows convergence out ICs failure and you need to replace STK 392-110
Its big black IC and TV has 2 mounted on silver heat sink at main board.
HERE is a pictorial web link and you will see how you can replace these ICs.
STK392-110 are available in Part Store.
Good luck.
Jan 15, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sudden shutdown - Red light blinking 3 times
Replace both convergence Ic's Stk392-110 and personally I'd use STK392-150's for greater reliability. Also check all 2.2 ohm 2w resistors for open or change in value and replace as many as needed...
Bill
Apr 18, 2008 | Panasonic PT-53WX52 53" Rear Projection...
Convergence for Panasonic 47"
Yes it is that set uses the same IC STK392-110 You can get the new ICs at this link and they will provide free installation instructions with pictures as well as free on line tech support instant messaging while you do the repair. heres the link.
http://servicemanuals.vstore.ca/
Apr 14, 2008 | Panasonic PT-47WX49 47" Rear Projection...
PT= 53WX42F
Does it blink three times if so its a convergence problem -your set uses stk392-110 i usually replace with stk392-150 or stk392-180 these are more stable. if you have no soldering experience or electronic experience. but if you want the challenge go for it. remember that there can be several thousand volts in this set even when unplugged.
Dec 12, 2007 | Panasonic PT-56WX53 53" Rear Projection...
It sound's like I am having a over surge problem
Don't have a repair come to you take the TV to them... And no, it's not something you can repair yourself. The symptoms you're describing are a common problem with the PT51HX41 in that one of the convergence amps has failed and most likely opened or dramatically changed one of the feed resistors in that circuit. Your amps are IC7001 and IC7002 both STK392-110 and I personally recommend using an STK392-150's for greater reliability. The feed resistors in that circuit are a 2.2ohm/2w and most likely you'll find one or more heat stressed... When researching for a shop ask them if they have the STK392-150's on-hand and if they have any problem subbing to that for greater reliability. Most shops will have no problem. Sorry if this wasn't what you wanted to hear - please don't kill the messenger. As a certified tech I most hate having to tell people bad news in a solution. Good Luck Bill
Jun 12, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Blue Convergence
Convergence problems are generally simple repairs, presuming you know how to solder and have a bit of brains about you. Eventually every projection set will have this problem - STKs are usually at fault (STK392-010/020/040, STK392-110/120/150/180, etc) and are easily aquired and replaced. Sometimes a fusible resistor is taken out in power supply circuit, sometimes a resistor will burn. Generally easy fix. Repalce STK and any fusible/blown resistor - you will need a multimeter, decent soldering equipment (NOT a 40watt iron or gun from Radio Shack, unless you're brave) and the replacement parts. But as everyone says - servicing TVs can be hazardous. Call a servicer if you're concerned, but in-shop repair should cost less than $250 - it would never exceed that at our location.
Apr 02, 2006 | Sony KP-61S65 61" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
