Question about Maytag SAV4655A Top Load Washer
Spin cycle became very loud within last couple days
My SAV4655A became very loud when in the spin cycle within the last couple days and does not seem to be drying clothes as well as it did. Could the pump be going?
  • fieldrep Apr 10, 2009
    I have the same problem and it just gets worse. Appears the main bearing is bad where the transmission enters the tub. If I can get the seal nut off I should be able to replace it?
    Brigadier General:
  • 8,619 Answers
Hi!
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Do rate the solution.
Thanks
Rylee
Posted on Feb 09, 2009
Make loud noises on spin cycle and smoke when we open door
The loud noises seem to be a feature of newer front loading machines. We bought a Maytag and have had similar issues since day 1. We were told the bearings are the problem. They don't last and make major noise as they wear.
Oct 28, 2013 | Samsung WF316BAC 3.79 cu.ft High...
Loud noise during spin cycle
what kinda noise, sqeeling, or clunking, mite be sumthing small that made its way behind ajatator an is causeing noise..or one of the springs that hold it broke..sorry i dont no what kind of noise.....
Jan 31, 2010 | Washing Machines
Loud clacking sound from the washing machine as spin cycle starts
Yes you either have a whirlpool or kenmore...since you didnt mention the make I guessed :) It sounds like you have a bad coupling, have included a link giving you instructions for replacing the coupling and a link where you can buy the coupling.
http://www.thisoldappliance.com/howto/Motor_Coupling.htm
p.s you don't actually have to remove the cabinet, the motor, pump and coupling can be accessed by tilting the machine back and wedging something under it so it does not fall on you while your working on it.
you can purchase the part from:
http://www.appliancepartspros.com/part_details.aspx?part_id=3963893
Hope this helps.
Jun 23, 2009 | Washing Machines
Loud screeching noise when spin cycle is on
Good morning! Possibly the noise was due to improper placement of load into the spinner which should be within its capacity load. best regards.
May 02, 2009 | Washing Machines
Water not draining
The belt may have failed due to the pump seizing up.
Remove the belt and turn the pump with your hand. If the pump seems hard to turn (should turn freely) replace the pump.
Jun 25, 2008 | Maytag SAV4655A Top Load Washer
Ecosmart loud during spin cycle
My majestic sounds exactly the same on the spin cycle and I wondered what the problem was. Is your unit still under warranty? If so, call the customer service line and get a repair started. I am a firm believer in warranty work on products I have purchased. WE pay hard earned cold cash on our consumer products and WE should be taken care of properly.
Good luck and please let us know what the solution was to your problem.
Jan 13, 2008 | Fisher Paykel EcoSmart GWL15
Spin cycle
  Did it make this noise just when it stopped spinning.  Just for a couple seconds?  If so,  it's only brake noise and not a concern.  If it does this all during spin you probably have a bad tub bearing.  Is it a roaring noise?  This is what the bearing will sound like.
Oct 28, 2007 | Maytag PAV2300 Top Load Washer
Maytag SAV4655A Top Load Washer Logo
205 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
