Question about Microsoft Xbox 360 Console
Disk jammed in console
My son's Xbox 360 put in a disc and it did not enter the tray correctly and it jammed in the console.
  • Anonymous Apr 19, 2009
    i have the same problem ive tryind your idea but i got pist case i wouldnt read and i shoved it in now i cant get it open someone help!!!!
    Problem Solver:
  • 19 Answers
Remove the Faceplate by prying your fingernails into the bottom of your faceplate and pulling up. After removing the faceplate try ejecting the disk again. If it still does not eject. Straighten a paperclip and use the manual eject hole under the disk tray. Do not force anything. just push in the clip and pull the disk tray gently. Good luck. Make sure to remove your disk before sending it in for repairs because they will not send any disks back with the console.
Posted on Feb 09, 2009
SOURCE:
Xbox 360 elite console makes 2 weird noises and says open tray when putting in any discs.how to fix it
I've fixed open tray errors before, and if you are sure the problem is with the 360 and not the disc, it means you need to open the dvd drive and slide the laser over once or twice (at least based on my experience). BE CAREFUL. The mechanism that allows the laser to move around and read the disc is probably jammed.
Mar 20, 2011 | Microsoft Xbox 360 Console
I put in a disc into my xbox 360 and i just keeps reading th disc and saying open tray, I open tray, put in disc and close tray, it reads the disk and just repeats message open tray?? Please help
You can do it yourself by opening the xbox 360 case and the dvd rom with a proper tools.. tighten with a screw (counter clock) right there!! (see the picture)
Feb 16, 2011 | Microsoft Xbox 360 Console
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
Games will not load on xbox 360
If once you put a game in the disc tray but it is does not load, you still have the dashborad on the screen or its just says "Reading" then "Open tray". You'll need to check first that you didn't set your Xbox 360 to boot to the dashboard.
To check this turn on the Xbox 360 with no discs in the disc tray. Go to the System section then Console Settings then Start up make sure it's set to Disc not Dashborad.
If you select disc the Xbox 360 will play the disc when you turn it on. But if you select dashboard the Xbox 360 will stay on the dashboard when you turn it on.
If you did so and still not loading, try another thing. Make sure this issue isn't with this disc only. Try some other discs and DVDs if you have to make sure is it an issue with this disc specifically and by then you'll need to get another disc or it's the console itself.
You'll need also to make sure that your Xbox 360 is not overheating and it's in a well ventilated place.
Check that the date and time are set correctly. To check this go on the System section then Console Settings then Clock then Date and Time. If it's not set to the correct date and time, set them correctly.
The last step to try is to unplug the Hard Drive and try some discs without the Hard Drive attached just to test is it the Hard Drive or the Xbox 360 itself faulty. If you did so and it worked without the Hard Drive, it would be obvious that it is the Hard Drive's issue.
Take care.
Jul 17, 2010 | Microsoft Xbox 360 Console
The xbox 360 elites keeps on saying open tray when trying to play
1, the disc may be dirty
2. the mian reason for this your xbox drive cannot read the disc , because the power of the lens is gone(not completely) ,
solution:
1. keep your disc inside the drive and switch off the console, again swith on try this 2 to 3 time
2. keep the console in vertical position or little slanding position(180 dg) make sure it does not fall
3. its better to buy hatddisc and load the game inside it , so that u lens life increased
4. change the entire drive
Feb 09, 2010 | Microsoft Xbox 360 Console
Xbox will will not play any games or DVD's.
try putting the game disc into your game console and close the lid with your hand without pressing the close lid button. hold the disc tray with your hand and turn off the game console. Turn on the game console. If problem still persists try cleaning the xbox with a blower or a vaccum. Pm me if problem still continues. Thank you .
Aug 07, 2009 | Microsoft Xbox 360 Console
Xbox 360
When your son knocked the console over, he may have broke a component connecting to the disk drive, especially if the console was on.
Apr 11, 2008 | Microsoft Xbox 360 Console
Xbox 360
Send the unit back to Microsoft for warranty repair.
Call 1-800- 4MY XBOX to set it up.
Mar 24, 2008 | Microsoft Xbox 360 Console
Open tray close tray reading open tray
call xbox customer support at 1-800-4MY-XBOX
Jan 18, 2008 | Microsoft Xbox 360 Console
Xbox 360
tap on right above the drive if a tap doesn't work just hit a little harder mine does it every now and then it will pop open
Aug 25, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
102 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
