Question about GE Spacemaker JVM1640SJ Microwave Oven
The blades do not seem to be cloged or stuck
  • 72 Answers
Hi this is techcrazy
possible solution to your problem may be
Possible causes:
1. No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
3. Open thermal protector or thermal fuse.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some models).
Hope this solution helps you
pleae do rate me on this solution
Posted on Feb 09, 2009
Garbage disposal is not working. There doesn't seem to be anything in it and resetting and unplugging/replugging hasn't worked. Do I have to take it apart?
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
Apr 25, 2011 | Microwave Ovens
Never have used a garbage disposal, now after 4 month and using it only about 30 times the water in the sink will not drain. When I turn on the garbage disposal the water in the sink swirls so I know it is...
hello fowl..... you have a blockage in the garbage disposal. you can use a chemical drain cleaner and pour it into the sink where the disposal is located. you should also look into that drain with a flashlight to make sure that there is not a fork or some other object causing the blockage. If you do not choose to use the chemical, you can also disconnect the disposal using the wrench that should be under the sink where the disposal is located. if you choose this method, have a pail handy to catch the water. also unplug the disposal before you work on it. Joe
Apr 24, 2011 | Microwave Ovens
I am looking for the installation guide for our old FB11 garbage disposal showing the sequence of installation steps
hello and welcome to fixya,
could you please provide the make of the garbage disposal? it will help me to narrow down my search alot of units seem to be fb11 garbage disposal I await your reply Thanks
Mar 23, 2011 | Microwave Ovens
Disposal won't start. Is there a reset button?
usually on the bottom of the unit, but first check to see if you have voltage to the device. if it hums when you turn it on, its getting power and may be jammed with something. first make sure its not being jammed by something. On the bottom of the unit is an allen wrench slot that you can use to turn the motor by hand, this will sometimes free up a stuck disposal.
Mar 14, 2011 | Microwave Ovens
Model mh3184xpso whirlpool microwave the vent fan for steam from the stove is humming in the off position. it works on all speeds but it runs real slow on the off position and hums.
Have you recently had a failure with the cooktop lights?
If so, we see (and repair) this a lot. The problem is on the control circuit board, which we regularly repair nationwide by mail for $39.95.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Even if you've not had a recent failure with the lights, i would bet it's a leaky hood fan triac on the control circuit board.
Mar 13, 2011 | Whirlpool MH3184XP Microwave Oven
When my dishwasher drains both sides of sink fill with water...then they both eventually drain back into the dishwasher.
Sounds like your sink drain trap or line is clogged. When the dishwasher drains, the sink drain can't keep up, the water backs up, then backs down the dishwasher drain line into the dishwasher. You may not notice the slow line when you run a little water into the sink, but with the amount of water coming from the dishwasher the problem is worse. You can try taking off the trap under the sink and making sure it's clear. If the problem is farther down the drain line, you can try snaking it yourself, or call a plumber. I don't recommend using Liquid Plumr or Drano because if those don't work, they leave the line full of caustic chemicals for the next person who works on it. That can be dangeerous.
Dec 07, 2010 | Microwave Ovens
All of a sudden, the water is coming back up on my garbage disposal instead of going down, it also swirl. I tried to see if the blades are moving and they are free, not stuck, also there is nothing that I...
The drain out of the disposal is plugged up...
Take the drain piping apart and clean it out and then you will be good again...
Aug 29, 2010 | Microwave Ovens
Ice jam in haier freeze
No you can use a hairdryer to melt it.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer
Dec 12, 2009 | Microwave Ovens
Cooling fan hums and turns slow.
You will need to replace the cooling fan motor. Remove it and check the numbers on the fan and then do an online search for the motor. you can also contact a website called the repairclinic.
Oct 20, 2017 | Whirlpool MH1170XS Microwave Oven
Blades don't rotate when unit is turned on
does the unit make any noise?? if so its prob bad..replace!....if no noise check under unit, there is a small red reset button..push up firmly.. turn on...keep fingers out please!
Mar 15, 2009 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
