Question about Brother MFC 210C All-In-One InkJet Printer
My Brother MFC 210 C printer will not print in yellow.
I used the cleaning mode, tried another cartridge and finally tried a brand new cartridge. Still no yellow. The print test page shows all the other colors printing OK.
  • roberto serbin May 11, 2010
    Have you tried uninstalling and then reinstalling the printer with your installation disk?
I cannot print the documents that i want ,,the printer cannot recieved the documents but it can copy.
Posted on Jun 25, 2009
MFC 240C will not print yellow despite new cartridge
check if plastic cover on ink cartridge . may need a lot of cleaning of print heads may need to get cleaning alcohol and a cloth and clean print head physically
Dec 24, 2014 | Brother Multi-Function Center MFC-240C...
MFC-420CN refuses to recognize or use black ink
The print head is clogged.Try powerful cleaning:
Press menu, then start black copy, then four times arrow-up quickly after another.Machine will be in maintenance mode
(all lights will flash).
Press 7-6-4 and OK (or start-black-copy).
When finished press 7-6-3 then start black copy,
printer will do a power purge.
Leave maintenance mode by pressing 9-9.
If this not help better think about new printer, because cost of repairing this one is profitable.
Nov 25, 2009 | Brother MFC 420CN All-In-One InkJet...
Hi i have a mfc 210-c & the yellow wont print , i get 3/4 dots i have tried to clean with no luck
Nov 19, 2009 | Brother MFC 210C All-In-One InkJet Printer
I have a Brother mfc-240c - will not print yellow
The print head is clogged.If not unclogging with cleaning process may you try to clean manualy.You need to dissasembly the hole printer to remove the print head.Put it in hot water.If you don't have a technical skills, don't try anything.
If not help just buy new printer, because the new print head will cost you as much more.
Nov 06, 2009 | Brother MFC 240C All-In-One InkJet Printer
Printer will not print dut to other color cartige. being empty.
The color cartridges print text that appears black by mixing the three primary colors (cyan, magenta, and yellow) to make composite black. To achieve a realistic black, large quantities of colored ink are used. Because black cartridges use much less ink to create a similar shade of black, they print more pages in black than the color cartridge.
If the color cartridges on the printer are next to empty, you will not be able to get perfect prints at all.
Please have the cartridges replaced to do the printing jobs again.
Sep 10, 2009 | Brother Multi-Function Center MFC-240C...
Does not print properly-even after installing brand new cartridge
most likely your ink nozzles have clogged up.
try several cleanings, if it still does not work, you probably have to get the printhead replaced.
Jun 26, 2009 | Brother MFC-465CN InkJet Printer
Brother MFC-465CN won't prink cyan
You got to re-check back the Ink Cartridge you've buy recently.. Sometime the ink already freeze inside the cartridge bcoz its been really-really-really long time they keep before the usage.. Ive also have experience about problem like this b4, so better re-check/change back the cartridge.. Or If the
printer head is not at the cartridge, it is seperate from the cartridge, you have to check back the printer head also.. normally all the new printer head comes together with the cartridge.. and prefer to use the Original Cartridge more than Pirated Cartridge ok.. Cheap Cartridge always giv a lot of problem, especially like Your problem.. Thats All, Good Luck and Happy Trying..
DEAth-MaN88®
May 08, 2009 | Brother MFC-465CN InkJet Printer
I think i need to clean the heads but i tried with a lint free cloth, still having the same problem
Make sure you have installed cartridge correctly. There is head cleaning routine in software and also on printer
Apr 30, 2009 | Brother MFC-210 All-In-1 Print/...
Won't print won't run clean routine
Did you try this
Press Ink.
2 Press ▲ or ▼ to select Cleaning.
Press Menu/Set.
3 Press ▲ or ▼ to select Black, Color or All.
Press Menu/Set.
The MFC will clean the print head. When cleaning is finished,
the MFC will go back to standby mode automatically.
If you clean the print head at least five times and the print has
not improved,
Apr 28, 2009 | Brother MFC 420CN All-In-One InkJet...
Mfc 210 nor working
make sure that you are using genuine Brother ink cartridges.what is on the lcd screen of the brother machine?if no cart,remove all cart.reinstall them.if there is an error message,sorry,but you have to replaced.and your brother machine does not have a green cart.it only has cyan(blue),mag(red),yellow and black.there is a way of cleaning it though
May 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
760 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
