Question about Avanquest My Invoices And Estimates Deluxe (gb0u3c0gn0000me066) for PC
Version 9.0 Grey bar acroos fourth line of invoice.
I have a grey bar across the fourth line of the invoice. I can type in this line, but the drop-down menus are locked up, and I have to type in the product descriptions.
All the rest of the lines are the same way. Also, I can't go back and edit a line, as it is locked up.
The first three lines are okay.
Thanks, Sharon
  • ronshimek Apr 08, 2009
    Hi Cinderelly32, this Ron.
    I have the same problem.
    It appears to be a rogue "window" floating around inside the program,
    most likely a software bug. Use your imagination and picture the
    grey line you are referrring to as the title bar of this rogue window.
    You most likely are now viewing it while in the Invoice tab.
    Most of the time, only a portion of this rogue window is blocking
    the Invoice Description area. For a test, tab to Estimates
    and if your problem is like mine, the rogue window will now
    be behind the Estimates Description area, but you will still see
    a portion of this rogue window on the left hand side and away
    from the Estimate Description area, until of course, when you
    scroll in that Estimates Description area again and now this
    rogue window comes to the foreground and blocks the data
    again. Finally, flipping back and forth between the Estimates
    window and Invoice window does allow you to see what is in
    those associated windows, only until your start to scroll in those
    windows, because at that time, this wierd rogue window will
    come to the foreground and block what you are trying to view.
    Let me know if you have found a solution.
    Thanks
    Ron from Wisconsin.
    President:
  • 2,976 Answers
Check your options & custom settings If that doesn't fix you up, try reinstalling the program. It sounds like one of the functions didn;t load in properly.
Posted on Feb 09, 2009
Screen keeps going black then grey and white lines start to come across the screen.
This is not the fault with remote control. It is with your TV itself. Contact any service technician.
Gopakumar Gopalan Google
Mar 24, 2014 | Televison & Video
Dell inspiron laptop grey dotted line across
You could try removing the display device in device manager then rebooting. At boot up windows will reinstall the drivers.
Check for new display drivers at Dell's support site.
Mar 13, 2014 | Dell Inspiron E1505 Notebook
Grey screen with coloured lines
Sounds like your video processor is faulty or a loose ribbon cable inside your tablet.
Feb 14, 2014 | Samsung Galaxy Tab Tablet PC
Grey and green bars across the TV
You are describing symptoms of power supply failure.
Jan 10, 2014 | Shar AQUOS LC-60C7450U 60" 3D 1080p...
Grey lines during playback.
Camcorder video head required cleaning because gray lines come in playback when video head got clogged/ dirty.
Put video head cleaning tape and playback it as per instructions.
hope this will help you.
Thanks.
Apr 03, 2010 | Sony DCR-HC38 Mini DV Digital Camcorder
Grey Lines across video display
Same thing is happening to mine, it's not the minidv because i tried that one on a diffrent camera and it works fine. It's got to be a setting or something. If anyone can figure it out, that would be great.
Sep 01, 2009 | Canon ZR200 Mini DV Digital Camcorder
My HP LJ 4 is printing Grey roller type marks. Not diagonal it's like a rectangle across the the width of the paper about 1 1/2 wide then a space about 1/4 then the Grey again. Any help would be gr
Sounds like dirty rollers or perhaps a bad print cartridge. If you have another ctg to replace try it first if lines are still there check the rollers inside the machine where the paper is fed. Use the sheet to match where the marks are to the rollers on the machine. When you find them clean with alcohol and let dry then try again. there are also paper feed tires that are inside the paper tray that could be dirty also.
Hope this helps
TankMurdock
Apr 24, 2009 | HP Office Equipment & Supplies
Blue line acroos the top and grey picture
not able to assist you with your problem, but if you give up on trying to get your issue resolved and decide to get rid of the tv and wish to sell it fo rparts then please contact me as i am in desperate need of the lense out of the front of this unit you have. Thank you i can be reached via email @ mrshadetree0222@aol.com, or via phone# 304-937-2369
Feb 16, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Main LCD
Check with the Software of the mobile,try to reinstall the software in mobile,not solved show the LCD Screen from authorize service center.
Jan 17, 2008 | NEC 535M Cellular Phone
Avanquest My Invoices And Estimates Deluxe (gb0u3c0gn0000me066) for PC Logo
144 people viewed this question
Top Avanquest Computers & Internet Experts
Alun Cox
Chris Larocque
Are you an Avanquest Computer and Internet Expert? Answer questions, earn points and help others
