Question about Nokia 6070 Cellular Phone
Insert sim i change the sim ic but it not solved,then i did jumper setting,but the problem not solved after that i flashed the mobile then also the problem not solved. how 2 solve this problem nokia6070 insert sim
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 158 Answers
Just clean the connectors, thats it
Posted on Feb 09, 2009
Insert sim card is found in low signal
First:
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Second:
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Jan 12, 2013 | Samsung GT C5130 Mobile
Tip
Insert Sim
When ever u have a problem of insert sim and the board point of sim jack are dead then u can jumper them easily by an iron....like this
look there are 8 points are stick on board and what u have to do .... simple
upper three points. (. . .) like this leave the centre and jumper..
centre three points (. . .) like this leave the centre and jumper or joint a wire to them as above on.
Last one two points (. .) like this jumper them or joint them.
if problem not be solved then heat/change power ic
on Jan 04, 2008 | Nokia 1600 Cellular Phone
Nokia 2626 insert sim jumpur setting
Hi.If you know the location the sim card ic jumper tricks is always same to other nokia.Anyway you can see the image from this link how to short sim ic of Nokia 2626.. Good luck
Oct 07, 2011 | Nokia 2626 Mobile Phone
When i insert sim to nokia 1650,the mobile hanging on display swoed only NOKIA
Phone of nokia like 1200 1208 1209 1650 sim ic location is same, you should try this jumperS IN R2700 to solve your problem....!!!!!!!!!!
Jul 16, 2011 | Computers & Internet
Always insert sim card eventhough the sim card is good and in a demo mode. What can I do?
The sim card IC(filter) might be broken or damage coz it is kind of glass/the pin of the sim case may bend or broken.The only solution is to change these thing.....anyway if you can do just follow the link 1661 sim ic jumper - Google Search
Jul 12, 2011 | Nokia 1661 Cell Phone
How to resolve a problem "sim card not inserted".
ITS INSERT SIMS PROUBLEM
FIRST CHANGE YOUR SIM
CHEK CONNECTION
PACKING
CHECK SIM SOCKET
RESOLD IT
THEN SIM ICS PROUBLEM HIT SIM IC
CHANGE SIM IC
JUMPER SIM IC
OR CHANGE IC
Oct 22, 2010 | Nokia 2760 Cellular Phone
My Nokia N72 is working only in offline mode. I therefore cannot make or receive calls. When I try to switch to general mode, it says I must insert a sim card whereas the sim card is inserted. Will you...
This problem is called the 'insert sim' problem, there are several possibilities but first of all clean the sim card and the sim card interface on your phone. Next try it with another sim card. If this doesn't solve the problem, you need to go to the mobile repairing shop to get it serviced, or if you have idea in repairing mobile you can refer to this site on how to do jumper tips and tricks for this problem..http://sephonetechnology.blogspot.com/2009/08/nokia-n70-sim-ic-jumper.html Good luck.. and please...-:)
May 04, 2010 | Nokia N72 Cellular Phone
Insert sim
Hi have a repair shop, and you know it’s a very common problem on this model. 90% of the cases I found liquid damage in the phone damaging the Sim Ic, it’s a little square one near your sim reader, you can also clean around that with a soft tooth brush and mentholated sprits. Don’t fiddle with your sin contact/ reader if no damage visible to the eye.
Dec 05, 2008 | Nokia 2626 Mobile Phone
Nokia 6070 Cellular Phone Logo
456 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
