Question about Dewalt DC011 AM/FM Radio
Broken battery port
I put in a battery wrong and pushed in the metal connecters, so i opened upthe radio and found that i had broken the center circuit board where the bat conects to. Its held down with 4 screws wher can i get a replacment for that board. thanks james
  • 3 Answers
Try this link for parts:
Posted on Apr 21, 2009
Survelliance headset won't work anymore with motorola t9500
Try leaving the batteries out overnight and see what happens
Aug 13, 2014 | Motorola Talkabout® T9500 Two Way Radio
Broken power plugin port
The power plug in port you refer to is the DC Power Jack.
The AC adapter (Charger) converts AC electricity into DC electricity.
DC electricity has two poles. Positive, and Negative.
(Just like on a D cell flashlight battery)
The center pin of the DC Power Jack is the Positive connection.
The outer metal spring-like pieces, on the inside of the cylindrical shape surrounding the center pin, are the Negative connection.
(The pieces of spring-like metal, all connect to the Negative connection in the DC Power Jack)
Example of a replacement DC Power Jack, for the Asus Eee PC 1005HA Netbook,
[ Note*
Cannot agree with the replacement instructions they offer, at the bottom of the page.
Not everyone has access to a hot-air gun. A 25 Watt soldering iron, and Desoldering Braid, is better, and more easily accessed ]
A few articles dealing with replacement of a DC Power Jack,
1) Remove ALL power. Remove the AC adapter, (Charger), and Battery.
2) Observe Anti-Static Precautions. Buy, and use an ESD wrist strap.
Electro Static Discharge.
(Average cost is from $3 to $6. Connect the alligator clip to a good ground source.
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
If you wish to proceed in replacing your DC Power Jack, and need guidance, post back in a Comment.
Dec 01, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
How do you remove the radio from a 2006 ford f-150 truck?
Open the ash tray, and on each corner pull out. The center trim panel ( from the top of the ash tray to the top tray on the dash ) is held in with 6 spring clips, the 1st time you remove it, it is hard to pull out.
Work you way up pulling out each side. The HVAC panel is attached to the center trim panel, and has 2 cam over connectors on it, and at the top if the PAD ( PAssenger Airbag Deactivation ) light with very small wires. Once you have the center trim panel off, you will see the 4 bolts holding the radio in.
Pro Fit International sells mounts, and they have some nice directions in PDF format available for download that show the removal process. Just look up a VSM for your MY truck, and on the listing page it will list the part number as a URL, this is the PDF version of the instructions.
Jun 24, 2010 | 2006 Ford F-150
Radio Locked Up, due to wrong code entered.....
Leave the radio on for one hour and the radio will reset. Works on all locked Mitsubishi radios. Dont go opening up the radio for no reason....
Jun 21, 2009 | 2001 Mitsubishi Montero
Saturn ion 2005 or 2006 - cannot get key out of ignition
there a battery peg under the hood so you can jump it
May 28, 2009 | 2006 Saturn ION
An Error in ibm T61p lAP TOP
Here is a link to the maintenance manual.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You will need to identify which usb port is bad by connecting a device to each port and seeing which one isn’t working. This is a physical problem with the connection between the motherboard and the USB port. (The system reads an open circuit) What is most likely happening on your laptop is one of the four 'prongs' for the usb port is pushed back (into the center on the laptop) and unhooked the connection to the motherboard. I have a feeling that because several people seem to be having this problem that there might be a manufacture defect with the particular USB port.
The way to fix it: (*note: whenever you work on the inside of a computer wear insulating gloves and remove the battery from the computer before hand.*)
Depending on your laptop there should be an access panel to the core compartments. Open the access panel and check if the usb pin’s are not seated correctly.. (Please note* the very small metal piece should be soldered very well onto the motherboard, the problem will probably be that it was pushed out of the USB connection side and it should still be rigidly connected to the mother board still.) Carefully place the small metal connector back into it's slot so that it looks like the other three. You should really solder this back into place. If you don’t know how take it to a repair shop to make sure it gets done correctly.
Feb 02, 2009 | IBM THINKPAD T61P T7700 2.4G 2GB 160GB...
I need 2 open my samsung dvd camera recorder sc-dc173u my usb port is pushed in
Oct 27, 2008 | Samsung SCDC163 Camcorder
Move timing cover with the motor still in the car. go behind harmonic balincer
sounds like you have had a frustrating time.... sorry to add to it.... i believe the balancer has to come off to replace the timing cover.
Sep 27, 2008 | 1992 Cadillac DeVille
Texas Instruments TI-85 Display Problem
You need a good screwdricer and skilled hands and an experienced friend for directions. Remove the batteries and the small backup battery. Remove the two other screws on the outside. Open it up and remove the metal shield. There should be a ribbon cable connected to the screen. IF YOU SCREW THIS UP, YOU SCREW UP THE CALCULATOR. take the screwdrivr and gently lift up on the top of the connecter on the board. push the cable in with very little force. it may snap into place. Push down on the cable fastener and it should hold the cable in place. Put the shield back on, replace the batteries, screw in the screws, and try to turn it on. You did something terribly wrong and need to reseat it again. if it works, well done! (clap clap)
Buy a TI-86.
Jul 31, 2008 | Texas Instruments TI-85 Calculator
If it was working fine before then are many reasons why this could happen
1. Battery is old and is dead
2. Battery not plugged in properly
3. Carbon might have appeared at the ports where the charge passes thru in the laptop
Solution: open the cover where u put the battery, The ports where the battery goes in , try to touch the metal area with any other metal so that if there is any carbon it passes thru to the other metal... and the ports become free
4. Try to do a flee power release
MAke sure battery is fully charged.
Take out the battery from laptop
when the battery is out , press the powe button on laptop for 30 sec and then put the battery in ur lapyop and try to trun it on by pressing the power button firmly.
IT shud work
Try different batteries ( u can borrow )
if it still does not work
They contact laptop vendor , the ports where the power from battery goes in to ur system are faulty
Take it to an authorized service center.
Feb 20, 2008 | Tablets & eReaders
Dewalt DC011 AM/FM Radio Logo
120 people viewed this question
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Rob Beech
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
