Question about Toshiba 53H71 53 in. Rear Projection Television
The electricy plug and cord
The electricity plug and cord on my Toshiba 53 inch rear projection TV got pulled off the TV during a move. Is it safe to take off the rear cover and insert back the cord myself?
  • 716 Answers
If The Unit Is Under Warranty There Is A Good Chance You Will Void The Warranty. But If The Unit Isn't Under Warranty I'd Go Ahead And Pull The Real Of The Tv And Repair The Power Cord Just Make Sure Everything Is As It Should Be Before You Put The Tv Back Together And Make Sure There Are No Exposed Wires Anywhere.
Sincerely,
Michael Scott
Posted on Feb 09, 2009
Moving the TV
TV should be in upright position during transportation in some safe packing around it.
Thanks.
May 13, 2010 | Toshiba 50H82 50" Rear Projection...
My toshiba rear projection 55 inch tv is showing a double reflection in blue how do i fix it
Replacing the Convergence IC'S should fix it. They should be STK392-110's. I would replace both of them as a pair.
I hope this helps,
Skyassoc
Nov 14, 2009 | Toshiba 53H71 53 in. Rear Projection...
52 inch Toshiba rear projection no picture has sound
You have bad solder connections in the deflection circuit. Call a good TV tech unless you know what you are doing. You could get an electrical shock from a charged capacitor.
Jul 06, 2009 | Toshiba 57H81 57" Rear Projection...
BIG SCREEN rca d53w19, where are the fuses????
There is one fuse if you look in the rear of the set on the left side follow the power cord as the cord plugs into the Main filter board which has the fuse. Its located right next to the power cord on the right side of that board
May 27, 2009 | RCA D52W19 52" Rear Projection Television
Tv screen will not stop blinking
It sounds definitely like a faulty power connection via the video cable from the inside. If it blinks a while then turns black then shows the picture, it would have to be that it's not screwed on properly, thus taking more time for it to get a full charge and then properly function. If you still have the warranty, any electric repair/retailer shop can fix it for you.
May 04, 2009 | Sony KP-53S65 53" Rear Projection...
My Hitachi 53 inch projection tv screen is warped...colors off
Good Luck on find screen ask all your local tv repair shops if they have one your size cost anywhere from150.00 up to 500.00.
Dec 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Toshiba TN55V71 55 in. Rear Projection - Damaged
Hi. If the convergence is out but uniformly then chances are its not electrical problem more likely to be physical see if the 3 small crt tubes are loose & can move about. Or was your stuff insured during the move if so put in a claim.
Sep 23, 2007 | Toshiba TN55V71 55" Rear Projection...
43 inch rear projection
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 22, 2006 | Toshiba 53H71 53 in. Rear Projection...
Toshiba 53H71 53 in. Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
