Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
LiftMaster Remote Not Shutting Garage Door
The remote controls are not shutting the door but they are opening them, When you press them when the door is open, it makes a clicking sound and it seems like it is actually trying to go the other way, that is, in the open direction, in my opinion. To shut the door, I have to go to the wall mount, press it once, then press it a second time but this time leave my hand on it until it closes
  • Anonymous Feb 10, 2009
    I have the same problem.Please send me the answer to fix this problem at
    alwinchar@hotmail.com
  • 30 Answers
That is a sensor problem click on the buttom on your tracks or left and right side. there are little boxes on each side of your garage door. Those are safety eyes. they much be looking at each other. they should have a light on each one make sure there both on. that will with out a doubt fix your problem. But if your have a hard time getting them to work make another post and tell me the make of your opener and the color of the lights on the photo eyes. I will be on for another hour or two to help you
Posted on Feb 10, 2009
How to change code on the garage door opener and the remote control on a lift master garage door opener
If you have a 315MHZ LiftMaster Garage door opener do the following:
Follow the purple wire (Antenna) up and you will see a square purple button.
Press and hold the square purple button for ten seconds until the amber led goes out.
Press and release the purple button one time (The amber led will come on solid).
Press and hold the button on the garage door opener remote control for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
to program the wireless keypad do the following:
Enter a four digit code into the keypad then press and hold the enter button for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
Aug 08, 2014 | liftmaster Lift Master 377LM 376LM 315 MHz...
Garage door will not close from remote or car. Garage door will open from remote or car; however, it will not close using these controls. The only way I can close the garage door is to press on the manual...
Try reprograming the opener to each remote, if this doesn't work then the command/radio module in the opener is damaged and needs to be replaced. Hopefully you can find one or you will have to replace the whole garage door opener. Good luck.
Jan 21, 2012 | liftmaster Chamberlain Garage Door Opener...
We have a Liftmaster garage door opener. I bought a new remote control for it - a Liftmaster security plus. I have tried to program it by pressing the button on the garage door opener, then pressing the...
YOU NEED TO MAKE SURE YOUR REMOTE IS THE SAME FREQUENCY AS THE EXISTING UNITS.
IF YOU LOOK ON THE BACK OF THE REMOTE THERE SHOULD BE A FREQ# IF THEY ARE NOT THE SAME YOU NEED TO EXCHANGE THE REMOTE.
HOPE THIS HELPS
Mar 26, 2011 | liftmaster Chamberlain Garage Door Opener...
My garage door opener remote does not work.I have a craftsman garage door opener manufactured in 1999. The garage door opener remote panel has a green light on and will open the garage door. The remote,...
Make sure the green light in the wall control is not flashing. That locks out the remote. If it is press and hold for 3 seconds the lock button on the wall control. It could just be that your remote has failed.
Dec 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
How to program the remote control door openers Liftmaster 3750E-1?
Locate the smart/learn button on the rear of the motor unit. Press and hold the button on the remote while you press and immediately release the smart.learn button. Do this for each remote.
Sep 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote control for garage door suddenly stopped working.
Press and hold for 3 seconds the button on the wall control with the lock icon. There you go.
Nov 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have 2 liftmaster 3245. The hand held remotes were working fine then stopped. I replaced the batteries and turned of all electrical/RIF close by. Still not working. Both cars operate the doors with no...
You need to reprogram the remotes by briefly pushing the learn button on the garage door opener until it flashes once, then release the button on the garage door opener.
Now press the remote button once until you hear the garage door opener click, now press the remote button once again and the remote should be programmed to work for that garage door opener.
DO NOT press and hold the garage door opener learn button for more than 10 seconds or you'll erase all programs and have to relearn all the remotes, including your car ones.
Hope you found this very helpful and best regards.
Aug 06, 2009 | liftmaster Chamberlain Garage Door Opener...
Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
