Home | Bialetti | Moka Express 6-Cup Coffee Maker | Espresso irregularly spu...
Bialetti Moka Express 6-Cup Coffee Maker
Problem for Bialetti Moka Express 6-Cup Coffee Maker
Espresso irregularly spurts out the center post
By sallymargoli on Feb 09, 2009
I recently replaced the gasket and filter in my Bialetti 6-cup pot with genuine Bialetti parts.
Now instead of gently flowing out of the center post, the espresso takes a long time to start brewing, and when it does, it forcefully spurts out of the center post, making a huge mess, and it takes a long time for the pot to finish brewing.
I thought it might be that the grind is too fine, but this grind works great in my 3- and 9-cup pots.
HELP! What's wrong?
Same Problem
Apr 27, 2009
-   I have exactly the same problem. It must be the gaskets. -   7054mwc
Apr 27, 2009
-   I HAVE EXACTLY THE SAME PROBLEM. It would sem that it MUST be the gasket. -   Guest
Best Solution
posted on Jul 17, 2009
Very Helpful)
7054mwc
Rank: Guide
Rating: 92%, 3 votes
It IS the gasket!!!!! Store the pot with the two parts screwed TIGHTLY together for about a week. Tighten it up as the new gasket compresses. Problem solved in two weeks or less. Funnel had NOTHING to do with my problem. Also cook on medium to low heat. High flame seems to make the problem worse.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 07, 2009
Somewhat Helpful)
RTDR
Rank: Apprentice
Rating: 75%, 1 votes
I have to agree with colebeck, it is the funnel. I followed the advice of 7054mwc but without any improvement, after replacing the funnel it worked first time.
Was this helpful?
Yes
No
Solution #3
posted on Jul 16, 2009
Somewhat Helpful)
colebeck
Rank: Apprentice
Rating: 75%, 2 votes
I've been posting this solution on all the same types of problems with these stove top coffee makers.
It isn't just the rubber gasket that needs replacing from time to time.
The funnel cup [where you put the coffee in] also needs to be replaced over time as it does get bent out of shape [how about when you knock it on the side of the bin to get the coffee grounds out?].
I've just been through the whole gasket thing and couldn't get it to work, then changed the funnel cup as well and it worked first time, and second, and third and every time since!
Was this helpful?
Yes
No
Popular Solutions for Bialetti Moka Express 6-Cup
Questions and Unsolved Problems for Bialetti Moka Express 6-Cup
Do you recommend Bialetti Moka Express 6-Cup Coffee Maker?
Answer
Answer
How long does it take for the water to reach the top of the tank? Also, the sales clerk sold me... (More)
Answer
My bialetti coffee maker ends up boiling the coffee if left on the stove. Is it meant to do this?... (More)
Answer
When I first got my Bialetti Mukka, it would leak from the sides.  Online, I found the fix of... (More)
Answer
The pressure valve on my Bialetti 6-cup Moka espresso coffee maker blew out after 1 month. I have... (More)
Answer
When I add water to the bottom (top of the filter) I can not get water to drop down into the chamber... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bialetti Moka Express 6-Cup...:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
