WASHER DRUM PROBLEM EXCESSICE MOVEMONT
The drum in my washer has an excessive amount of play you can move it several inches in either direction however all top straps are secure and i can see nothing on the bottom lose or broken ? ge washer mod # WLRR417OG1WW
    President:
  • 1,902 Answers
Have you checked the drum bearing? The bearing is on the very bottom attached to the drum. If this bearing has broken it will allow for excessive play in the drum, Also make sure every bolt is secure and tight
Posted on Feb 09, 2009
My Electrolux from load washer GLTR1670AS0 started making a load banging noise during the high speed rinse out
One or more of the washer drum shocks is broken and or the washer drum bearing is defective and has excessive play.
Jan 28, 2017 | Electrolux Washing Machines
Maytag MHWE400WW01 fills with a small amount of water when not in use
Selenoid valve leaking. Could be a rubber washer or complete valve or very low water pressure.
Dec 08, 2013 | Washing Machines
When the machine goes into spin cycle there is excessive vibration as if something was loose in the drum. Other wise the machine cycles fine. Is there someway to check for bolts or nuts loose on the drum....
Move the drum around by hand and listen carefully. There should be no loose bits or rattling, if there are it is possible that something has slipped in between the drums. It sounds as if the drum bearing may be failing. Grip the inner drum and move it up and down at the front while feeling for play relative to the outer drum. i.e hold outer drum and lift inner drum relative to where you are holding. There should be virtually no play.
Jan 05, 2011 | Kenmore HE2 Plus Front Load Washer
Need to balance washing machine drum
The drum should not need balancing, but the washer should be level in all directions. If the washer is level, but vibrates excessively during spin cycle, you may need to replace the springs. There is a set of suspension springs which act as shock absorbers. When these wear out the washer will bounce across the floor unless the clothes are 100% balanced in the washer.
Jul 29, 2009 | GE Washing Machines
Excessive vibration
check for bearings fault,ie open door and lift inner chrome drum up and down if you feel a knocking feeling or you ear this then its the bearings
Jul 06, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
SMEG WDI 12 Washer/dryer Unable to fit new belt
Sadly, the answer to your question isno, it's not normal. In fact as soon as I saw the first sentence of your problem, I guessed the rest. The wheel should have no play at all and the drum and wheel move together on a sprung mechanism. The reason that the wheel is loose is because the bearings in the drum (That sit directly behind the centre of the wheel) are worn out. To be sure that this is the problem, open the front of the machine and pinch with your thumb on the outer (static) cylinder of the drum and your forefinger on the drum that spins. There should be no play here whatsoever. I suspect that you will see the best part of a quarter of an inch of play and pinching as I describe will make a nasty little clunk at the same time. The other classic sign (though not always there) is that there is a tiny amount of water leakage from the bearing at the centre spindle of the wheel. The reason the belt comes off is because the wheel is unstable on the worn out bearing.
Some machines can have their bearings replaced by a competent DIY-er, but many require a specila tool to extract the damaged bearing and press the new one into the housing. I imagine that a call to your local supplier will reveal which of these actions is possible for your machine, but either way, this is going to be a real pain. It's a drum out job and that's not fun if you have never done it before (I do occasionally, and I still don't have any fun!).
Sorry to be the bearer of bad news.
Mar 26, 2009 | Smeg WDI12 Front Load Washer / Dryer
EXCESSIVE AMOUNT OF PLAY IN DRUM BANGING NOISE
hi, was the machine making a noise when it was runnig, if so you may find the drum bearing has gone and needs replacing,, hope this helps
Feb 09, 2009 | Washing Machines
Not spinning properly
You will need to replace the inner basket and front outer tub assembly. Likely, the spider on the inner basket (drum bracket) has broken which is causing it to be loose and rubbing on the inside of the outer tub. This can be verified by checking for excessive play of the inner basket (hold the front of the inner basket and check for play by moving it up and down).
It's not a cheap repair unfortunately. Be sure to always use a small amount (2 tablespoons for a full load) of HE (high efficiency) detergent to prevent future build up which could cause corrosion of the tub spider.
Feb 01, 2009 | Whirlpool GHW9100L Front Load Washer
Kenmore 80 series washer
drum is stationary in wash and moves only in spin
Aug 19, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
87 people viewed this question
Top Washing Machines Experts
