Question about Vivitar 285HV Flash
No power for my 'old' Vivitar 285HV Flash
I pulled my old Vivitar 285HV flash out of retirement (stored away for several years, without batteries installed). I would like to use it, with an optical slave, as an off-camera unit since the sync voltage problem keeps me from using it on my newer digital Pentax camera . Alas, after installing fresh batteries and flipping the power switch on -- nothing. Instead of the familiar 'buzz' I got zip. Please, how should I proceed?
    Problem Solver:
  • 17 Answers
I've got three 285HVs and have had this problem. Obviously, make sure the batteries are good and the door and inside terminals are not corroded. The whine sound that you usually hear is the high voltage circuit. the reason it changes pitch is that the main capacitor is charging. As the charge gets greater and greater, the pitch with go up as the circuit changes the power being fed to the capacitor. If you don't hear the "whine" then it's either the HV circuit isn't working (probably not) or the capacitor has gone bad. These things are sealed but can decay internally due to their structure. Usually this is due to the dielectric components breaking down or the electrolytic goo drying up (usually what causes it).
Sometimes, you can let it sit with good batteries and the switch on to see if it will eventually start to charge the cap. Most of the time tho, this is an indication that the capacitor or the charging circuit is dead. It can be repaired but sending it off will usually be more expensive than replacing the unit.
Be sure and rate me!!
Posted on Feb 09, 2009
How to remove sensor from Vivitar 285HV Flash
Pull it straight out from the body. See the instructions on page 9 of the manual.
Oct 22, 2012 | Vivitar Used Replacement Vari Sensor...
Why does it take more than 20 seconds to change up in order to fire the flash strobe on the vivitar 285hv
My first impression is that you are using the flash at its maximum capacity and completely draining the charge each time. I'd also say that you are only going to get about a dozen flash burst before the batteries are exhausted. I use several Vivitar 283's 285's and a couple 285HV's in a portable studio set up I have and the 285 HV's have got to be tuned down about 1/3 before I can get them to match the other flash outputs. If I need all out brute power then the 285HV's are used on full inside a softbox. I generally work with a 16 batteries between the two 285HV, also they need good fresh batteries off the charger. On a photo shoot I'll get maybe 15 shots before the power is down enough that I change then, I'd say powering back up it'll take about 15 to 20 seconds before they come out.
Jan 30, 2011 | Vivitar 285HV Flash
I have a Vivitar 285 HV flash that hasn't been used for 15 years. Nothing happens when you install fresh batteries and turn it on, is there something else I can try? thanks Ian
After that long without power, the main storage capacitor has likely failed. If you can find the correct model or an equivalent one, then you'll find that they're not overly expensive but you'll need good soldering skills to replace it without damaging the new one and to ensure that the new connections are sound.
Sep 01, 2010 | Vivitar 285HV Flash
My one year old vivitar 285hv flash fires intermiiently (every 3 or so flashes) when the flash is connected by pc cord??
PC cord might get minor short circuit and got faulty.
You can confirm this by removing it.
May 20, 2010 | Vivitar 285HV Flash
Need battery holder for Vivitar 285 flash
easiest way to get these is search for them on Ebay. they are usually very plentiful. If that fails, most on-line camera stores (B&H Photo is a good one) have them on line to order
Feb 03, 2009 | Vivitar 285HV Flash
No power know
if you're talking about the plug in knob on the front of the unit... without the knob, the unit will only deliver full power and not try to control the amount of light based on the color coding. there is no way around this. you can, order a new plug in module either from vivitar, on line stores like B&H or probably find one on e-bay.
Jan 27, 2009 | Vivitar 285HV Flash
Vivitar 285HV Stop Working
There is nothing wrong with your flash unit. The regular AA batters are 1.5 v volts each- if 4 batteries are used that is a total of 6 volts for proper operation. The rechargeable batteries are 1.2 volts each and 4 will get you 4.8 volts- thats 1.2 volts short and that is probably the root of our problem .
Try recharging you rechargeable batteries and put the im one more time- if the same problem happens you will have to stick with standard AA batteries. There external 6 volt packs that will work with your flash unit0 the are a bit of an expense at first but you will save on replacement batteries in the long run,.
Nov 27, 2008 | Vivitar 285HV Flash
Can I use my Vivitar 385 with my Pentax K200?
Yes, you can use the flash if your camera has a PC connector.
Or, check the trigger voltage: under 7VDC = OK on hotshoe.
Oct 31, 2008 | Vivitar 285HV Flash
Will not flash red/green
This means Battery is low to charge the capacitor.
I suggest you test this with unused new Duracell.
Oct 06, 2008 | Vivitar 285HV Flash
Vivitar 285HV Flash Logo
355 people viewed this question
Top Vivitar Cameras Experts
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
