Question about Xerox Phaser 5500N Laser Printer
Change ink cartradge 11ER00670, same error after new cartradge.
  • 1,602 Answers
SYSTEM NEED TO BE RESET, CARTRIDGE MAYBE DEFECTICE, THE SWITCH MAYBE A PROBLEM, GO ONE LINE AND SEE IF ANYONE ELSE SEEN THESE TYPES OF PROBLEMS, GO ONLINE AND TYPE:
XEROX PHASER 5500N LASER PRINTER CARTRIDGE ERROR 11ER00670
ENTER
IF THAT WAS THE ERROR NUMBER YOU HAD
OR
XEROX PHASER 5500N LAZER PRINTER CARTRIDGE ERRORS
ENTER
OR
XEROX FOREM GROUP
ENTER
OR
MANUFACTURE NAME,MAKE,MODEL, DRIVERS AND SERVICE MANUAL
ENTER
ROD
Posted on Feb 09, 2009
Type of ink cartridges
you have to use the same number cartradge but you can get a cheaper brand look on ebay the best place of that stuff and guranteed or money back
Mar 28, 2014 | Lexmark X Office Equipment & Supplies
Print Blank Pages not print by ink cartradge full
Here's a solution to your printer problem ;
Press the Ink button -> Test Print -> then choose Print Quality -> the printer will then go through and print a series of small squares in each of the four colors in the shape of parallelograms. If you see any gaps in parallelograms then you will be asked asked to clean the cartridge, do so. -> Just keep repeating process until there are no gaps
Then I did an Alignment check right after the cleaning through pretty much same process:
Press Ink button-> Test Print -> then choose Alignment-> and make sure the patterns match to the closest number
In Case You Still Need Online Help For Brother Printer,Then I Suggest You Follow Us For :Brother Printer Support
Sep 14, 2012 | Brother Ink for Dcp145c Lc-980
I have multipack ink for sx115. the blue has run out. how do i change it to go to net colour. thank you
There is no any way to change only blue colour ink. You need to change complete cartradge of this Epson printer.
Thanks
Sachidanand
Apr 13, 2010 | Office Equipment & Supplies
The cartradge block is blocked at the right handside most likely due to a faulty cartridge. How can I manually move the block to the left and get the cartridge out??
For a forced cartridge change it will either be a quick press of the ink button or by holding the paper feed button for 10 seconds. Or there may be a an Ink cartridge replacement option the Printing Preferences > Maintenance section of the driver.
Jan 19, 2010 | Epson Stylus Photo R2400 InkJet Printer
I could not find the ink cartradge for the printer D3200 CAN YOU LET ME KNOW AT LEAST THE COMLATIBLE ON THE ORIGINAL CARTRADGE IS OC20 AND 0D10
u can order and get that via net.......just go for shoopin online.com .........here u will find that and u can purchase that by usin ur visa card and other cards
Oct 15, 2009 | Office Equipment & Supplies
Cyan not printing,
PURCHASE A NEW CARTRADGE OF GO ONLINE
CANON 850i WILL NOT PRINT IN CYAN
SEE IF ANYONE ELSE HAS THAT PROBLEM AND HOW THEY SOVLED IT
ROD
Feb 02, 2009 | Canon i850 InkJet Photo Printer
How to put a ink cartridge in a Canon i850?
LIFT THE FRONT COVER UP , GIVE THE PRINTER SOME TIME AND THE PRINT HEADS SHOULD GO TO THE CENTER OR RIGHT OR LEFT MARGIN PUSH IN AND DOWN.
----------------------VERY IMPOTANT-----------------------------
I THINK NEW CARTRADGES INSIDE THE PACKAGING HAS INSTALL INSTRUCTIONS INSIDE THE BOX WHEN YOU BUY IT FROM CANON INK CARTRADGE, OTHER BRANDS MAY DO THAT, IF NOT SURE OPEN BOX LOOK INSIDE AND SEE IF THERE IS INSTRUCTION ON HOW TO INSTALL NEW PRINT CARTRADGE
ROD
Jan 06, 2009 | Canon i850 InkJet Photo Printer
System Error. lower heater is not warming. I have reset the printer. but no response. My printer model is SAMSUNG CLP-310 SERIES. WHAT TO DO NOW?
It's a internal issue of printer. you need to check your printer warming heater. because in the printer you can find two warming heater they are used for waming the text of your printer cartradge ink. go to neares service center and check it.
Dec 01, 2008 | Samsung CLP 300 Laser Printer
Epson stylus pro 4800 black ink problem
When you put the printhead back into the machine, did you seat the dampers correctly?
Aug 07, 2008 | Epson Stylus Pro 4800 InkJet Printer
How to change printer ink cartridge
This is fairly simple. first make sure you have the proper replacement cartradge. then open the frount of your printer. your cartridge compartment should slide to the middle. to open these compartment you should look at them they should have an arrow or some sort of instructions. remove the old cartridges, take the new cartridges and make sure the securtity tape has been removed from over the bottom. then place them in the proper slots, black/color. firmly push them in, and close the ink compartments and the frount of your printer. you should be ready to go! if these instructions were not helpful, you should refer to the printers user manual and lookup ink replacement. if you have no manual, then search for your printer type and model and check out the faqs.
I hope this information was helpful.
Aug 01, 2008 | HP Computers & Internet
Xerox Phaser 5500N Laser Printer Logo
272 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
