Question about Hobart A200 Stand Mixer
A200 electronic start switch
Have Hobart A200 ml # 104858 (missing) switch-electronic start 50/60 Hz part # 00-271612-00002
when I get new switch what wires go where. Thanx, Harry
  • harryo52 Feb 12, 2009
    Thanks Bigg T, got new switch and found that in fact they where marked. Like to stay ahead of thing and didn't want to wait till last minute to find that switch would not be marked. Thanx for sharing Bigg T. Harry Oooooooooo
  • flormont Feb 20, 2009
    Hi Bigg_t, I would be interested by your diagram which describes how to connect the start-relay.Could you send it to me, please ? many thanks, flormont@gmail.com
  • 640 Answers
Hi harry,the wires should be marked 1-2-3-4,if not i'll give you the diagram.Let me know.
Posted on Feb 12, 2009
Why My Hobart A200 20 QT Mixer ML #104858 Motor Is Smoking?
I think... without knowing that motor... that the capacitor is a start capacitor, and that the start switch may be trying to "start" the motor full-time instead of switching it out of circuit after it figures that the motor has spun up. I may be wrong - that design may be a capacitor-run motor (similar to a three-phase motor) - but I'm betting it's a start-only capacitor.
If you know someone with a capacitance meter, you could check the capacitor - for both capacitance (to be sure it matches the label) and leakage. Easy way to write that one off. Alternatively, you could rig it such that after the motor's wound up you could manually disconnect the capacitor and see what happens - either the motor stops or else the smoking issue stops.
Whatever you do, don't let it smoke very long. The varnish on the windings is only so thick.
Jul 31, 2014 | Hobart A200 Stand Mixer
ANTONIO
you mean it was not working now?
Mar 20, 2008 | Food Mixers
Hobart A 200 Mixer
There are four possibilities to look at here. Assuming your mixer has a normal capacitor start motor (older a200's used a different style motor), possibilities are, in order of likelihood:
Motor start capacitor
Start switch (electronic or mechanical)
Burned wiring
Motor start winding
The start capacitor is located at the rear of the mixer. Remove the rear cover (4 screws) and pull the cover towards you. Disconnect one wire from the capacitor and test with any multimeter.
The start switch, if electronic, is able to be tested, but not very easily. Once you've eliminated the other possibilities, it's time to replace the (electronic) start switch. If the motor has a mechanical start switch, it's easy to test: Remove the two wires at the rear of the motor and test for continuity with the motor stationary. A multimeter should show near zero ohms for a good mechanical start switch.
Burned wiring should be easy to spot with some careful inspection around the motor, capacitor, and start switch.
Start winding: Look closely at the stator (stationary part of the motor). If some of the copper windings look significantly darker in color than the others, it's likely the start windings were overheated (the start windings are the thinner copper wires - if you look closely, approximately half of the wires are thinner than the other half). Look for a wiring diagram behind the power switch and determine which wires leading to the start switch and/or capacitor are for the start windings and test for continuity across the start winding. You should read a fairly small value such as 5 - 15 ohms. Values significantly outside this range could indicate a partially open or partially shorted start winding.
Jun 09, 2010 | Hobart A200 Stand Mixer
Stationary Start Switch part needed
Go to your local Motor repair shop. They usually have used ones laying around or can sell you a new one.They wont try to sell you the new improved solid state controlled version!
Dec 14, 2009 | Hobart A200 Stand Mixer
Hi i have hobart mixer 220v and it start to make loud noise when the dough get harder .thank you
What is the model and ml # on the data plate?I'm a hobart tech and repair these mixers often,let me know.
Nov 20, 2009 | Hobart A200 Stand Mixer
Looking 4 used parts A200
The safety cage kit is not cheap and you may not find a used cage. Why would you want to install used gears? They would have been removed from a mixer that has failed for some reason. Usually broken gears or shafts.
Mar 06, 2009 | Hobart A200 Stand Mixer
On and off switch for hobart stand up mixer a200
I'm a hobart tech---what is the ml number on the data plate?
Feb 23, 2009 | Hobart A200 Stand Mixer
Hobart A200 MIXER ON/OFF SWITCH
I would call hobart and have all the information about your machine you can find on the data plate they have more that one style of switch
Jan 28, 2009 | Hobart HL600 Legacy Stand Mixer
Hobart A200T General Info / Back cover plate gasket
I'm a service tech for hobart,I'll type your serial number into our database and see what it brings up.The changes that have been made---older units use a mechanical start switch on the motor,the new units use an electronic start switch.the old units center shaft and gears have changed.the older units dont have bowl guards and the new units do.(this is a cage that goes around the bowl).The gasket that your talking about is just that--a thin paper.The paper wears and you get that symptom you describe and its normal.I'll get back to you.
Feb 20, 2008 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
478 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
