Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
KF-50WE620 4 FLASHES
My Sony will not power up; it flashes 4 times which seems to point to the fans. The service manual shows 3 fans I could only locate 2.
I tested both fans and they do work. Where is this third fan (if my set actually has one)? Any ideas on what would cause this problem?
Would a bad lamp, bad lamp driver or circuit cause the problem?
Thanks for any assistance.
  • FerGarza Mar 31, 2009
    The same problem 4 flashes
    Novelist:
  • 184 Answers
There's a fan in the optical block (light engine) You may also have either an intermittent fan or a bad connection from the fan(s)
michtech
Posted on Feb 20, 2009
Sony 50sx200u red light flashes 3 times then atemps to light up then goes off fan seems ok#
Try a new bulb. Sony XL-2000, or if you can replace the old one from the housing (simple to do), an E23H 120 Watt will work.
May 07, 2014 | Sony KF 50SX200U Compatible TV Lamp
My sony wont turn on the red light keeps flashing
Need to check all your switches and connections.
The Red led indicated and device function problem and you need to respond with the sequence of flashes. ( Example 1 long and two short. or Flashes 3 times ? )
Let me know if the fan is running and the age of the power supply.
Sony LCD Model KF-60WE610 lamp was replaced and then it shortly after stopped turning on. Blinks Green 6 times then Red 6 times Please help!
For Sony Model KF-60WE610, KF-50WE610, and KF-42WE610, the Diagnostic Code of power light indicator flashing 6 times green, then flashing 6 times red (6 red etc), means you need to replace part number A-1302-272A G1 BOARD, COMPLETE. See Sony Service Manual, 4. Chasis-1 at part Ref no. 103. The Power Board sits vertically in two slots on the left side of the electronics board. 4 wire connectors to remove when replacing. This component fits all 3 KF models listed above.
Jun 22, 2011 | Sony Grand WEGA KF60WE610 60" Rear...
Sony wega kf-ws60s1 , standy by red lamp flashes 4 times, help please!!!
standby 4 time flashes shows error of Fan that is not running in TV.
Your TV has 4 fans and any one is not running due to some reason. Check fans are not caught wires or some thing that causing problem.
Qualifier tv tech will require to inspect TV if you are not comfortable working in TV.
Dec 16, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
My kf-e50a10 lcd projection tv suddenly just shut off and when i
Check your fans. You have a stuck fan. You may want to call a service center as it is a pain to get to one or two of the fans. Theres 3 or 4 of them.
Dec 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
KF-WE42 Indicator flashes red.
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 29, 2009 | Sony KDF-E42A10 42 in. LCD Television
Sony KF-50WE620 - 5 Flashes
5 flashes indicates ballast malfunction. 4 flashes indicates fan not working. I would replace the big fan in the back because it is a common failure for this model. But befor this check to see if the lamp door is warped from overheating. If it is the wiring on the balast good be burnt and the light engine could be damaged.
Feb 02, 2009 | Sony Grand WEGA KF-50WE620 Television
Sony KF-WE50
my front panel sound is not working.......?
how i can do this.?
Jan 05, 2008 | Sony Grand WEGA KF-50WE620 Television
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
124 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
