Question about Sony VAIO PCG-GRT360ZG Notebook
Wireless gone down
My wireless has stopped working on my laptop, only way it works is when i plug the cable into the netopia box
  • 2 more comments
  • jackie_be2 Feb 09, 2009
    No it does'nt even show if theres wireless near me
  • DEKR
    DEKR May 11, 2010
    are you still having problems
  • Dan rogers
    Dan rogers May 11, 2010
    No the device manager shows all the devices connected or installed on your computer. Try this...
    Right click on your "My Computer" icon and select properties. The icon will be on your desktop or the start menu Then select the hardware tab and click the device manager button and this will bring up a window called your device manager. Then look for a wireless network controller and see if there are any small icons or pictures next to to the device.
  • Dan rogers
    When you go into the device manager is there any icon next to the wireless device?
    Problem Solver:
  • 9 Answers
Unplug the network cable, go to control panel, double click internet options, click connections, then choose setup and follow through the steps.
Posted on Feb 10, 2009
I need to find a driver/sortware program to get my netopia 3D reach wireless adapter up and running. all i can find are these driver scans that want me to install them and scan my computer to tell me I...
Here's a driver-free, software-free solution.
Turn your cable-modem (or DSL-modem) off.
Turn your Netopia off.
Connect:
Ethernet--port on cable-modem <-- cable --> WAN port on Netopia.
One LAN port on Netopia <-- cable --> network-port on your computer.
Turn the cable-modem on, and wait until its lamps settle-down to a repeating pattern.
Turn the Netopia open, and wait until its lamps settle-down to a repeating pattern.
Restart your computer.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: Default Gateway ... 192.168.123.456
Start Internet Explorer
Type http://192.168.123.456 (or whatever numbers you see)
Login to the web-server running "inside" the Netopia.
Click to run the "Wireless Networking Setup Wizard".
Enter an SSID of your choice.
Select the 'WPA' level of encryption.
Enter a network-password of your choice.
Click OK
Restart the router (if it did not automatically restart).
Disconnect the Ethernet cable from your computer's network-port.
Click "View Available Wireless Networks".
Click the SSID of your new network.
Click Connect.
Enter the password, when prompted.
Voila! You have a wireless connection to the internet.
Oct 24, 2010 | Netopia 3-D Reach (TER/GUSB-N1)...
How do i turn off the wireless on my netopia 2247nwg router
Type 192.168.1.254 Enter your password default Username-Admin Pass-Admin
Once in there find your wireless setting and turn it off. I personally do not have a netopia router but these are the usual steps, if you have any problems comment back and i will be glad to help.
Mar 20, 2010 | Netopia 2247NWG-VGx Wireless Router...
Wireless not working, went into setup and enabled
1. Please make sure its the router and not the laptop. can you get the laptop to scan for other networks . this is to make sure that the issue is with the router and not the laptop. 2. goto the setup again and try changing channels to 11 or 4.
Thanks
Ranjit
Oct 05, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
My internet connection will work when yellow cable is plugged in but wireless has stopped working on both laptops. The wireless connection isn't even showing up in the wireless connection window.Help!
your router may have been reset somehow and the wireless settings have been retired. goto: http://192.168.0.1 . and follow the setup wizards for wireless setup. This will repair the problem
Aug 27, 2009 | Netopia 2247NWG-VGx Wireless Router...
Att dsl cable with wirelesss router netopia 3347w
yes it will work but you will need to login to the router interface and reset the router configurations
Jul 18, 2009 | Computers & Internet
I lost my CD for my Netopia USB wireless router
go to windows update after you have installed netopia usb adapter and do custom scan and it will bring up ralink 2500 usb driver install that and it will work netopia usb adapter i think it has ralink chip but it works with mine
Mar 28, 2009 | Netopia 3-D Reach (TER/GUSB-N1)...
WHAT ARE THE STEPS TO HOOKING UP MY WIRELESS ROUTER TO MY NETOPIA ROUTER - RIGHT NOW NETOPIA IS BEING FED BY MY CABLE MODEM
the cable modem should be giving the netopia an ip address
go inside the netopia by opening Internet Explorer and type 192.168.1.254
a little window will pop open
the username is admin, the password is the serial number on the bottom of the netopia
once in, click on configure, lan, then wireless at the bottom
make sure the wireless box is checked
name your network (SSID its called) like randy578
then click advanced if you want to enable wireless security encryption, your key to get online securely
click submit underneath it
clike the yellow triangle up at the top right
click save and restart
in like 2-3 minutes, click the wireless connection icon by your clock
connect to randy578 network
you should now be online
spin
Jan 11, 2009 | Netopia Cayman 3347W-Ent Wireless Router
Netopia 2247 NWG can't find Atheros AR5007EG WLAN
ok heres the solution.
goto start,control panel,performance and maintainance,administrative tools,services.
Scroll down to bottom to WIRELESS ZERO CONFIG,double click and click start.
now exit and wait a minute and your limited or no connectivity should change to connected,
let me know if this helps,
Patrick.
Aug 02, 2008 | Netopia 2247NWG-VGx Wireless Router...
Wireless adapter
here is a quick install guide for your wireless adapter,
http://www.netopia.com/support/hardware/manuals/3DReach_usb_install.pdf
good luck and i hope you make this one work.
Jul 28, 2008 | Netopia 3-D Reach (TER/GUSB-N1)...
Sony VAIO PCG-GRT360ZG Notebook Logo
42 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
