Question about Dell Inspiron 2200 Notebook
Ndisio.sys problem When I start my inspiron 2200, it momentarily goes into Windows, but goes to a DOS screen quickly with a message. "A problem has been detected and Windows has been shut down to provent damage to your computer. The problem seems to be cause by the following file: ndisio.sys." Restarting doesn't help. What should I do?
  • sb32 Feb 09, 2009
    I tried pressing F8 on  startuup, but it doesn't do anything.
  • Dell Master
  • 4,806 Answers
Hi there
Boot up in safe mode ( press F8 on start up ) then go into system restore and reset your machine to a time before the problems occurred
Good luck and thanks for using Fixya!!!
Posted on Feb 09, 2009
  • 837 Answers
That is a trojan .. run your anti-virus software .. do it in safe mode if you can
  • Jay Glendenning
    Jay Glendenning Feb 14, 2009
    Has this helped? If so I would appreciate a FixYa .. Thanks .. Crayz
Screen goes black after loading windows xp
Is it possible that it's display output is set to external screen, display no 2 from within the graphic cards settings/preferences. I cannot see how while in the GUI (XP Loaded) that making an adjustment not suitable for Laptops screen can take affect without XP sending out error messages. I really am curious now as to what the problem is or was, cheers.
May 01, 2013 | Dell Inspiron 2200 Notebook
Stack overflow at line 598
Stacks are reserved memory that programs use to process hardware events. A stack overflow occurs when there is not enough space in memory to run the hardware interrupt routines. To resolve these behaviors, you can modify the "STACKS=" line in the Config.sys file, eliminate terminate-and-stay-resident program (TSRs), and eliminate hardware conflicts.
When Windows delivers an error message that is related to an internal stack overflow, there is not enough space in memory either set aside or available to handle the calls that are made to the computer hardware. There are several things to consider when you troubleshoot this behavior:
  1. The Config.sys startup file may not be properly configured for the Windows installation. Use the following values: STACKS=64,512 ;(this is the maximum allowed)
    FILES=60
    BUFFERS=40 If you are using the dual-boot capabilities in Windows, the Config.sys and Autoexec.bat files may not contain the correct configuration to run Windows. When you are dual-booting between Windows 3.x and Windows, these files may not have been renamed back to Config.dos and Autoexec.dos.
    Examine the Config.sys file to determine if files such as Himem.sys or Emm386.exe are loaded from a folder other than the Windows folder. If so, boot Windows by using the Safe Mode Command Prompt Only option. Rename the Config.sys file to Config.dos and the Autoexec.bat file to Autoexec.dos, and then restart your computer.
  2. Some TSRs may be interfering with Windows. Disable any non-boot device drivers in the Config.sys and Autoexec.bat files. If you install from Windows 3.x and you receive a stack overflow error message, check the Win.ini and System.ini files for non-Windows-based programs or drivers that are loading.
  3. There may be an incompatible hardware configuration. Check the port and IRQ settings of the network adapter, sound card, and modem. Make sure that there are no COM2/COM4 or COM1/COM3 conflicts and that no devices are sharing IRQs. Disable or remove conflicting devices.
  4. The computer may need a BIOS upgrade. Check the BIOS version and contact the manufacturer of your computer for information about a BIOS upgrade.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 28, 2010 | Microsoft Computers & Internet
My dell inspiron 2200 wont start up..Well it starts up but then it sais "Windows start up has failed." and it gives me options to start up in safe mode with command promt and safe mode with networking...
Boot your PC with the windows OS disk and choose to repair your computer when asked. Run the chkdsk program in DOS on the recover mode to correct disk errors.
On completion, restart your computer normally and check it it works.
If it does not work, you may need to format your pc & reinstall windows again.
Aug 02, 2010 | Dell Inspiron 2200 Notebook
Boot failure. I get this message: Windows could not start because the following file is missing or corrupt: system32DRIVERSpci.sys
For what i see in forums, this issue is really hard, since u cant even start windows in safe mode cuz its one of the drivers that loads even on it. I suggest u try to run the repair windows option from a Windows CD, or even reinstall windows.
U could try to look over the internet for a pci.sys file and copy it via ms-dos if u know how to work on it.
Nov 01, 2009 | Dell OptiPlex GX270 PC Desktop
I was trying to hook up my laptop (Dell Inspiron 2200)(windows xp) to my television. I managed to get the laptop to go to the tv screen, but when computer rebooted, I got a black screen and cannot get rid...
use the F8 button before windows starts. as the laptop show the manufacturer's screen. keep tapping it gently and fast until you get froted with the bootup options screen. Select whichever option reads the word "VGA" in it. Then it will boot into windows. Enter the multiple screen setup (could be hard given that screen could show all icons and windows big) and select proper settings. Restart the PC and ensure the options remain active.
Aug 31, 2009 | Dell Inspiron 2200 Notebook
I like to use dos on full screen mode
create shortcut on desktop by right clicking on desktop ->new-> shortcut->type command->next
after shortcut appears on desktop
right click on the msdos prompt icon -> Properties ->Screen tab -> choose usage as full screen - > apply and ok...
try opening dos... u'll find dos in full screen...
May 26, 2009 | Dell Inspiron 2200 Notebook
Missing or corrupted file C:\windows\himem.sys
If you are running Windows 95, Windows 98, type:
copy himem.sys c:\windows <press enter>
If when typing any of the above commands you receive a prompt that the file already exists, ensure to overwrite it.
Reboot the computer; if the issue continues to occur, verify that the config.sys is properly setup. The line himem.sys should read:
DEVICE=C:\Windows\HIMEM.SYS
or
DEVICE=C:\DOS\HIMEM.SYS
Additional information and examples of the config.sys can be found on our autoexec.bat / config.sys page.
Dec 27, 2008 | Compaq Presario Notebook
Dell Inspiron 2200 Notebook Logo
423 people viewed this question
Alun Cox
