Question about HP LaserJet 4000 Printer
Knocking noise I am hearing a knocking noise on the left side of the printer (Looking at it from the front) about the middle of the machine towards the front. Any guess on what is causing it and how to fix it?
  • rchaney86 Feb 10, 2009
    Heard the noise with toner out. Already tried swapping the fuser out and noise still came back. Noise also followed toner to another known to be good machine. I am wondering if it is internal gears that are having issues that are not worth fixing.
    Genius:
  • 2,120 Answers
Remove the toner cartridge to hear if the noise goes away.
Pull the 2 caps with the arrows on them in the rear to check if the 2 Phillips screws are tight.
If you loosen those screws, you can pull the FUSER out and check the gears.
Posted on Feb 10, 2009
  • Leroy Elliott
    Leroy Elliott Feb 10, 2009
    Trust me on this. The 4000 is the best HP ever. I would get it fixed if it were mine.
    I still think some assembly is just loose.
Knocking nosie from left side of 06 saturn ion? hear it all the time but mainly after 2nd gear when it shifts is the worst part?
Have your motor supports checked. Also the drive shaft could be causing the problem if that knocking is not coming from inside the motor.
Mar 25, 2014 | 2006 Saturn ION
Knocking noise
check the sprocket sometimes they are put together with screws and it might be extruding out and rubbing.
Mar 04, 2014 | Yowza Fitness CAPTIVA - Worlds 1st...
Kenmore elite problems
lift the basket up and down by the front edge see if you can hear knocking noise and try turning the basket by hand see if you can hear metal to metal noise then it is the bearing...lot of things that could cause noise like unleveled machine, broken shocks etc. thx
Mar 01, 2014 | Washing Machines
The engine has a nkockig sound..could this be caused by a bad knock sensor?
No it isnt a knock sensor the knock sensor job is to detect a knock noise and ****** timing. The knock that it is looking for is from octane or fuel or pinging that creates N0X s. A pollution gas. The knocking noise that you are hearing is different. If it is a multiple noise ar a rattling sound that will be the valves. There are other noises like a piston knock this knock is a sharp metallic noise, If the knock occurs only on acceleration that noise is a crankshaft noise. You need to check you oil level and make sure it is corrects. Look at the oil condition do you see silverish or whitish condition,is the oil deep black.
Apr 24, 2011 | 2004 Nissan Maxima
I hear a knocking nosie in the front of the car and it stops when i reach about 50 miles per hour and will start again when i slow down or stop at a light or stop sign. the cv joint has been replaced on...
so the noise changes with vehicle speed and NOT engine speed?
did they also replaced the intermittent shaft and bearing
however, this cause more of a humming noise than knocking
therefore start looking at transmission concerns
May 07, 2010 | 2000 Dodge Intrepid
Front driver side suspension knock over bumps
See if you can bounce car and replicate the noise. If you can, you should be able to find it, and put your hand on it. Stabilizer bushing are a place to look, both at the lower a arm and on the frame. If you narrow it down to the strut, it will need to be replaced. The front trans mount also goes bad, try putting it in drive with your foot on the brake and give it some gas and see if the engine moves an excessive amount.
Nov 23, 2009 | 1992 Buick Regal
Knocking noise more on right side, but left side turns also
Check the boots at the ends of the front axles...If one is torn the joint has likely failed and needs to be replaced.
Jun 17, 2009 | 1998 Nissan Altima
I hear a knocking noise while driving
Check your outer c/v joints..a torn boot is a dead giveaway for joint failure (boot fails, lets dirt into joint, joint fails) Also since you didn't mention if noise is also preaent standing still, check the exhaust to make sure it's not hitting floor pan anywhere. (most likely the joint though)
Apr 01, 2009 | 2001 Ford Taurus
1993 Toyota 4Runner-Knocking noise-front end-cold weather
This is Caused By the Grease in the Spindle Bearings Getting frozen. Get it Greased up really Well and you Might need to Repack the Bearings on this side to Stop this and Stop further Damage to the Spindle.
Jan 17, 2009 | 1993 Toyota 4Runner
Knocking noise
it sounds as if your CV joint may be going bad, unfortunatly i can't tell you how to check it yourself.
Nov 26, 2008 | 2001 Toyota 4Runner
HP LaserJet 4000 Printer Logo
380 people viewed this question
Ben Johnson
