Question about Dryers
Dryer doesn't dry clothes thoroughly
I have to start my whirlpool dryer over several times before the clothes dry completely. I've cleaned the lint trap and disassembled the back to clean all the lint from the back. i'm stumped
  • Jeremy Reddick
    Jeremy Reddick May 11, 2010
    Is the dryer getting the clothes warm?
  • 979 Answers
Turn off your breakers, then back on to insure a good reset. Then check the wiring from the receptacle, to the plug and then to the back of the dryer. You are getting some heat which tells me that one leg of power is out. I don't think it is your element, because you get some heat. Let me know how you do.
Posted on Feb 10, 2009
My Whirlpool gas dryer is not working
Instructions
Check that the dryer door is closing completely. Remove anything that blocks the dryer door from closing.
Ensure the "Start" button is pressed firmly to start the dryer cycle, the dryer is not overloaded and the clothing is not balled up. Any of these things can prevent the dryer from operating and/or drying the clothes.
Use a level to confirm your Whirlpool dryer is sitting flatly and evenly on the ground. Adjust the dryer as necessary for it to be level as the dryer will vibrate and make unnecessary noise when sitting unevenly.
Examine the inside of the Whirlpool dryer drum and in the space around the drum for loose change, pens, hair ties and other items that could have been left in the pockets of clothing. These items will cause noise and potentially cause the dryer to become inoperable.
5
Examine the Whirlpool dryer's lint trap for excess lint. Remove any lint from the trap and place it back into position. Always clean the lint trap between dryer cycles. Inspect the area around the dryer and in the ventilation and exhaust systems. Remove any built up lint and clean the area thoroughly. Built up lint is a fire hazard and can cause operating issues.
6
Check the gas shutoff valve if your Whirlpool dryer is gas powered. Ensure the shutoff valve is turned all the way to the "On" position.
7Check the electric plug and ensure it fits securely in the outlet.
8
inspect both the fuse box and circuit breaker for any electrical problems. Replace any blown fuses, if necessary, and reset the circuit breaker if it has been tripp
Jan 09, 2013 | Whirlpool Dryers
Clothes get caught
Instructions
Remove the lint screen from the GE electric clothes dryer.
Roll the lint from the screen with your hand. If the lint screen is clogged with fabric softener, fill a sink with hot water and add 1 to 2 tsp. dish soap.
Scrub the lint screen with a soft-bristle brush and soapy water. Rinse the lint screen thoroughly and shake off any excess water. Set the lint screen aside to air dry while you clean the dryer exterior.
Dampen a cloth with warm water and wring it out. Wipe over the GE electric dryer exterior to remove any lint, dust or product residue. If the dryer is very dirty, dip the cloth in the soapy water and wipe away any spots.
5
Wipe the GE clothes dryer with a towel to dry. Replace the lint screen when it's completely dry.
Jan 09, 2013 | GE DCVH515EFWW Electric Dryer
Hi there, I've got a Whirlpool dryer that doesn't dry clothes anymore. The clothes get really hot, but they stay damp, never properly dry after several cycles and then smell mouldy. Oddly,...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Sep 05, 2011 | Dryers
When washing Machine goes into spin cycle, , it starts making a grinding noise and never goes to full momentum and starts to slow down, after the grinding noise. The clothes aren't fully dry as they...
Sometimes, a Whirlpool dryer may not function as you'd like.Although specific details vary by model, the company offers several generalguidelines to troubleshooting your Whirlpool dryer and getting it back intoworking order.
Verify that thedryer is connected to its power source if it won't turn on. Whirlpool alsosuggests checking your home's circuit breaker, as the high power needs of thedryer may have tripped the circuit. If the circuit has been tripped, reset itby flipping it back into the "On" position. Push the door of the dryer. Whirlpool designed its appliances to not turn onif the dryer isn't secured and notes that the dryer door may not be fullyclosed even if it appears shut. Push firmly at the top and bottom of the door,as some Whirlpool models have two latches. Press the "Start" button again. Whirlpool reports that some modelsrequire you to press and hold the button for five seconds to fully start themachine. Depending on the model, the button may be labeled "Hold toStart," "Start" or "Push to Start." Check that the dryer's settings knob is set to an actual drying mode and notsimply "Air" or "Tumble." On most Whirlpool models, themanufacturer states that the settings knob should be set to"Accudry," "Timed Dry" or "Automatic Dry." Clean the lint trap, typically located at the top of the dryer and removedby pulling its plastic handle. Over time, lint and dust builds up here. Thethicker the trapped layer of lint, the slower your dryer performance. Whirlpoolrecommends removing built up lint after every dryer load. Remove some of the wet clothes inside the dryer if it's taking an unusuallylong time to dry your clothes. Whirlpool warns that placing too much clothinginside the dryer reduces hot air circulation, which also reduces dryingcapabilities. Recommended dryer load s vary, with compact Whirlpool modelsholding approximately 3.4 cubic feet while extra large Whirlpool dryers holdingmore than 7 cubic feet.
Jun 07, 2011 | Washing Machines
Clothes have to be dried several times before getting dry
The first thing to do is to remove the ryers exhaust venting tubes and clean them out thoroughly. Any lint build up will cause the moister sensor to keep the heat in check. It is a saftey device to prevent home fires from clothes dryers. Just on small clog will do this. If cleaned and still no heat listen for a clicking noise upon starting. If no click is heard the Spark ignitor is at fault. If it is clicking the moister sensor is at fault
Jun 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Clothes not dryin
clean out the exhaust vent tubes thoroughly. the moister sensor will shut down the high heat if clogged full of lint
Jun 06, 2010 | Estate EED4100SQ Electric Dryer
Won't dry clothes thoroughly
It could be or the moister sensor is bad. Do this first for most people never think of doing this. Disconnect the entire venting duct work. Inspect it and clean it. If you get a wad of lint every foot length from this vent this will be your problem in drying clothes. The clogged vent will not let the exhaust pass through and the moister sensor detects that and shuts off the heat automaticly
Apr 20, 2010 | Whirlpool LER7646E Dryer
Whirlpool dryer not drying
your dryer is likely clogged up with lint .. that would be after the lint filter .. the pipe that carries the hot air out is usually completely clogged after that long .. it and the dryer itself (down inside) has to be cleaned about once a year to keep it tip top .. hopefully you can find someone that can take it apart and clean everythiing .. that should get you back to like new performance .. or you could call a few handymen to see what they would charge to clean the lint from your dryer and stack .. or if you are handy there is a special big brush with a string attached .. you pull that thru the stack to clean it .. use a vacuum cleaner to get inside the dryer vent (you can see in the vent when you take the hose off .. excessive lint buildup not only greatly reduces your dryers efficiency but is a fire hazzard as well ..
Aug 12, 2009 | Whirlpool LER5636P Electric Dryer
Dryer must be run several times before clothes will dry
Hi Herrony,
You have a ventilation issue. Somewhere in the internal (inside the wall) vent plumbing is a blockage. This keeps air exiting. Check this website for more information. Before calling a vent cleaning service, locate the dryer exhaust on the outside of your home and check it for obstructions (lint, bird nest, etc...).
Thanks for trying FixYa! (and if this solved your problem, don't forget to log back on and rate it, OK?)
SG
Apr 02, 2009 | Whirlpool Dryers
Whirlpool Model LE7010XSNO. No Heat After Lint Cleaned Out
Those are likely possibilities. Also check the wiring for disconnected or burned terminals especially in areas that get hot. The element comes out easily to visually check it for breaks. If that's OK I'd look at the safety thermostat.
Jan 06, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
94 people viewed this question
Top Dryers Experts
