Question about D-Link Netdefend DFL-210 (DFL210) Firewall
I want to set factury default to my fair wall dlink dfl 210
And set up again with the new Ip
    Scholar:
  • 81 Answers
With the unit on, locate the small reset switch on the back of the router. Insert the end of a paperclip into the reset switch and hold for 10 seconds. The router will restart itself and the WLAN light will stop blinking.  The router is now reset to factory defaults.
Remember The factory defaults username is admin, and there is no password.
Posted on Mar 19, 2009
How do I reset my Dlink to factury settings
Press RESET button for 10 seconds it is in the back side of router. then all settings goes to defaults. connect router to computer lan port with lan cable. then you can access it with default ip addresshttp;//192.168.1.1 or http://192.168.1.2 Type user as 'admin" and password as "admin" or "1234" or "password" or blank then you can see configuration page of router. Then configure it. Let me know if you need further assistance. Thanks for using FixYa.
Sep 27, 2011 | D-Link DIR-615 Wireless-N Router (54682G)
How i can reset factory my D-link firewall DFL-210
The easiest way to reset the firewall is hardware reset button. You can follow the following steps to reset the D-Link Firewall DFL-210
Hardware Reset button
Step 1 Make sure the unit is powered off.
Step 2 Press and hold the reset button locatedon the back of the firewall. While continuing to hold the resetbutton, power on the firewall.
Step 3 Continue to hold the reset button for 30seconds after the unit is powered on.
Step 4 Release the reset button and thefirewall will be at factory default settings.
Note: Only when the System light comes on solid will yourfirewall is ready for configuration.
For further information about reset through console connection and web configuration please refer here
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Jan 08, 2011 | D-Link Netdefend DFL-210 (DFL210)...
What is the default ip address for dlink 3226?
The Switch's factory default IP address is 10.90.90.90
with a subnet mask of 255.0.0.0 and a default gateway of 0.0.0.0.
Often set up by rs232 connection
See
ftp://files.dlink.com.au/products/DES-3226S/QuickInstallGuide/Generic_QIG_for_Managed_Switches_v1.03.pdf
and
http://support.dlink.com.au/Default.asp
Apr 20, 2010 | D-Link DES 3226 (DES-3226) 24x10/100 Mbps...
Unable to reset Dlink DFL 700 network firewall
To perform a factory reset using the reset button do the following:
Step 1: Make sure that the DFL-200/DFL-700 is on.
Step 2: Press and hold the button located on the back of the DFL-200/DFL-700 below the word Reset using a paper clip for 10 seconds.
Step 3: Release the button.
Oct 23, 2009 | D-Link NetDefend DFL-700 Firewall
Unable to map server to storage media over the internet for back
Virtual Private Network (VPN) endpoint and pass-through support. Additional firewall features include custom and policy-based filtering options. These options have to be configured properly.
Check your configuration level and access policy.
If its a public server you have to place it in DMZ.
Check IP settings of the server. U may require a VPN tunnel
Rate if this is helpful
Thanks
Good Luck
Jun 01, 2009 | D-Link NetDefend DFL-200 Firewall
I need to reset the password
reset the router to default settings by pressing on the reset button for ten seconds. (usually located at the back of the unit)
May 12, 2009 | D-Link DFL 500 (DFL-500) Firewall
DFL-260 Fierwall setting for Static IP
All of these info below are available in the owner manual that you can download here :
D-LINJK DFL-260 Firewall
You can either do it true command line or with the web interface.
Apr 09, 2009 | D-Link NetDefend DFL-200 Firewall
DFL-210, follow example to block web site
i have the same problem....try this
In order to enable port forwarding you need to create two rules on the DFL-210. The first rule is for service to Static Address Translation (SAT) and the second rule is for Network Address Translation (NAT) to Static Address Translation.
The first rule is created using the following steps:
  • Under Rules/IP Rules/wan_to_lan add a new rule
  • Under the general tabName = enter desired nameAction = SAT
    • Service = Select the desired service
    • Schedule = Select the desired schedule or None
    • Source interface = any
    • Source Network = all-nets (you specify a specific inbound address or range)
    • Destination Interface = core
    • Destination Network = wan_ip3. Under SAT tab
  • Under the SAT tab
    • check destination IP address
    • New IP Address = the address you want to forward to
    • New Port = the port you want to forward to
    • Create the rule by clicking OK.
The second rule is created using the following steps:
  • Under the general tabName = enter desired nameAction = Allow
Activate the configuration by using the Configuration/Save and Activate menu item.
posted.
Jan 06, 2009 | D-Link Netdefend DFL-210 (DFL210)...
I need configuration aid for the DFL-210
Dear Sir/Madam,
Please check this link for more details. It may be help you.....
ftp://files.dlink.com.au/products/DFL-860/Manuals/NetDefendOS_2.12_User_Manual_v1.05.pdf
Thanks
Don't forget to rate the solution
Mar 06, 2008 | D-Link NetDefend DFL-200 Firewall
D-Link Netdefend  DFL-210 (DFL210) Firewall Logo
2,158 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
