Question about Garmin StreetPilot C330 GPS Receiver
Garmin c330 won't power up on battery only
My c330 won't power up unless it is connected to a power source ie... usb or mobile base that is plugged into the car. The charging prompt works and it says that the battery is charged. It has the latest firmware update, not that this should make a difference. The unit is about 4 years old. Any ideas on this?
  • 728 Answers
My StreetPilot c330 ( 4 years old ) went dead and I can not get it to come back on. I have checked the fuse and pushed the reset button.
PULL OFF SILVER FACEPLATE AND A RESET BUTTON IS BEHIND FACE PLATE COVER PLUG UNIT UP TO POWER SOURCE PRESS RESET BUTTON AND THEN PRESS POWER BUTTON,YES BATTERY MAY BE DEAD BUT AS LONG AS YOU KEEP CONNECTED TO A POWER SOURCE IT WILL WORK.
MINE DID THE SAME THING I JUST KEEP CONNECTED TO CIG ADAPTER IN MY CAR.
Oct 25, 2009 | Garmin StreetPilot C330 GPS Receiver
My garmin c330 will not run it had said battery low. Even in car lighter it will not stay on. When I push the power button it will power up and shut down right away
The Garmin C330 has an internal Lithum Ion battery that needs to be recharged. Use your USB cable that came with the device to connect it to you computer. The computer of course has to be on. Leave it connected to the computer all day or over night. After that time it should be charged completely. If it is not charged after that time the unit will have to be returned to Garmin to have the battery replaced.
Apr 02, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin won't turn on or charge.
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 23, 2009 | Garmin StreetPilot C330 GPS Receiver
C330 can't locate satilite
You need to open up the Garmin and flip the metal thingie (above the battery place.
Mar 13, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin died and will not turn on
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
My streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Display image has shifted, difficult to use
ok, first you will have to unplug the power and usb cables to remove external power. Secondly, place your thumbnail in the groove located under the Garmin logo on the face plate and gently pull off the face plate. Next, press the reset button for three seconds. Finally, connect the c330 to a power source using the power cable. the c330 should automatically turn back on and operate normally.
Please rate my response and have a wonderful nite.
Mar 10, 2009 | Garmin StreetPilot C330 GPS Receiver
Power dors not transfer thru the connection between the wire and unit on my c330 , it appears that a little gold wire has broken in the rubber mount.
It took a nap...
Feb 18, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 gps will not turn on
try this just worked for mine
1.Under the face plate by the Garmin Logo.Use your thumbnail to remove the plate.
2.Press the reset button.
Information located on page 28 of the owners manual if you need a diagram.
Nov 14, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Battery
Pop the face plate off with your thumb nail right uner the Garmin logo. On the right side you will see a reset button. Depress it for 2 seconds. Replace face plate and power back on.
Nov 23, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
141 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
