Question about HP PSC 950 All-In-One InkJet Printer
Power issue I experienced a power surge and then outage yesterday. Hp 950 connected to surge protector but still now it just blinks. When I can get it to turn off it just blinks but power is not really getting to the equipment to get it to reset. I have tried to turn off everything and still no luck. I cant untinstall and reinstall because now my disk drive on the PC wont work either (Gateway windows xp) Any suggestions?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 82 Answers
Sounds like your power supply may be shot on your computer. You can get a power supply tester and check it. Not sure what to do about the printer. If you had a surge protector in between your computer and ac. Plug the computer and printer back in to the AC outlet directly and see if that helps. Hopefully only your surge protector is damaged.
Please rate, Thanks.
Posted on Feb 17, 2009
Printer will not turn on, checked adaptor it lights until i plug it into printer
Hi Gary Brooks, I would be happy to do all I can to help you with your C6280. I understand it will not turn on, and the adapter light is illuminate until you connect the cable to the printer. Please review the following document to ensure you have completed all of the necessary troubleshooting;
HP Printers The HP Printer Does Not Turn On or Respond When the Power...
Also, do you have the printer power cable connected directly to a wall outlet or is it in a surge protector or power bar? Even if you have been using a surge protector/power bar all this time and you feel it is not the cause, please connect it to a wall outlet just so we can eliminate the power source as the root cause. Issues when Connected to an Uninterruptible Power Supply/Power Strip/Surge Protector
In this document you will see, ISSUE: Problems or issues may arise when an HP LaserJet series printer is connected to an uninterruptible power supply (UPS), a power strip, or a surge protector
^ This is not limited to Laserjet printers.
I hope this helps. I work on behalf of HP.
Jul 18, 2015 | HP C6280 Photosmart All-in-One Printer...
Electricity came back on after power outage and the red LED blinks and goes of & there is no OSD
If your TV was not connected to a surge protector, it may be damaged. If you still have your warranty, check if it covers power surges.
Mar 02, 2011 | Philips 42HF7444T 42 in. Plasma TV
My sister in Charlotte, NC had a couple of seconds power outage, her processor, modem, monitor, tv and phone were connected to outlet thru a surge protector. All work except processor. Is there a reset for...
No reset for that processsor.. ALL Surge protectors are not guaranted for lightning strikes. Does she know if lightning hit the line that services her home?
Jul 13, 2010 | HP Pavilion a1540n PC Desktop
Blacked out screen
If the power light is blinking amber – The computer is receiving electrical power, but an internal power problem might exist.
Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
Ensure that the processor power cable is securely connected to the system board (see page 73).
flip off the surge protector and then flip it back on.
Jan 26, 2010 | Computers & Internet
Canon PIXMA ip4500 will not turn on
Sounds like the power outage was a power surge and destroyed your printer, especially if your printer was not plugged into a power surge protector strip. Check with others in your apartment to see if they experienced the same. If so, your landlord may be responsible and can put in a claim. If your printer is still under warranty, contact Canon. Also, check to see if this item is covered by tenant insurance, if you have coverage. Hope this helps.
Jul 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Hp laserjet3030 is put on it shows" Scanner Error"
Hi ritaccpl: Here is your problem. 52 Scanner Error The all-in-one has experienced an internal hardware error. 1. Turn off the power by using the power switch, and then wait at least 30 seconds. 2. If a surge protector is being used, remove it. Plug the all-in-one directly into the wall socket. 3. Check the FFC connection between the formatter and the scanner. NOTE Do not bend or fold the FFCs during the removal or reinstallation process. 4. Try connecting the product to a different power source or surge protector. 5. Turn on the power and wait for the all-inone to initialize. 6. If the error persists, replace the laser scanner assembly. Hope this helps
Jun 08, 2009 | HP LaserJet 3030 All-In-One Printer
My printer won't turn on after a power failure.
No, there is no reset button.
disconnect the pirnter from the computer and the power cord. press and hold the power button for 30sec. connect the power cord, and connect it back to the computer.
Dec 01, 2008 | HP Photosmart C3180 All-In-One InkJet...
Power outage, now pc will not power up at all.
sounds like the surge protector didn't protect. I would change the power supply.
Jun 12, 2008 | HP Media Center m7060n PC Desktop
No power
Unplug the tv press power on and plug it back in.
some of these units have a reset clearly marked on the back.
connect direct to wall as the surge protector may now have issue.
Jan 27, 2008 | Hitachi 60VX500 60" Rear Projection HDTV
Tv won't come on
Sounds like the typical power surge created by the outage has caused a power supply problem inside your TV. IF that is it, there not much you can do yourself.
Nov 07, 2007 | Televison & Video
HP PSC 950 All-In-One InkJet Printer Logo
120 people viewed this question
Seeker5211
Seeker5211
