Question about FIC IC-VG61 (dhicecube) Barebone
CPU Power, Changing to a lover voltage CPU
Hi im not sure so i thought id post a question , im currently running a Pentium 4 1.6 GHZ Willamette but i want to upgrade it to a 2.8GHZ Northwood CPU but i know those user lower voltages than the willamette processors so what im asking is if i install a lover voltage CPU will i adjust auto maticly or do i have to fiddle with the jumpers?? Many thanks Peter
  • crazycorvett Feb 09, 2009
    I've tried finding a bios update for my system (running on Phoenix award 6.00) and i haven't been able to find anything and hints on where i can find it?
    ok thanks m8 i will give that a try and get back to you if it fails may thanks Peter
  • FIC Master
  • 4,806 Answers
Hi there
Firstly update the bios, then install the new CPU, go into the bios settings and set them to default, that will auto adjust the computers settings, then you can have a look in the bios again to make sure the voltage is running as preferred.
Good luck and thanks for using Fixya!!!
Posted on Feb 09, 2009
  • Lee Hodgson
    Lee Hodgson Feb 09, 2009
    what you need to do is note down the make and model of the motherboard, go to the manufacturers support website and download the latest bios update from there.
    Good luck
I want to know what processor can i upgrade my pc with i got a HP pavilion desktop a705w
Well, you can see your computer spesification here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00255589&cc=us&dlc=en&lc=en&product=435558&tmp_track_link=ot_search
your socket is mPGA478, so it will be compatible with:
Celeron (Willamette) 1.5 GHz - 2 GHz RK80531RC041128 (BX80531P200G128) Celeron (Northwood) 1.5 GHz - 2.8 GHz RK80532RC072128 (BX80532RC2800B) Celeron D (FC-PGA2 package) 2.13 GHz - 3.2 GHz Celeron D 350 Mobile Celeron 1.2 GHz - 2.5 GHz RH80532NC060256 Mobile Pentium 4 processors (micro FC-PGA4 package) 2.4 GHz - 3.46 GHz Mobile Pentium 4 552 Mobile Pentium 4-M processors (FC-PGA package) 1.4 GHz - 2.6 GHz RH80532GC064512 Pentium 4 1.4 GHz - 3.4 GHz RK80546PG0961M (BX80546PG3400E)
RK80532PG096512 (BX80532PG3400D) Pentium 4 Extreme Edition 3.2 GHz - 3.4 GHz RK80532PG0962M (BX80532PG3400F)
Please Vote if you mind and thanks for using fixya!
Sep 12, 2011 | HP Pavilion a705w PC Desktop
I want to upgrade the current CPU on the motherboard to my HP Pavilion 760n.....what is compatible with?
Any Pentium 4 northwood or willamette CPU should work, when ordering your CPU make sure is for socket 478, you can use up to 2.80 Mhz speeds on that motherboard. you can get those on ebay for a good price.
Hope my opinion helped. :)
Jan 30, 2011 | Computers & Internet
Will I have any problems if I run 533 mhz with this board or is it better to say with 400mhz HP specification. My pc: HP pavilion 751n Pentium r 4 1.8 ghz willamette northwood 400mhz/256/1.5v I...
No, it will not work because the chipset can't support anything beyond 400MHz. You can see that yourself here
http://www.cpu-upgrade.com/mb-ASUS/P4S333-M.html
Jan 17, 2011 | ASUS P4S333-M (P4S333-M SA/LAN)...
HP Pavilion 751n Pentium r 4 1.8 GHz Ram: 1G DDR
you can use Prescott 2.4 it will suport .
purchase from bellow the link.
http://shop.ebay.com/i.html?_nkw=2.4+prescott+&_cqr=true&_ipg=&_nkwusc=2.4+preescort&_rdc=1
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
I have IBM p6 motherboard with processor Intel 1.8ghz/256/400/1.75v Processor had demaged. I replaced with Intel 1.8ghz/512/400/1.525v When I starts the system it gave error "0167 no processor bios...
I suggest this is not going to work.
1.Your motherboard is supplying 1.75 DC volts of electricity to the processor socket.
You have installed either a SSpec number SL68Q, or SL62P,
Intel Pentium 4 processor. (The sSpec number is on the top of the processor case)
These Intel Pentium 4 processors use 1.425 to 1.525 DC volts of electricity. If you haven't already, you are going to burn this processor up.
Also, the Intel Pentium 4 that you had before, is based on the Willamette Core. (180nm) These earlier Pentium 4's did not have HT.
Hyperthreading Technology.
The Intel Pentium 4 you have in it now, is based on the Northwood Core. (130nm) These Pentium 4's come with HT.
Even if you could go into your BIOS Setup utility, and change the CPU voltage, and lower it, the HT in the processor you have now, wouldn't work on this motherboard.
(CPU stands for Central Processing Unit. Another name is Microprocessor, or simply -> Processor)
You won't be able to lower the voltage in BIOS Setup, for this processor. IF you did, then you would change the Front Bus Speed, and the ram memory wouldn't work.
Solution?
Obtain an Intel Pentium 4 processor, that uses the Socket 478 processor socket, has a 400MHz FSB, and is based on the Willamette Core.
Here is a list of Willamette Core, Intel Pentium 4 Microprocessors, that will work,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#.22Willamette.22_.28180_nm.29
Apr 13, 2009 | IBM (25P3294) Motherboard
Cpu support
hi,
It will be supporting till 1.6 ghz pentium if u will put a processor from outside
Mar 03, 2009 | HP Compaq Evo D310 PC Desktop
Best/Fastest CPU for DFI PE21-EL mobo
Your motherboard supports 2 different fsb's.
look these up @ cpu-world
you can use:
Intel Pentium 4 processor (478-pin)
- 533MHz system data bus - supports up to 2.8 GHz
- 400MHz system data bus - supports up to 2.4 GHz
Intel Celeron processor
- 400MHz system data bus - supports up to 2.0 GHz CPU speed
and here are the suppoted cpus:
Intel Celeron RK80531RC029128 BX80531P170G128 1.7 GHz 17 x 400 MHz, Willamette Any A RK80531RC033128 BX80531P180G128 1.8 GHz 18 x 400 MHz, Willamette Any A RK80531RC037128 BX80531P190G128 1.9 GHz 19 x 400 MHz, Willamette Any A RK80532RC041128 BX80532RC2000B 2.0 GHz 20 x 400 MHz, Northwood A 1.525V not supported RK80532RC045128 BX80532RC2100B 2.1 GHz 21 x 400 MHz, Northwood A 1.525V not supported Intel Pentium 4 RK80532PC021512 1.5 GHz 15 x 400 MHz, Northwood Any A RK80532PC025512 BX80532PC1600D 1.6 GHz 16 x 400 MHz, Northwood Any A RK80532PC029512 1.7 GHz 17 x 400 MHz, Northwood Any A RK80532PC033512 BX80532PC1800D 1.8 GHz 18 x 400 MHz, Northwood Any A RK80532PC037512 1.9 GHz 19 x 400 MHz, Northwood Any A RK80532PC041512 BX80532PC2000D 2.0 GHz 20 x 400 MHz, Northwood A 1.525V not supported 2.1 GHz 21 x 400 MHz, Northwood A 1.525V not supported RK80532PC049512 BX80532PC2200D 2.2 GHz 22 x 400 MHz, Northwood A 1.525V not supported RK80532PE051512 BX80532PE2266D 2.26 GHz 19 x 533 MHz, Northwood A 1.525V not supported RK80532PE056512 BX80532PE2400D 2.4 GHz 18 x 533 MHz, Northwood A 1.525V not supported RK80532PC056512 BX80532PC2400D 2.4 GHz 24 x 400 MHz, Northwood A 1.525V not supported RK80532PC060512 BX80532PC2500D 2.5 GHz 25 x 400 MHz, Northwood A 1.525V not supported RK80532PE061512 BX80532PE2533D 2.53 GHz 19 x 533 MHz, Northwood A 1.525V not supported RK80532PC064512 BX80532PC2600D 2.6 GHz 26 x 400 MHz, Northwood A 1.525V not supported RK80532PE067512 BX80532PE2667D 2.66 GHz 20 x 533 MHz, Northwood A 1.525V not supported RK80532PE072512 BX80532PE2800D 2.8 GHz 21 x 533 MHz, Northwood A 1.525V not supported
Dec 26, 2008 | DFI PE21-EL Motherboard
UpGrade
you could only upgrade the processor and RAM in this condition i.e.
you can only change your an upgraded p-III processor like 1.0 GHz, 1.1 GHz or 1.3GHz and
upgrade the RAM by changing to 256 in each slot.
that is all what u can do with ur pc
Oct 18, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Compaq presario S R 1103 W M
what does it have currently? i know that motherboard can handle a 478 pin pentium 4 chips. they can be either willamette or northwood processors. i believe they made those lines up to at least 2.8 ghz. just go to newegg.com and look up pentium 4 and either northwood or willamette and you should find something you like.
if you need help installing, here is a helpful site provided by hp.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07139&lc=en&cc=pe&product=424182&dlc=es
May 27, 2008 | Compaq Computers & Internet
FIC IC-VG61 (dhicecube) Barebone Logo
151 people viewed this question
Top FIC Computers & Internet Experts
David
David
John Anderson
John Anderson
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
