Question about Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x
Toro 724 snowblower won't start
I have a toro 724 that won't start either manually or electrically.. I tested the electric start by removing it from the motor..... The flywheel is not turning when i try to start it.....seems to be locked up...
  • 1,902 Answers
One of two things will cause this. Either your piston rings have fried and your piston is stuck. The bearing on the flywheel is bad. Or actually one of thing, the crank shaft has broken. You willl need to take the motor apart all the way and see what is going on. If you take the flywheel off try to turn it by hand and see if you can turn it that wy. You also can try easier to check for first symptom is to make sure you are not in vapor lock. Remove the spark plug, turn unit upside down and see if you can get the motor to turn, if you can then replace the spark plug and it will start up. You can getvapor lock by running it low on fuel or the wrong fuel or running it to rich
Posted on Feb 09, 2009
I replaced the auger on my Toro 1800 electric snowblower and now the auger stops as soon as it hit the snow. How do I adjust the auger?
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Jan 08, 2017 | Toro Garden
My electric toro power curve 18" snowblower won't start.
I had the same problem. Stopped while using it. I discovered the black plastic cover over the motor was not properly seated all the way around which allowed snow to infiltrate the area. With all the moisture present it didn't take long for the carbon from the brushes to totally cake the copper contacts. Note all the ice present. After cleaning with a piece of emery cloth it's worked like new. Hope this helps those that are still having trouble. Take extra care to ensure the black cover is properly positioned before tightening the 3 screws.
20171230_115326-jxqihalonfbfbg4v1uc0cw0h-2-2.jpg Cheers, Ed
Mar 05, 2015 | Toro 1500 Power Curve Electric Snowblower...
Back fires when running at high speeds
if its older valves may be getting worn
but before you check valves
clean carb change the plug and put fresh gas in it
Feb 06, 2014 | Toro Snow Blowers. Power Max 724 OE 24 in....
My 418 ZE Toro snowblower won't start either manually or electrically. I need to empty the gas. How do I do that?
Easiest way is to pull the fuel line from the carburetor.
If you have not started it since last year and had the gas sitting in there. You need to clean the carburetor too.
Ethanol Gas ruins Carburetors on all engines. Tell your congressman to stop this Ethanol gas madness
Dec 15, 2013 | Toro Garden
Cannot start Toro 1800 snowblower (electric) inserted key, power connected...
Can you pull start it? If so,you may need a new starter gear,about $30,they're plastic & wear out.
Jan 12, 2011 | Toro Snow Blower Ccr 1000 Belt 715381...
How to change spake plug on powerlite snow blower
Remove the two screws holding the control panel to the machine. The spark plug is behind the panel.
Dec 23, 2008 | Toro Blowers Rake and Vac - Electric...
Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x Logo
1,517 people viewed this question
Top Tecumseh Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Tecumseh Tool and Hardware - Other Expert? Answer questions, earn points and help others
