Question about Hotpoint HSS25GFP Side by Side Refrigerator
Noisy Periodically my frig will run and make lots of noise (cycling really loud, then soft) , before it finally stops and is apparently at required temperature. The noise seems to be coming from the top freezer side. Otherwise, everything seems to be working OK.
    President:
  • 1,902 Answers
Check to make sure the fan is not hitting anything, if the fan looks good then on the back oof the unit is a relay, check that and make sure all is well. If both check out ok then I would get to work on the compressor and make sure it is not HOT to the touch and that it is operating correctly.
Please rate and let me know if you need more help
Posted on Feb 09, 2009
Fan noise loud and always present
If the fan is very dusty that an cause a lot of noise as it will be unbalanced. If the fan is on all of the time, maybe the bios requires updating. There may be a GPU issue and that will make the cpu run hot.
Jan 03, 2014 | Toshiba Portege R400-S4831 - Core Duo...
My avanti thermoelectric compact refrigerator periodically runs very loud which is not normal. If I hit it, it stops and runs quietly again. Any ideas? I have already cleaned the dust off thoroughly and...
The noise if from a sympathetic vibration of the unit which transforms to vibrate any loose joints, parts or fittings.
You will need to listen to the noise, use your hand to hold up the plastics or the joints in the bottom section of the unit or the frame work. It will require a lot of patience to find the source of noise. Pad it up after tapping for loose noise on the rear and insulate the noise heard till you finally get rid of any vibration noise..
Aug 30, 2010 | Avanti Compact Thermoelectric Refrigerator
GE side by side Refrigerator makes LOUD SQUEAK when running
Noise can come from these areas:
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Mar 24, 2009 | GE Refrigerators
Noisey compressor
Does it make the noise all of the time or just periodically? Does the outdoor fan run when it is making the noise. If the fan isn't running and the compressor is noisy at that time likely it is in defrost mode which is normal.
Jan 17, 2009 | Goodman CLQ36AR49 Air Conditioner
Danby washing machine noisy only during spin cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jan 13, 2008 | Danby DWM99W Top Load Washer
Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Nov 20, 2007 | Frigidaire FWS833A Top Load Washer
Noisy dishwasher
i have aloud buzzing nose and humming what is the problem
Oct 29, 2007 | Dishwashers
Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Jul 25, 2007 | Maytag Performa PAV2200
Hotpoint HSS25GFP Side by Side Refrigerator Logo
122 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Gil Shultz
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
