Question about Freezers
TOP PART OF FREEZER DOES NOT COOL, BUT BOTTOM DOES
THIS IS AN UNPRIGHT ONE COMPARTMENT FREEZER
MODEL# EV171NYMSO2 LO
SERIAL# EWP4702466
STAINLESS STEEL
ABOUT 4 YEARS OLD
  • richohashi Feb 11, 2009
    no, cannot see or hear top fan operating
  • Jeremy Reddick
    Jeremy Reddick May 11, 2010
    Can you hear or see the top fan operating?
    President:
  • 1,902 Answers
Then you need to look in the back of the freezer and check for the Far. Your fan does not seem to be circulating air through the system
Posted on Feb 11, 2009
Samsung refrigerator has 21 E code flashing
Freezer fan error. Most likely the fan in your freezer has stopped working completely
Jul 05, 2016 | Samsung RF260BEAESR 25.5 cu. ft. French...
Specs of tev for mccall freezer
you need model number and serial number . refrigerant type and possibly the compressor model number to determine the txv type and capacity
Nov 26, 2012 | McCall Refrigeration Commercial Freezer...
I need to learn how to control the tempature setting
The temperature controls are located at the top front of the refrigerator or freezer compartments.
The recommended setting should be correct for normal household refrigerator use. The controls are correctly set when milk or juice is as cold as you like and when ice cream is firm.
Wait 24 hours for your refrigerator to completely cool before adding food. If you add food before the refrigerator has completely cooled, your food may spoil.
NOTE: Adjusting the refrigerator and freezer temperature controls to a colder-than-recommended setting will not cool the compartments any faster.
If the temperature is too warm or too cold in the refrigerator or freezer, first check the air vents to be sure they are not blocked before adjusting the controls.
To turn Off/On:
Style 1 Press the freezer down arrow touch pad until a dash (-) appears in both the refrigerator and freezer displays. Neither compartment will cool.
Style 2 Turn the freezer control to the word Off. Neither compartment will cool when the freezer is set to Off.
Energy Saver option (on some models)
The Energy Saver option turns off the heater which helps to reduce moisture on the door hinge seal. The refrigerator uses more energy when Energy Saver is off.
Press the control to On to save energy when the environment is less humid.
Press the control to Off when the environment is warm and more humid, or if you notice moisture on the door hinge seal.
Adjusting controls
If you need to adjust the temperature in either the refrigerator or freezer compartment.
NOTES:
For Style 1 control, press the up and down arrow touch pads; for Style 2 controls, turn the dial to adjust the temperature.
Except when starting the refrigerator, do not adjust either control more than one setting at a time.
Wait 24 hours between adjustments for the temperature to stabilize.
Hope this guideline will helpout.....
Aug 10, 2010 | Traulsen Reach in Freezer - G22010
My chest freezer recently beginonly freezez a little at the top but it 's just cool like a fridge at the bottom
Hi and welcome to FixYa. I am Kelly. This freezer uses the chassis to dissipate heat so that the freezer can freeze. There is not a condenser fan. So what you have is a basic and usually trouble free freezer. If your freezer is not cold at the bottom of the unit there can be a couple of causes:
1. The compressor is running slow due to the rotor dragging on the compressor stator.
2. The PTC relay contacts on the compressor are getting hot and the compressor is shutting off before the temp control cycles the compressor off. Usually that is how PTC relays fail.. one hot contact and the unit cycles much more rapidly than usual and eventually the compressor stops running completely.
3. The system Freon has leaked out of the system and the unit is running on low pressure. (If this is the case the symptom will only get worse and very soon)
4. There is a very remote possibility of the cold control being damaged from an external bump by someone due to the fact that it is located outside the freezer compartment on the chassis.
Thanks for choosing FixYa. Kelly
Jul 09, 2010 | Magic Chef Chest Freezer MCCF5WBX
Refrigerator is not cooling
Good day,
You will need an ohm meter to check the parts.
Your defrost system has failed.
It is made up of 3 components, 2 of which are located behind the rear panel in the freezer compartment.
Remove the rear panel. There is a cooling coil, that has a calrod heating element that runs along it's bottom. As well there is a defrost thermostat ( a small round 1" disk) which is located on the top of the same coil. Both should be checked with an ohm meter to test for continuity. The heater should read no more than 30 ohms, the thermostat ( IT MUST STILL BE COLD BELOW 30 DEGREES) should read zero ohms. Note: The heater rarely fails, the thermostat has a high failure rate.
The third item is a timer, or a solid state adaptive defrost control. Depending on age, and model, it is located , behind the kick plate on the bottom front.
Or, in the fresh food compartment on the roof.
If it is a timer, you can turn the timer shaft when the machine is running until the machine shuts off. With it still turned on, wait 40 minutes.
If the machine turns itself back on, the timer is O.K. if not, the timer is bad, and needs replaced.
If the Main heater checks O.K. and it has a solid state control, then replace the thermostat in the freezer compartment, and the solid state board.
Below is an excellant tutorial on defrost systems.
http://www.appliance411.com/faq/howdefrostworks.shtml
Thank you for using FixYa
Jan 20, 2010 | Nor-Lake Freezer Norlake Refrigeration 6'...
Kenmore chest freezer does not stay below 30 degrees compressor runs but I don't see a fan to cool the compressor
If your chest freezer is less than 50 years old, it does not have a fan. Cooling coils contact inner walls of freezer compartment, warm coils dissipate heat through outside walls of freezer. If compressor runs, temp is 30+ degrees, gasket is OK, lid not left open, then you have one of two contions: 1. Low capacity compressor 2. Refrigerant leak. Solution to either is to replace freezer. (My opinion: Don't get a Kenmore brand, which generally ties you into poor warranty and slow and poor service.) No matter what brand name is on the freezer, it is most likely manufactured by Electrolux (in St. Cloud, MN) or Haier (from China). Look at the model / serial number plate before purchase to see where it was manufactured. Yes, the USA manufactured ones are better. (and I'm not just saying that because the plant is less than 15 miles from where I am sitting right now)
Jan 01, 2010 | Freezers
I need to order the power board of the freezer one door delfield/alco
Call Rick at Restaurant Parts and More. He can get you just about anything if you have model and serial numbers. Prices are reasonable and great service. Been doing business with him since '93 with out any problems. 1-888-814-1110.
Nov 20, 2009 | Delfield Freezer 6151XLSR Stainless steel
Bottom of refrigerator will not cool...while the freezer over freeze and packed with ice
What you have is a defrost problem. Most likely the defrost heater has failed. Read more about it HERE
May 16, 2009 | Frigidaire Freezer GLRT183TD
My Kenmore freezer, model #253.9280212 runs but will not cool below 40 degrees. It runs all the time but I do not hear anything cut on and off. The freezer is 10 years old but looks brand new.
The first thing to check is door gasket< bad corners,gap in side,bottom or top. Close door on a dollar bill and try to slide it top to bottom side to side and if it slides fairly easy then seal is not doing good. If you find dirty area clean it off along with the cabinet side as well.If you find the side is leaking then heat gasket with hair dryer and apply vasoline to gasket to help it move freely. If you find tear or hole then replace it.
Apr 22, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Bottom freezer door dripping water on kitchen floor
you can take a ook into the freezer sect its possible that the line has frozen, nad no longer is defrost water going into the drain but rather falling on to the floor of freezer and evnetually out the door
Jan 11, 2009 | Freezers
Freezers Logo
50 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
