Question about HP Pavilion zd8000 Notebook
Screen is dark
Screen went completly dark. Took battery out rebooted came on for a while and then went slowly darker until I couldn't see it. Everything is working you just can't see it.
HP Pavillion zv 5000
Any suggestions?
thanks
  • mrogers1691 Feb 09, 2009
    I just did and it works fine on another monitor.
  • 1,602 Answers
DID YOU TRY EXTERNAL MONITOR TO SEE IF IT IS A SCREEN ISSUE
ROD
Posted on Feb 09, 2009
  • ROD GANDY Feb 11, 2009
    check the driver and any updates
    device manager in control panal, also sync in control panal, in sync program our for plug and play devices.
    check the connector, if the monitor cable has the same amount of pins on the plug just switch the ends the of the cable where they were attached at,,
    rod
Has a black screen. The screen slowly went from dark to darker, then went to dark. I have a Hitachi CLU-572TSI projection tv
Not likely a do it yourself repair---loss of the filament voltage (6.3 volts) in the power supply of the set (some had issues where a resistor changes value).
May 05, 2012 | Hitachi 51G500 51" Rear Projection...
Screen is dark and pixalated
If u have warranty means then claim it.................
Jul 22, 2008 | LG 42PX5D 42 in. Plasma HDTV
I have an acer aspire 5630 it has worked well for nearly 4 years, about 4 months back I noticed that the screen would be dark and slightly reddish for the first 30 seconds to a minute after turning it on...
hi
try rebooting the system (i think its F8, to get to SAFEMODE) . in DESKTOP , right click and go to PROPERTIES, go to SETTINGS, go SCREEN RESOLUTION and take the arrow to the left ; set to 640x800 and and take the color setting to 256 drop down . hopefully this works after rebooting the system. if it doesnt, it may sound like the inverter card may be bad (PC bourd that connectes to the screen : this requires a service technician)
good luck !
Dec 09, 2011 | Acer Aspire 5630 Notebook
The screen on my Toshiba Tecra laptop has been flickering the past couple of weeks. Today, after using for about 5 minutes, the screen went completely black. I had to reboot to get the screen lit again. ...
Sounds like an inverter problem. If your laptop is still under warranty, send it in for repair. If not, and you know a little something about taking laptops apart, then you can take the screen a part and see the inverter behind the screen. It is long and skinny and has wires coming out of both ends, one side going to bulb, the other to the motherboard. Inverters are fairly cheap, and easy to replace... it's getting to it that is a pain.
Jan 03, 2011 | Computers & Internet
While using my gps 12, the screen suddenly went dark with just a narrow border of lit screen. batteries good. I can faintly see the pages behind the dark screen.
it turns out I inadvertently adjusted the screen contrast. This is adjusted by holding the left arrow key down after powering up, until the contrast is corrected. If the screen was completely white, holding the right arrow key down after powering up would bring contrast back into balance.
Nov 28, 2009 | Garmin GPS 12 GPS Receiver
Screens going dark
Wow you have a serious problem. Your LCD screen is losing power probably from a leak or bad wires or connections. If you stil have your warrenty, I would try to take it back.
Oct 16, 2008 | Nintendo DS Console
Solid Line Across Screen
Suspect the Light Engine part # 939P977010
Feb 21, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Screen went dark (almost completely)
check your power cord and make sure it's plugged in all the way, and if it is, check your brightness setting.
Usually it's the Fn key + an arrow key. Make sure the brightness is up all the way
Dec 12, 2007 | Dell Inspiron 6000 Notebook
Picture is getting darker and darker
The screen/focus block assembly has caused problems with this model in the past. Sometimes it can be readjusted, other times replacement is called for.
Jan 20, 2007 | Hitachi 51F510 51" Rear Projection...
HP Pavilion zd8000 Notebook Logo
149 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
