Question about Minolta DiALTA Di620 All-In-One Laser Printer
Error c-0072 minolta di 620 problem
  • Minolta Master
  • 6,359 Answers
Power off the machine. Then remove the toner bottle, be careful the hole might be on the bottom and the toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KNUB on the side of the bottle is damage put a new one in. That KNUB is what the toner motor uses to turn the bottle, if it damaged you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad.
Posted on Nov 22, 2015
4 Suggested Answers
SOURCE: minolta di520
es el pote fraSCO DEL TONER
AT THE TONER WHERE IS
Posted on Sep 30, 2008
SOURCE: scan with minolta Di 620 . Is there a way?
There were two minolta print controllers that came on the DI-520/620, which were the PI-6000 and then followed by the PI-6200. Neither of these controllers would allow you to scan.
You can however scan with the AHT or OneRip Controller for this machine.
So, to answer your question.............. Yes you can.
Posted on Jan 07, 2009
mr_kairo
SOURCE: Copier proplem
1. Reset the malfunction (i.e., turn OFF and ON the Power Switch).
or 2. If the same malfunction is still detected, check the EDH harness and, if it is okay,
change PWB-IB.
Posted on Jul 15, 2009
Minolta di 620 error C-13F0 SOLUTION required please
if you really need the solution then i tell you about icici lombard motor insurance plan.this is the policy who cover for all expenses and provide personal accidental coverage and more benefits also.go a head with this plan .click at icici lombard website.
May 12, 2016 | Minolta Office Equipment & Supplies
Error code c13f1
do you have the optional print controller installed? if not you would need to buy one.
Dec 21, 2014 | Compatible Minolta Di-520, Di-620 Toner,...
Solve the plroblem in di 620
The 13xx - printer engine malfunctions
13F0 -400 dpi SOS sensor detection failure.
13F1 -600 dpi SOS detection failure.
13F2-universal tray adjustment failure maximum.
13F3-universal tray adjustment failure minimum
13F4-optical system out of adjustment
Dec 15, 2013 | Minolta DiALTA Di520 Laser Printer
I have a Dialta Di-620 copier with an error code C-0540
i have a problem di620 code error c0540 please solve this thanks alote
Aug 23, 2011 | Minolta DiALTA Di620 All-In-One Laser...
I have a Minolta Di-520 thats giving a C-0072 error upon power up. What does that code mean and what do I do to fix it. Thanks, Jeremy Ky
Change the subtoner motor.Take up the development unit,and change the development,motor.Close /up the front cover and the problems resets.
Aug 07, 2010 | Minolta Office Equipment & Supplies
C1039 in di 620 power supply
Failure in Memory board according to the service manual all c10** and c11**
Apr 13, 2009 | Minolta Office Equipment & Supplies
Scan with minolta Di 620 . Is there a way?
Go to the website and search for the "TWAIN" driver for the relevant model
follow this link :
http://onyxftp.mykonicaminolta.com/download/Search.aspx?ht=
Nov 20, 2008 | Minolta DiALTA Di520 Laser Printer
Minolta Dialta620 copier error code c-0000
Code C0000 if a fuser motor failure.
Check to see if anything is damaged in the fuser (the thing that gets hot).
Also, check for a jammed transparency (if you use them).
Feb 10, 2008 | Minolta DiALTA Di620 All-In-One Laser...
Problem in networking minolta di 520/620
Jan 26, 2008 | Minolta DiALTA Di520 Laser Printer
275 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
