Question about Whirlpool Duet GHW9150P Front Load Washer
Won't spin on drain & Spin cycle. Works otherwise
It makes some strange noise if I put it on Drain & spin and it doesnt spin. Any ideas?
  • Kroseata Feb 09, 2009
    I hear that there's a drain filter on this model. Where do i find that?
  • Whirlpool Master
  • 19,396 Answers
The drain filter is attached to the drain pump.
To access to the drain pump on this model you need to open the panel at the lower (right hand) corner of your appliance.
Be prepared to get water flowing when you access the pump.
Filter is attached to the pump.
You can get some instructions here: whirlpool duet washer won't drain - Appliance Repair Forum.
It sounds like you you have a drain problem, but if the problem is not drain hose/pump/filter, then it is probably a defective control.
Let me know how it goes and give me feedback on this.
Thanks.
Posted on Feb 10, 2009
    Sergeant:
  • 326 Answers
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Feb 09, 2009
    Master:
  • 848 Answers
Hi
It sounds like the timer is causing problems. The timer controls the direction of the motor on this model of whirlpool. When timer contact 11B closes, this sends a message to the motor control board to turn the motor in the spin direction. You will need a volt meter to make some checks with. With the timer in final spin, check for 120 volts on 11B to neutral. If you do not get the correct voltage reading, I would recommend replacing the timer. Otherwise more testing will need to be performed; motor control board, wiring harness & motor.
    Brigadier General:
  • 3,614 Answers
Check the tub.
move the top up/down, if the tub move about 1 to 2 inches means that there was a problem on the bearing.
also check for any stuck object inside, this can also made the problem.
let me know
  • 153 Answers
Ball baring beneith the drum wil be fault
it can be somewat ruiened
    President:
  • 1,902 Answers
I would suggest that you check the pump out. It is on the bottom of your washer and if the pump goes bad it will bad a really horrible noise and will not let it drain. If that is good then I would check the timer to make sure that it is working ok. Both can be checked with a voltmeter and the washer powered on. Just please be careful, remember that you are working with live electricity so make sure you check things carefully.
  • 679 Answers
Seems there is some cloth sucks in the washer.check that.
  • rockfixya
    rockfixya Feb 09, 2009
    It's noisy--
    Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
    It doesn't spin
    If your washer won't spin, check these:
    let me know for further assistance.
    Thanks
Grinding noise in spin cycle
It sounds like the drain pump needs replacing, its bearings have failed or there is something from the wash jammed in it. But before you buy a new one, get the machine checked by an expert in case lots of parts are damaged.
Dec 20, 2013 | Whirlpool Washing Machines
No spin cycle
What is the model number of the unit?
Nov 14, 2012 | Samsung Washing Machines
Washer won't spin after rinse cycle
Hello Dorothy - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Sep 29, 2012 | Frigidaire FEX831CS Top Load Stacked...
Makes buzzing noise and won't spin or drain
Sounds like something is stuck in the drain pump.  If nothing is stuck in the pump replace the pump.  It won't spin until it drains, so fixing the drain problem will fix the spin.  You can get at the drain pump by taking off the bottom panel.
Dec 19, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer doesnt spin
as you said it does rest of cyle well. then the only problem can be faulty timer. may be in spin part of timer contacts are not getting on.
Nov 25, 2009 | Washing Machines
My kenmore washer Agitates but doesn't spin/drain
your help has arrived!
buy new timer! and install exactly the way you took out with the wires
Jun 10, 2009 | Washing Machines
Flashing F2
“F02” (Drain Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Is the drain hose kinked?
Is the drain hose frozen?
Is the drain hose clogged?
Is the drain hose more than 96" (2.4 m) above the floor?
After running this check list, plug back up and try a complete cycle using cold water and no detergent. Sudding can mimic a drainage issue as well. make sure you are using the correct HE detergent to prevent over sudding.
Feb 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Loud noise in spin cycle
Most leaks are associatd with your drain pumps although it can leak from the tub. If its the tube the seals in it are worn if it the drain pump - the first point to check is where the drain hose connecs to the pump otherwise you may need to replace the drain pump
The noise - if its what i am thinking of starts just as the spin cycle stsrts and just as it finishes - usually a clutch problem - worn - parts need to be changed.
Regards
Sep 20, 2008 | Frigidaire CWS3600AS Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
24 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
