Question about Westinghouse W33001 30 in. HD-Ready LCD Television
WESTINGHOUSE MODEL W 33001 GREEN LIGHT NO PICTURE OR SOUND
THIS TV DOES NOT RESPOND TO THE REMOTE OR KEYBOARD ON YHE SET. SEEMS LIKE MICRO PROBLEM , NO PICTURE OR SOUND SCREEN NOT LIT. WEHEN YOU PLUG IT IN GREEN LIGHT COMES ON.
  • npita2636 Mar 21, 2009
    Same problem here only sometimes when i unplug it and plug it it works either all night or 15 min
  • Anonymous Mar 16, 2014
    Toshiba 32sl415u
Unplug,replug,check to see the green light is now red,press remotepowerbutton,if this does not work the first time,try repeating about five or so times. i use the plug on the left underside of the tv itself,no moving the one ton entertianment center. this action resets the protect mode and relying on this may damage your set further. yet it works for me.
Posted on Jan 07, 2010
    President:
  • 1,077 Answers
It's posible your TV when into protection mode to prevent further parts from being damaged. This normally happens when a single parts goes bad inside your TV.
You may have to take it to a repair shop.
Posted on Feb 09, 2009
Our sharp tv model # LC-42D72U power light flashes green but there is no sound or picture. Looking for your expert opinion on what could be wrong so we can get the part ordered. The board with the power...
Green on light is blinking, but no picture - Television - iFixit
https://www.ifixit.com/.../Green+on+light+is+blinking,+but+no+pict..
iFixitOct 3, 2014 - The Sharp LCD TV LC37SB24U set worked until off button on remote ...The green light is blinking any time power cord is plugged into the wall outlet. ... It does sound like either a bad inverter board or a bad power supply. .... On the clad sidethere is no connections or ribbons that indicate hard current draw ...
Oct 20, 2015 | Sharp LC-42D72U 42 Flat Panel 1080p...
Used universal remote still have sound on tv but lost picture
follow this instruction and fix it. God bless you
No picture
  1. Make sure all power cords are connected.
  2. Try pressing the enter/play key.
  3. Make sure the TV is turned on and the input is set properly.
  4. Make sure the TV source is set properly on the TV (This is probably done on the screen; Check your TV manual).
Aug 01, 2013 | Westinghouse 16093 Remote Control
Mmitsubishi wd-73733 dlp green light flashing
This may help you if the set has the tiny recessed reset button on the front, those buttons (not the button itself but the tiny push switch under or behind it) do fail and trigger the set into the blinking green light of death--lots of techs call that.
Somewhere behind the speaker grill is a access plate, removed you will see the bundle of wires that come from the front keyboard---there will be a inline plug----Disconnect it.
Turn set on with remote--if it works the micro switch for the recessed reset button (its a joke as all it does is reboot the digital board) is bad---the remote will still work as the receiver is inside the screen unit. Leave it disconnected if the set works OR spend a few hours getting at the defective micro switch and remove it.
If the switch is bad they only sell (if its available any more) the whole pc board with all the controls on it.
Dec 22, 2012 | Mitsubishi WD-73734 73" Television
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
Westinghouse 33001 won't turn on power pack has green light could it be a fuse or a switch that needs to be reset?
The green light means the 5v standby circuit is working, yes it can be a fuse for the main power supply section that gets the control signal from the main board to turn on, so it can be the main power supply or the main control board.
Nov 03, 2009 | Westinghouse W33001 30 in. HD-Ready LCD...
BLUE LED LIGHT IS ON ALL THE TIME, NO PICTURE, NO SOUND. UNPLUG AND PLUG BACK NO CHANGE, REMOTE HAS NO EFFECT, CAN'T TURN OFF NEITHER AT REMOTE OR ON TV. SUSPECT LIGHTING STORM
I will need the model number of your set in order to help you out with it. Plaese respond to this same post with your model number.
Jul 09, 2008 | Televison & Video
Westinghouse W33001 30 in. HD-Ready LCD Television Logo
465 people viewed this question
Top Westinghouse Televison & Video Experts
Dave Naylor
Dave Naylor
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
