Question about GE WSXH208A Front Load Washer
Outer Tub Bearing
GE repair told that the outer tub bearing is shot; this machine is only 2 yrs old & I have washed light loads only. The few unbalanced loads I've had were paused so the wash in the tub could be evened out, seemingly not enough to wear out the bearing. I paid approx. $600 for this washer; my total estimate for the repair will be $1,333.63. Looks like we were taken 'to the cleaners' by a very expensive machine.
    President:
  • 1,902 Answers
Yikes, I would buy a new washer for that price. Also try calling another local appliance tech out and see his price on fixing the problem. You may also be able to fix it yourself but you will have alot to remove
Posted on Feb 09, 2009
Crosley washing machine making a clicking noise when I turn it on.. Machine won't do anything ?
(1) The tub bearing is mounted in the middle of the outer tub. The tub bearing helps to keep the inner tub spinning smoothly. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer. If the tub bearing is defective, i recommend replacing both the outer tub and bearing.
Jan 11, 2017 | Crosley Washing Machines
I have a LG front loader WD-1049C it's 6 yrs old And has just started to make a loud noise while in spin cycle All other cycles are fine
If the washer is making a loud noise the tub bearing might need to be replaced. This is a very involved repair and will require disassembling most of the washer. The manufacturer recommends that if possible the complete outer tub and bearing be replaced rather than attempting to replace just the bearing in the tub. If the bearing is bad the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine
Feb 19, 2015 | LG Washing Machines
During spin cycle, stainless tub makes loud noise and appears to be rubbing on outer tub front. what can cause this and is this expensive to repair?
Bearings in outer tub shot, couple hundred bucks for the whole rear tub then if you have ruined the front half of tub thats another 150.00 bucks .mite be best to get a new washer!
Apr 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hight pitch sound at the spin circle.
The outer tub bearing is worn out but the problem is it's not repairable or replaceable. Replacement of the complete outer tub assembly is required to resolve the noise problem. The outer tub assembly costs between $400 and $500.
Remove the rear access panel and allow the washer to spin then verify the source of the noise which is likely to be the outer tub bearing right behind the drum pulley.
Apr 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
Final spin loud noise out of balance??
sounds like your bearing is shot
is this a fridgedair?
does it sound like a 747 or freight train?
if yes might as well throw it away
I would say your looking at about 5-6 hundred dollars to repair
you will need the basket and outer tub
the reason is your bearing is compressed from the factory in your outer tub and your basket shaft goes through the bearing
and usually gets eaten up by the bearing
Feb 11, 2010 | Kenmore 43142 Front Load Washer
Looking for replacement bearings for the outer tub to inner tub on our Maytag FAV6800AWW, S/N 13389034ET. Don't want to replace the whole outer tub assy.
It sounds like you may have to replace the Outer Tub to replace the Outer Tub bearing .....ain't that just peachy.....good job Maytag design team.
If you are the original owner I would press Maytag hard to replace the Outer Tub based on the Outer tub Bearing failure. Their warranty states third thru tenth year Drive Motor, Outer Tub and Sealed Transmission. I’m sure you will need to have a certified Maytag repair service tech certify the failure and fix action required. Why should an Outer Tub bearing replacement cost you $430. Another poor design issue of this machine.
Sep 25, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Noisy when spinning
The noise coming from this machine as it spins is due to -- If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly  and the outer shell with the tub bearing.
Sometimes the inner basket support will crack, this can give an clicking or banging noise as well.
Pictures of this job...
A sure indication was the brown junk/gookus leaking out if the rear bearing area and the belt has spewed it around in the drum that the rear bearing and seal was bad...
Picture1 - Picture2
The whole outer shell and basket come out to do this repair....what bad bearing and rusted shaft looked like...
Picture1 - Picture2 - Picture3
I had to remove the back panel. Undo the pump hose & water level hose, remove the 2 shocks, remove the motor, undo the front boot from the outer panel and remove the 2 springs to lift the whole assembly out from the back to work on it.
Picture1 ( boot pushed inside ) Help page1 - Help page2
May 07, 2009 | GE WJSR2070B Top Load Washer
Made a loud noise and drum stopped moving
Picture1 - Picture2
May 03, 2009 | Hotpoint WMA40 Front Load Washer
I am considering purchasing a front load GE washing machine. I am curious if the inner drum and the outer drum are both metal? I am comparing the advantages of the GE front load with the Miele and the...
I can't speak for all, but my GE front loader has a stainless inner and a plastic outer tub. I don't know what the benefit of a all metal would be. The plastic outer tub seems to hold up fine, The only problems I have expereinced with the washer tubs were the bearing going bad after the seal failed, but its 10 years old. I consider that normal wear.
Jan 08, 2009 | Washing Machines
Grinding noise
The Neptune bearings are an interesting breed... Maytag wants you to replace the whole outer tub which includes the bearings installed for $180 or so. You can replace the bearings yourself. See www.tonytool.com to see how it is done. The tool costs $379 or so... but it is designed for the service tech. not the d.i.y.er. But watching the video can give you an idea of how to do it yourself. The bearings were available on www.neptunewaxmotor.com for about $35.00. You will also need the Maytag seal kit 12002022 to complete the job whether you decide to replace bearings or the outer tub.
Jan 01, 2008 | Maytag Neptune MAH5500B Front Load Washer
GE WSXH208A Front Load Washer Logo
210 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
