Question about Linksys Wireless-G WRT54G Router
LED #4 light is on-, though nothing connected
No cables plugged in, but the LED #4 is on (green) and I am unable to connect to the net. Tried to reset, nothing hapened. any suggestions?
  • 141 Answers
Call linksys tech support. Try upgrading the firmware. Try this
Posted on Feb 15, 2009
The led on the front won't light, and I have power connected, but nothing. Is there a reset somewere?
I am assuming you are trying to power up an installed motherboard, based on the category selection. You say that you have power connected. That means that you have connected the 20 (24) pin main connector and the 4 or 8 pin CPU power connector to the motherboard. Have you connected the front panels controls to the motherboard header? There are connections for the power switch, power LED, HDD LED, reset switch (optional). They must be connected in order for the motherboard to start. THe HDD and Power LED connections are polarity-based, so if you hook them upo backwards, their respective LED will not light. The HDD LED plug is usually red and white with the red being on the positive (+) terminal. The Power LED plug is usually green and white with the green wire going to the positive terminal. The power switch and reset switch wires can be connected either way as they are not polarized.
Jul 14, 2015 | Computers & Internet
Have had the N600 WNDR3400v2 installed for over a month and all worked well until yesterday. I have an internet connection and the router info says all is good, i cannot get it to connect. I've tried...
The blue light indicates the wireless network is working, it is just that nothing is connecting through it.
The internet icon should be solid green or blinking green which shows it is connected to the Internet, if not connect your ISP.
Feb 06, 2014 | NetGear WNDR3400 N600 Wireless Dual Band...
Emachines Will not detect ethernet cable
With the machine on and the cable connected on both ends (1 to computer and the other end to the Router or Modem that needs to be powered up) look where the cable plugs into your computer. Is there a green or orange light on. There may be two. Normally one that stays on steady is the CONNECT. This one is normally green color LED. When Data is being transmitted a second LED will be flickering showing data transfer. If you have no LED lights showing directly by the Ethernet cable, try another cable. Reminder: also make sure you have power on the router/ cable/dsl modem.
Hope this helps..
Nov 04, 2012 | eMachines T5062 PC Desktop
While installing the HP Photosmart Full Feature Software and Drivers from the HP website, power went out for a few seconds. When power returned the printer was off and will not turn on when the power...
Theres nothing in the drivers that would cause this unless the software was doing an update to the printers internal software
you could try a hard reset
1. Remove all cables, including:
2. Unplug the printer power.
3. Hold down # and 6 on the keyboard.
4. Plug the power cord back in. .
Mar 18, 2011 | HP Photosmart C6180 All-In-One InkJet...
Power supply pulled from working system about 1.5 years ago. Connected to the previous mother board. On board power LED solid green. Tried to power up, but the light just flickered very fast. Tried...
try 800W power supply? also make sure you connect the big flat multi cable plug and small 4 cable plug into the mother board usually on opposite side of the big plug
Mar 02, 2011 | ASUS A-55GA (A55GAATX550WAPFC) 550-Watt...
My DLink DI-604 router is not working properly. Lan port 1 I think is not working and only one computer connected to the router can connect to the internet. So I tried to remove all ethernet cables,...
Having an issue with your router or other equipment rented or purchased from Verizon Fios? Contact customer support service number 1-800-243-0019 for help. Our technical experts.
Apr 15, 2017 | D-Link (DI-711) Router
Front panel to motherboard, ASRock P4i65G, connections
the power switch is on the 3 and 4 pins....the 7 and 8 pin are the reset pins. Trying it on wrong pins just won't startup the board but won't short circuit anything.
Jul 28, 2009 | Computers & Internet
The screen is black even though the green light is on
try with another cable, pc if nothing. need to get service.
May 30, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Red light
System does not power on and the LEDs on the front of the computer are not flashing.
System unable to power on.
Press and hold the power button for less than 4 seconds. If the hard drive LED turns green, then:
1.Check that the voltage selector is set to the appropriate voltage.
2.Remove the expansion cards one at a time until the 3.3 V_aux light on the system board turns on.
3.Replace the system board.
Press and hold the power button for less than 4 seconds. If the hard drive LED does not turn on green then:
1.Check that the unit is plugged into a working AC outlet.
2.Open hood and check that the power button harness is properly connected to the system board.
3.Check that both power supply cables are properly connected to the system board.
4.If the 3.3 V_aux light on the system board is on, then replace the power button harness.
5.If the 3.3 V_aux light on the system board is off, then replace the power supply.
6.Replace the system board.
Jan 02, 2008 | HP Compaq Business d530 PC Desktop
Link light on the modem green or orange
the first 4 lights should be gree then the fith orange and should be flickereing on and off fast the last one should be doing nothing
Nov 23, 2007 | Arris SURFboard SB5120 Modem
Linksys Wireless-G WRT54G Router Logo
53 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
