Question about Canon ImageRUNNER 330s Copier
Imagerunner 330S - just received this copier as a donation (we're a small nonprofit). Machine claims there is a paperjam in paper tray and side drawer. Doesn't seem to be paper in either location. Any ideas? Thanks.
    Problem Solver:
  • 6 Answers
Check whether any sensor spring will open under stack bypass area, under toner area or under back panal fixing area or any short piece of paper in way of paper feeder
Posted on Mar 20, 2009
Obstructed copy
Typically when labels come off the paper, the get stuck on the Fuser (the heating rollers just as the paper exits the machine) Open up the printer and turn the round hand that you would clear a jam with, and look on the roller to see if they are stuck there.
They are also known to get stuck in the paper tray or pickup assembly. Follow the paper path through the machine and you will find them.
Good Luck
Jun 03, 2012 | Canon ImageRUNNER 330s Copier
How to add toner
Open the front cover. Towards the right side about half way down, there is a plastic lever. This will rotate to release the Developer/Toner Unit away from the Drum Unit. Pull the Unit outwards...it should stop before coming all the way out (unless someone has removed the stopper) Please use the correct type of Canon Toner as it fits on top of the Unit and unlatches Toner cover to add the toner. (Canon Type GPR-2). The instructions should be in picture format on inside of front cover.
Jun 10, 2009 | Canon ImageRUNNER 330s Copier
I have a canon imagerunner 330s copy machine. I'm
Hello sir;As your descript, it seems need to replace drum blade, if they come with whole cartridge then replace whole cartridge.
May 12, 2009 | Canon ImageRUNNER 330s Copier
Adding Staples Image Runner 330S
depednding on sorter im guessing its the small sorter with one tray the stapler is in the rear of the sorter green handle pull it out uses L 1 staples
Jul 24, 2008 | Canon ImageRUNNER 330s Copier
Canon Imagerunner 330s - Stack Bypass
you can select for tray (letter size ) as default in paper settings
the stack bypass paper sensor may be broken and is active all the time
Jan 29, 2008 | Canon ImageRUNNER 330s Copier
Canon imagerunner 5020
you have either a bad sensor or there is a small piece of paper on a sensor.
1-take out all trays ( or open and look from both sides ) look at where the paper feeds ( where the tires are) there is a small black lever if lifted will snap back in place, spring loaded. is there paper there?
next open copier put handle down, will bring transport with belts down, look to the right there are two long rollers and another sensor there or on the transport itself does it have paper or spring action?
next open left side where it gets hot ( good idea to do this one when cold) there is a sensor there usually on the door itself, next if you have a duplexer open and check the top and bottom of duplexer
next check sorter
if there is no paper anywhere bad sensor.
Oct 25, 2007 | Canon imageRUNNER 5000 Copier
120 people viewed this question
old marine
old marine
