FixYa.com
Tags:
GE Freezer  14.8 Cu. Ft. Manual Defrost Chest Freezer
Q: Making a GE freezer colder
By Phoebe - usenet poster
For the past few days my freezer hasn't been as cold as it used to be, so I am
hoping someone can tell me whether I have to raise the temperature in the
refrigerator to make the freezer colder. I can only find a dial to adjust the
temperature in the refrigerator, so this begs the Question: Is the dial in the
refrigerator for both the refrigerator AND the freezer? I don't have an
instruction manual. It's a General Electric, if that matters. I raised the
number on the dial inside the refrigerator to "6" around ten minutes ago, so do
I just have to wait?? Thanks so much.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 01, 2007
FixYa! (100)
Riddle
Riddle - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Thanks everbody. I set the dial on "7" which is higher than it's supposed to
be, and everything is back to normal on that setting. If I remember right, the
refrigerator food would freeze when it was set at "6" but so far it's working
like when it was set on "5."
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
lawyer
lawyer - usenet poster
Rating: 0%, 0 votes
Xahkdotyjdhhljl wrote
If it only has one dial, then yes.
At least 12 hours before you may notice a difference but that might
not be the cause of your temperature problem. You can read about
setting the controls on refrigerators at the following link:
If your model has a condenser fan (by the compressor), the condenser
(hot part) itself may be plugged with dust and dirt and/or pet hairs
causing the fridge to no longer operate properly. In that case
cleaning the condenser will allow the fridge to cool better.
Also, if your fridge is a frost free model (usually with a fan in the
freezer), there may be a problem in the defrost system in which case
the fridge will eventually stop cooling altogether. You can read other
possible causes for the fridge getting warm at the following link:
Dan O.
Appliance411.com
Solution #3
Not Rated (0)
kcw573
kcw573 - usenet poster
Rating: 0%, 0 votes
No model# posted.
Model# helps.
Normally yes...a higher number is colder, lower number is warmer. If
your refrigerator only has one dial/control, it should control both
sections. Should wait 12-24 hours after a control change to notice any
changes.
Some simple things to check.
jeff.
Appliance Repair Aid
Solution #4
Not Rated (0)
Cornish
Cornish - usenet poster
Rating: 0%, 0 votes
Yes you can, but that will not fix the problem. If the freezer has been OK
all along, but now had gotten warmer, you have another problem.
Most likely, the fan between the freezer and the refrigerator compartment h
as died. This is very common. It will still work, but most of the time the
freezer is not cold enough.
If it is a top freezer model, the fan is usuallylocated behind the back
panel of the freezer. Take everything out, remove the back panel, and see
if the fan operates while the compressor is running. You can lubricate it
and get another week or two out of it, but it will fail again. Just replace
it and be done with it. Last one I bought was about $20.
Ed
Solution #5
Not Rated (0)
Riddle
Rating: 0%, 0 votes
On 29 Mar 2003 00:01:35 GMT, (Xahkdotyjdhhljl)
wrote:
Sounds more like either the timer motor or the defrost heaters have
quit on you. You will in all likelyhood have to call in a pro for the
repairs.
...Ron
68' RS Camaro
88' Formula Bird
Solution #6
Not Rated (0)
pandamama
pandamama - usenet poster
Rating: 0%, 0 votes
I meant to raise the *dial* in the refrigerator, not the temperature. I got
confused because I raised the dial in the refrigerator from "5" to "6" around
20 minutes ago to try and make the freezer colder.
Can you Help with these Freezers problems?
Freezers
LBF6
unit has evaperater coil and... Answer This...
Freezers
Constantly running deep freezer
Our Gibson Model GFC15M4AW4... Answer This...
Freezers
turbo air freezer
i have a turbo air freezer 2... Answer This...
Freezers
Whirlpool chest freezer seems...
my chest freezer has a red... Answer This...
GE Freezer  14.8 Cu. Ft. Manual Defrost...
Small chest freezer, manual...
Stopped freezing. No compressor... Answer This...
Repair Service
Find Freezer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
