Question about Kenmore 63942 Dryer
Dryer won't heat.
New thermostat installed, dryer still won't heat.
    President:
  • 1,902 Answers
Check the glow ignitor and make sure it is glowing, if it is not glowing then replace it, if it is glowing then check the gas valve.. But sounds like the glow ignitor is bad and needs replaced, if it is cracked it wont work either so look really carefully, maye even pull it out.
Posted on Feb 09, 2009
Dryer says clean filter
Elizabeth, I can't answer your question until you provide more detail about the equipment and control thermostat. Brands, type, etc. If the "static" is too great, you should install a NEW filter. Turn the power switch off, then back on to reset the control and the thermostat.
Sep 18, 2017 | Filter Heating & Cooling
Maytag dryer heating element won't come on
you should have a nominal 240 volts between the 2 heating element connections
Feb 07, 2012 | Dryers
Electric Dryer starts and runs but won't heat.
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag Neptune MDE4000 Electric Dryer
Won't heat up
If it won't heat it will be either the heating element or the thermostat or the control board.
Aug 28, 2011 | Whirlpool GEW9250 Electric Dryer
Electric dryer won,t heat/replaced heating element last year,dryer worksbut won't hea
Hi galepezz...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Jul 25, 2011 | Kenmore 62602 Electric Dryer
Hi galepezz...
Check your Wiring
Jul 25, 2011 | Kenmore Dryers
Kenmore Gas Dryer 11072212101 won't heat. we
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101.,/
Jun 30, 2011 | Kenmore 73102 Gas Dryer
The dryer continues to heat after it is turned
Was this the reason you installed the element and thermostat? Or did it start doing that after you installed the new ones? Maybe you have the spiral element portion touching the metal encasing aroung it. The element has Line 2 to it at all times so the ground will provide a circuit even when all else shuts off. Check for any other ground issues.
Nov 02, 2009 | Kenmore 800 6983 Electric Dryer
Dryer will not heat
check high limit thermostat, operating thermostat and centrifugal sw on motor. voltage is always present going into centrif sw and is cut by motor stopping. timer feeds other phase going thru thermostats to heater.
May 03, 2009 | Whirlpool Dryers
Kenmore 63942 Dryer Logo
53 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
