Question about VIA MSI: MSI PT8 NEO-LSR P4 PT800 DDR400 Motherboard (MOTMS47)
Switching from 40GB IDE HDD to 500GB SATA HDD. SATA won't boot.
I have a VIA - PT 800-8237-6A6LXJ1AC-00 motherboard. I finished cloning my new WD 500GB SATA hard drive from a 40GB IDE hard drive. The new drive (H:\) has the files and is working, but I'm having trouble booting from it. Is there a jumper change needed?
  • parridl Feb 09, 2009
    My motherboard (VIA - PT 800-8237-6A6LXJ1AC-00) gives selection on boot devices. CDROM, HDD0, HDD1, HDD2, HDD3, LAN, SCSI, Floppy, LS120. I can't find the manual I got with the board or online (.pdf). I'm wondering if there's a jumper on the board that needs changing. Thank you.
    .......DP
  • VIA Master
  • 4,806 Answers
Hi there
No there is no need to change any jumpers on a sata drive, go into the bios settings and tell the bios to boot from the western digital drive only.
Good luck and thanks for using Fixya!!!!
Posted on Feb 09, 2009
How Do I exactly make a 500gb sata hdd work with this p4m266a ndmx motherboard? It doesn't appear to have a sata port and using the sata compatible cable did not help. Thanks
if your motherboard does not have SATA, purchase a SATA - PCI card, they cost something to the direction of 10 to 20 $ and give you 2 to 4 or more SATA ports.
Feb 12, 2011 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
Cloned hard drive "C" (WD 40GB) to A Deskstar 8oGB using external enclosure. When I remove the old drive and install new drive and boot up I get Msg drive 0 not found retry or enter setup. If I enter setup...
there are few thing you ahve to keep in mind
there are two type of hard disk
1. IDE
2. SATA
As per your hdd capacity it should of IDE type.
Now there are two IDE slots on motherboard. One is Primary and other is Secondary
You can fix two hdd with one IDE Slot that mean you can fix up upto faour IDE hdd at a time
Now again there are Primary master and Primary Slave
and
Secondary Master and Secondary Slave
Now You have to examine what was the location of previous hdd
1 Primary Master
2 Primary Slave
3 Secondary Master
4 Secondary Slave.
Now you have to make a HDD master or Slave.
just in between data cable connector and power cable connector there is a jumper. that specify the master or slave. do reply me if it works well thanks
Oct 01, 2009 | Hitachi Deskstar 7K250 80GB...
Can I transfer data from 250GB IDE HDD to a SATA II 500GB HDD
Yes you can. You may have to go in BIOS or and select your SATA as the first drive to boot off of though, else it might try to boot off the old IDE. But once you're in windows, it will appear as another drive in my computer.
Thanks and please take a moment to rate as fixya.
Dec 16, 2008 | ASUS A8N-VM Motherboard
HDD Installation
Hi gravni,
The bios (MUST see the drive). If the bios does not see the drive neither will windows!
The down below port (as you mentioned) is for IDE devices. IDE1 by name. Use your ATA IDE port for the slower IDE drives or cd-rom drives. (This board does not have a second IDE port).
If the WD drive is a SATA drive connect it to the SATA 2 port. See your manual. Go to page 1-4.
As show in this pic below.
2711d19.jpg Is the WD 500Gb drive SATA or IDE?
It's suggested when adding a new drive into a working system, the user should setup the drive by using the manufactures guide. Click on this link & download WD's pdf file:
http://www.wdc.com/en/library/sata/2079-001042.pdf
You mentioned the drive is hot. This only means it is running.
Include in this post the model number of your WD drive? So I can check the specs.
Mike
Oct 28, 2008 | MSI P965 Platinum Motherboard
1 TB HD of Samsng is not recognized
some motherboards and processors are compatiable with certain hd's only. Here is a list:
Pentium: 2GB through 5GB
Pentium 2:5GB through 20GB
Pentium 3: 20GB through 40GB
Pentium 4: 40GB through 500GB
Pentium D: 40GB through 1TB
Celeron: 2GB through 500GB
All AMD's: 300MB to whatever.
so, that's probably your problem. I suggest
Jun 05, 2008 | Asrock K7VT4A-Pro Motherboard
ASUS K8V-MX Motherboard with 250GB SATA HDD and 250GB IDE HDD Problem
Hi LP,
I’ am very familiar with ASUS motherboards. I am thinking you have posted two questions or more referring to the,
ASUS K8V-MX board. When you sign into you're FixYa account you than need to click on you're profile. Within you're profiles are the questions you have posted. Click that question to add or see the expert's answer. If you need another question (about the same item) re-post within that same question. You can even copy the link to an older post & past that link into you're next question. (Than I can read you're last question & my responce).
LP you have me all mixed up. I'll answer the question you have posted above. In the future please provide you're old post so I understand better.
There is nothing wrong with IDE 250GB drive or the SATA drive.
The problem you are haveing is setting the correct settings.
The ASUS K8V-MX can support two serial ATA SATA drives. The SATA drive's can only run at 1.0 version. 1.5GB transfer speed & not SATA II, the 3.0GB speed.
How to setup the SATA drive?
Please disconnect any other drives (IDE) & a second SATA drive that may be connected to the system. Except the CDROM drive.
Using you're manual the SATA drive should be connected to SATA1 port. Page 1-24 in you're manual.
Put you're windows CD into you're CD-ROM drive & boot the PC. You will see, Press any key to boot from CD... (press any key on your keyboard). Windows will start to install. Durring installation of windows the system will restart. You will again see, Press any key to boot from CD... (DO Nothing)!
Just allow windows to conintue on its own. Windows will continue to install it's self. This will happed once again, & again do nothing. Windows will finish installing it's self.
After windows has finished, load the ASUS CD into you're CD-ROM drive & install it's driver software. Restart the PC.
You must register windows. Do so.
Than update windows through windows update service. (This will take some time to complete). (Do not install service pack 3).
If you have an IDE drive 250GB in size & you installed windows on it. You must erase the drive or it will conflict with you're new installation on the SATA drive. To do this, look on the IDE drive & you will find a large white sticker. Printed on there is instructions of how to set the drive pin. Set the drive up as a slave drive. (This is only temporary).
Power off the PC & unplug the power cord. Connect the 250 IDE drive's power cable & data cable. Plug in the power cord to the PC & turn on the PC. Windows will load. Right click once on the start button & slide up to & left click on Explorer.
Find the 250 IDE drive, it should be drive letter D or E. Right click the proper drive letter & format the drive.
( Do Not format, Local_Drive C:\ ). Once the format is complete, power down the PC by clicking on the start button & click turn off the computer. Once off, unplug the power cord. Change the pin on the 250GB IDE drive to Master with a slave. Take the 40GB drive & change it's pin so the 40GB drive is a slave.
Connect the 250GB drive to the end of the IDE data cable & connect the 40GB drive to the next connector of the same IDE data cable. Re-check all power cables & data cables for good connections before closing the case. Plug the power cord in & power up the PC. Everything should run just fine.
Setting the pin for you're IDE drive's can be very confusing. Click on the link below. This will give you an idea of how to set you're pin for a master drive, master with a slave drive. If you post the name ST****** of you're two drives I can post the correct pin locations from Seagate's web site.
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
Have more questions about this post?
Mike
May 21, 2008 | ASUS K8V-MX Motherboard
Connecting an IDE HDD to a SATA port using an IDE to SATA converter
Not complete product...need to buy additional adapter for IDE to SATA power source.
IDE drive will have to have the power source hooked up as well as the adaptor hooked up.
Installing the adaptor only will not work. Your computer should have the 4 pin plug for the power to the IDE drive, other wise you will have to buy another adaptor.
Mar 23, 2008 | Intel Motherboard
NI8 SATA DVD Drive compatability
You must have added the SATA drive after setting up the IDE. If both drives are using the same os this will not function. Ony one drive can have the os on it. All SATA's are seen as a master.
To correct this problem, disconnect the IDE drive. Hook up the SATA drive. Again if the SATA has the os on it everything will run. Change the jumper on the IDE and set it as a slave. Hook the IDE up. Enter the bios & do not list the IDE in the boot to section. Problem solved. While in windows, format the IDE drive.
You do not want windows thinking you want a dual boot system.
So you understand, in the bios -boot settings this is how things should be listed.
Boot device 1 Sony Optiarc DVD drive
Boot device 2 WD raptor SATA, In-stall your os to this drive
Mike
Mar 22, 2008 | Abit NI8-SLI Motherboard
Primary hdd(SATA) appears as removeable storage
There is no problem about that because my system here was all removable storage detected.its thesame (SATA) ..If try to safely remove that you cannot remove because it was use by the system so don't worry about that.
I encoutered that problem 35 times already.
Jan 17, 2008 | Abit NF-M2S Motherboard
VIA MSI: MSI PT8 NEO-LSR P4 PT800 DDR400 Motherboard (MOTMS47) Logo
495 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
Abhinandan  Patil
Abhinandan Patil
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
