Question about Honeywell Programmable Thermostat Heater
Baseboard heater problem
I get a loud clicking noise when the baseboard heater cuts in. Why?
    President:
  • 1,902 Answers
Sounds like you have spark ignition, and possibly your spark ignitor module is going bad and needs to be replace, could also be your thermopile or thermocouple going bad. If you open the door you will be able to see what is going on. If you see spark and it looks like it is pretty strong, then I would make sure everything else looks ok
Posted on Feb 09, 2009
My Jandy lite 2 natural gas heater has a loud clicking noise. It fires up and heats my pool nicely. My problem is.... as it is heating there is a loud clicking noise from the gas valve area. It acts a
make sure pressure switch is good and wires are tight sounds like pressure switch cutting in and out opening and closing gas valve also make sure wires to gas valve are tight
Apr 10, 2013 | Jandy Laars Lite 2 Pool Heater 250,000 BTU...
How to wire unit baseboard heater to the power to thermoster
That is a portable unit and should not be hard-wired and controlled by a wall-mounted thermostat. The unit may never cut off that way.
It is considered a "space heater" not an area heater.
===sorry===
Sep 14, 2009 | Fahrenheat PHH15002 Oil Filled Baseboard...
Heater is excessivly noisy, can be heard over tv
first, my research into the Cadet model #09954 is a 240v unit. if it is wired to only 120v that may be your problem. I am not even sure it work work on 120v.
Feb 11, 2009 | Cadet Manufacturing 09954 Baseboard Heater
Fahrenheat baseboard heater
no this is normal for this type of heater during its run time,I hope this makes you feek a little better!
Oct 24, 2008 | Fahrenheat Built-In Baseboard Thermostat...
A buzzing noise
Why do you say put in line to stop the buzzing? What is it that tells you the wire is creating the buzz?
It could be anything from a loose sheet metal part, rivet, fan, transformer, loose connection, or just the way it was built, although a loud buzz sounds like a problem waiting to happen to me.
No there is nothing to put in line to make it quit buzzing, I need to know all the information about the device, voltage, amps, brand, and then tell me how it is wired including number of wires, size of wires, voltage, how it is wired to what colors, how far from breaker, what breaker and size, and anything else that seemed unusual to you during install if anything.
Write me back here or allexperts.com or wbwill@sbcglobal.net.
Oct 24, 2008 | Fahrenheat Electric Convector Baseboard...
2000 watt baseboard heater is making loud clicking noise
Most base board heaters installation instructions say to attach to the wall with screws which are slack ( not fully tightened) in order to allow the heater case to expand and contract otherwise you get a clicking noise
Nov 17, 2007 | Heating & Cooling
Loud humming
If this is an electric resistance heater then there is no power supply or transformer. I had a baseboard heater that would hum loudly and I found there's a wire that runs along the bottom to connect the far end of the heat element to the electrical wiring at the supply end. This wire becomes magnetized from the current flowing through it and vibrates in the channel it runs through. I was able to open this channel and squirt a bit of silicone caulk in to keep the wire from vibrating and the hum is gone.
Dec 19, 2006 | Honeywell HZ514 Baseboard Heater
Heating & Cooling Logo
159 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
