Question about Lexmark Wheelwriter 3500 Typewriter
Code 215 The typewriter does nothing but display a little box with a slash thru it and the numbers 215. It does not make a difference if you power it off or unplug it, it continues to display that error code on the screen. I tried pressing and holding code key while pressing "L" release "L" and type 001 release the code key, but the error remains unchanged on the display screen; Could that also mean the keyboard is bad? Or can I simply throw out the old thing and tell the woman in that dept. to get with the times ;-) In any case, thanks again for your assistance. Unit was not typing full characters, found that platen was not fastened down correctly. When platen was secured, started getting 215 error. Unit does not initialize, wheel spins, carriage attempts to travel to left side but seems to stall, that beeps and displays the 215 message.
  • SweeneyJJ Feb 09, 2009
    Unit is a Lexmark Wheelwriter 3500.
  • SweeneyJJ Apr 02, 2009
    Changed print wheel, no help. Cleaned out area, no help. Finally had unit serviced and I believe they replaced sensor - now works fine.
  • 1,031 Answers
Its a printwheel problem.Remove P/W check for debris or durt in that area if you have compressed air blow this area out. If this dosen't work you probably have a bad sensor.
Posted on Feb 09, 2009
  • 679 Answers
It seems a  keyboard problem.
Try--
and type 001 release the code key.
let me know for further assistance.
Thanks
    Master:
  • 848 Answers
Hi
probably you have a bad sensor ........need to replace it .........
    Brigadier General:
  • 3,614 Answers
What exactly the model of the typewritter
  • 1 more comment
  • micromaster
    micromaster Feb 09, 2009
    for initial help, better clean the unit, for any dirt that stuck in it that blocking the parts inside.
  • micromaster
    check also the print wheel for any abnormal movement or any damaged
  • micromaster
    let me know if the one of my posted solution was done!
IBM Wheelwriter 30 Series II is showing an error code of 215 with a box with a slash through it and am unable to type on it
215 is a Print Wheel error. Remove the print wheel, look for debris in the P/W area, if you have a compressed air source blow the P/W area out. If these don't work the P/W sensor is probably bad.
DickyO
Sep 07, 2011 | IBM Wheelwriter 30 Typewriter
I have an IMB Wheelwriter 30 Series II. When I turned on the machine this morning it made a couple of ringing sounds and then on the display it reads a square with the number 215. Nothing else works on...
215 is a printwheel error. Remove the P/W, look for dirt or debris in that area, if you have a compressed air source blow out the P/W area. If these fail the P/W led sensor is probably bad.
and you most likely need a tech.
DiclyO
Sep 06, 2011 | IBM Wheelwriter 30 Typewriter
What does a box with a slash and 215 mean? we can't find our manual and I need to type diplomas for graduation today
215 means that the T/W isn't seeing the printwheel. Remove the P/W. look for debris in that area, blow some canned air into that opening, be sure the P/W is fully installed. If these don't help the LED is probably Bad.
DickyO
Jul 03, 2010 | IBM Wheelwriter 30 Typewriter
In the display box there is a box w/ a slash through it and the number 215 following it. everything seems to be locked up - what do I do?
The book says bad keyboard. Try unplugging and repluggin the 2 keyboard ribbon connectors. If that fails contact Geo. Beyers Co. @1-800-392-8085 for a rebuilt keyboard.
DickyO
Aug 17, 2009 | IBM Wheelwriter 30 Typewriter
IBM WHEELWRITER 30 SERIES II
I believe a 215 code is a bad printwheel sensor. You need a tech.
DickyO
Mar 05, 2009 | IBM Wheelwriter 30 Typewriter
IBM wheelwriter 25 message: a box and diagonal line thru it and the number 215.
Code 215 is a printwheel error. Remove the P/W and look for debris in that area, if you have some compressed air source blow this area out, if this dosen't do it the P/W sensor or the LED are probably going bad.
DickyO
Nov 01, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Series II Typewriter 6787
The book says turn the T/W off wait 30 seconds and restart, if condition returns call for service. However you might try removing the batteries and unplugging the machine waiting a few minutes and restarting. CAUTION ALL THE MEMORY WILL BE LOST!
DicktO
Jul 16, 2008 | IBM Wheelwriter 30 Typewriter
Code 215
I don't know where you are but if tou can get it to us we will give you a free estimate. We are in Cleveland Ohio
bizmach@earthlink.net
DickyO
Apr 01, 2008 | Lexmark Wheelwriter 3500 Typewriter
IBM WheelWriter 3500
Try pressing and holding code key while pressing "L" release "L"
and type 001 release the code key. If this solves the trouble but it comes back on the next power up the keyboard is bad.
DickyO
Mar 25, 2008 | Lexmark Wheelwriter 3500 Typewriter
Lexmark Wheelwriter 3500 Typewriter Logo
53 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
