Question about Casio FX-115ES Scientific Calculator
Can't get rid of DEG in calculator display
I have just bought this calculator Casio FX-82 Solar Fraction at a jumble sale and have been playing around with it. Now, whenever I start it up it shows DEG in the display and I can't get rid of it. Is it supposed to do this? If not, what can I do to put it right? I am wanting to put it on Ebay!
I'm not technical, so if you know the solution, please keep it simple, thank you.
  • madasaballoo Feb 09, 2009
    Thank you very much. Casio forum sorted it - it's not a problem, it's normal.
  • madasaballoo Feb 11, 2009
    This is a rechargeable calculator with a solar cell. No batteries.
    I went to the Casio forum and they sorted it, thanks.
    I posted this on Feb 9th, above. But thanks for trying.
  • 1,602 Answers
GOTO CASIO WEB SITE, COASIO USERS GROUP OR CASIO FORUM.
CASIO.COM OR CASIO.NET
Posted on Feb 09, 2009
  • ROD GANDY Feb 11, 2009
    remove the batteries and put them back in a few minutes
    rod
    maybe the wrong type of batteries installed in the calculator, take it to radio shack and try alcaline and non alcaline batties,
    maybe on of the memory functions for that calculation forumula tool is locked into the memory save, one of the keys maybe mc memory clear, the other two memory is[M-], memory key is MR,
    clear the field, check the science keys memory, may of go turned on by accendent and this is why you found it for sale becuase of the same issue or problem turning it off.
    ************IMPORTANT INFORMATION FOR YOU*******************
    THE DEG REFERS TO DEGREES FOR SOLVING AND ANGLE.
    I WENT ON INTERNET EXPLOLER AND TYPE IN THE FOLLOWING INFORMATION.
    WNEN I TURN ON MY CALAULATOR IT SAYS DEG
    and that is how i found your information for you
    or
    display deg when i turn on my calculator
    good luck
    rod
How do I clear "DEG" from display?
You can switch between Rads/Deg/Grads. Deg is the one you want to use. So, to answer your question, the "DEG" is suppose to be there so that you know what mode you are using. If you don't have the manual, here it is:
http://support.casio.com/pdf/004/fx82SOLAR_E.pdf
Nov 11, 2014 | Casio FX-260 Solar Scientific Calculator,...
What does E mean
The Casio fx-300ES doesn't have a button marked "E" (at least not on mine). On some calculator models a button marked "E" is used for entering exponents of ten.
If you mean the one marked "e" then this gives you the value of Euler's constant e.
Mar 19, 2013 | Casio FX-300ES Scientific Calculator,...
I am using my Casio fx-300MS and have somehow gotten into the display where it puts my answers in exponential form; 5+5 = 1.0 exp10 to the 1. How do I return to getting my answers in standard form?
Display Format
To change the exponential display format, press the [MODE] key 3 times.
Fixed number of decimal places:
Press 1: Scientific Notation: 0
Press 2: SCI: 0
Press 3: NORM
You will then be prompted for NORM 1 or NORM 2. CHOOSE NORM 1
To return the calculation mode and setup to the initial defaults, press [SHIFT] [CLR] [2]
[=]. This will return the calculator to the following settings:
Calculation mode COMP
Angle unit Deg
Exponential display format Norm 1
Fraction display format a b/c
Decimal point character Dot
Percentage Calculations
Apr 13, 2011 | Casio FX-300MS Calculator
My daughter is starting 6th grade and they have asked her to get a T1-30XA or TI-83/TI-84, she is not advanced in math. Which on would you recommend ?
The Ti83/84PLUS are a lot more advanced than the TI-30XA because thaeu can graphs, statistics, calculus etc. But they lack a key for the % function, and a key for the fraction manipulation, the angle unit conversions (deg, radians, et grads) and they are a lot more expensive than the TI30XA.
Before your daughter finishes high school, you will eventually have to buy her a graphing calculator but right now a TI83/84Plus calculator seems like overkill. Besides some teachers may not let students have graphing calculators during exams.
Honestly I suggest you buy the TI-30XA Solar version. There are some new nifty calculators manufactured by Casio (Casio FX-115ES, FX-991ES, FX-300ES), Sharp (El-506W, 516W ). The beautiful thing about these new kinds of calculators is that you can configure them to use the Textbook display: equations and expressions can be entered as they would appear in textbooks. The Casios are called Natural Display and the Sharps are know as WriteView models.
In fairness to Texas Instruments, they too have calculators that incorporate that display format but I do not know the exact model numbers (maybe TI34XII multiview).
Aug 20, 2010 | Texas Instruments TI-30XA Calculator
DEG mode
The DEG indicator has absolutely nothing to do with division, fraction or other operations. It is relevant only when you are calculating trigonometric functions (Sine, Cosine Tangent and their inverse functions.)
When you are calculating trigonometric functions the results depend on the angle unit the calculator is configured for
DEG >> angle values are in degrees.
RAD>> angle value are in radians
From the equivalence 180 deg =Pi radians you get
1 rad= 180deg/Pi=180 deg/3.14..=57.29577951 degrees.
The DEG indicator merely reminds you that angles are in DEG. If you change the unit to RADians the RAD indicator will be displayed instread.
Apr 15, 2010 | Casio FX-260 Calculator
Does the fx-260 SOLAR do exponential calculations?
Yes it does. All scientific calculators do logs, power, roots, exponential, trigonometric functions. Most do also hyperbolic and inverse hyperbolic functions.
Hope it helps.
Aug 16, 2009 | Casio FX-260 Calculator
Unwanted letters DEG show on Casio FX-100A display
No!! deg mean degree the system of answers you get, you can change it to rad=>radians but you never get rid of them. Sorry :(
Jan 11, 2009 | Casio FX-300MS Calculator
Casio FX-115ES Scientific Calculator Logo
1,772 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
