Question about Crosley CDG6000 Gas Dryer
Crosley Gas Dryer-small plastic object fell into blower (?)
Help, I have read the other psot about chapstick being dropped there by another poster, and I tried a vacuum, a wire hanger with tape at end, etc and all it did was jar the object loose, but dryer is still making a horrible noise and can't be used. My users manual does not show how to get inside the dryer via a panel and I have looked all over the different sides of the dryer for a way to get in and get the piece (it is a cap to a bleach pen that fell down under the lint screen). Can someone tell me how to access a panel or what else I can do to get this item out? I am running out of clean clothes...help.
    Problem Solver:
  • 8 Answers
You might have to take the back off then off to the left take the screws out of the blower houseing and carefully pull it apart and then you should be able to take what ever is in there out
hope this helps
please rate this help
Posted on Feb 12, 2009
DRYER MAKES NOISE WHEN DRYER TURNED ON SMALL PLASTIC PEICE FELL INTO DRYER LINT CATCHER
it may have worked its way into the b,lower. u have to remove cabinet and then remove blower cover and try to find it.
Aug 27, 2014 | Kenmore 500 6952 Dryer
Small toy accidently fell down dryer vent. What to do? Afraid to turn dryer on. Help
To get to where the toy fell on this unit is a little involved. Unplug unit. take out the lint filter and gently turn the machine upside down hoping the object will fall out if not you will need to take the back off the unit and loosen or remove the blower chute to get at the blower wheel and your missplaced object
Good luck...
Aug 10, 2010 | KitchenAid KGYS700LQ Gas Dryer
Kenmore 80 series dryer, no heat. blower works
Check to see if the glow bar is coming on first. If it isn't, it is probably the thermal fuse/ cutoff. It is a small white plastic piece on near the motor housing.
http://www.partselect.com/PartDetail.aspx?Inventory=345113&SourceCode=6
or
http://www.partselect.com/PartDetail.aspx?Inventory=344958&SourceCode=6
If it is coming on but not lighting the flame, then you probably need gas coils. They are the two cylinder shape black and white objects attached to the gas valve.
http://www.a-1catalog.com/gasvacokit2.html
Jan 15, 2010 | Kenmore 73952 Gas Dryer
Dryer is not heating enough to dry clothing. The problem started with the electric braker box switch triped i had to replace it, dryer would turn on but no blower, I took a look at it and found some...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
87gh
Dec 09, 2009 | Estate TGDS740JQ Gas Dryer
A chalk piece fell into the lint trap keeper of our Kenmore dryer.We our concerned whether we can use the dryer or not,because we haven't been able to take it out. Thanks Amy
Try to vacum it out from the top ...
If not - pull the drier out and try to get it from the exhaust port. If your hose is plastic, please replace it with an aluminum one.
I just posted similar instructions for another poster if you would care to review them
I hope this works for you.
a
Sep 25, 2009 | Kenmore 73952 Gas Dryer
Dryer doesnt work
I am an authorized crosley repair man. The fuse mounts on the rear wall on the right hand side of the heater element. When it blows the problem is usually a ball of lint in the filter housing or a bad blower wheel.ba7d2fe.jpgThe kit comes with 2 fuses. One for gas and one for electric dryres. Use the fuse with the same color dot as your old one. DEAD DRYER
Apr 12, 2009 | Crosley CDE6000 Electric Dryer
I have a Crosley dryer and I need to know the size of overheat protector for model number CDE22B7BC. The dryer had a faulty overheat protector as I had it checked by a serviceman but he thinks it may need...
The electric heater fuse takes a 300 degree limit. Pink dot6885cfc.jpgThe kit comes with a 250 degree for gas and a 300 for electric. many people have told me either one would work and many folks have said when the 300 degree poped they have used the 250 till it too dies.Keep the dryer clear of lint and regularly checked for lint balls and striped blowers to keep this problem at bay.
Jan 12, 2009 | Crosley CDE6000 Electric Dryer
No heat
ck thermal fuse on rear of dryer remove rear cover small white object on blower housing is fuse ..if it is bad ck air flow to ouside of house and at dryer oulet if low air volume ck for restriction
Sep 04, 2008 | Kenmore 74602 Gas Dryer
Dropped a chapstick down into the filter
Shouldn't hurt anything... but if it gets dislodged and makes its way into the blower.. will make a racket.. If you can see it.. you should be able to extract it with a vacuum cleaner hose of coat hanger with the end wrapped in tape ( tape put on sticky side out)... Otherwise.. I wouldn't worry about it...
Hope that helps.. and you may want to purchase another chapstick for your needs...
Aug 14, 2008 | Dryers
Kenmore gas dryer series 80 not heating up--dryer revolves but no heat--guessing it's the ignitor--can't access-no lower panel to open tomroske@msn.com
small plug left side bottom remove it this will allow you to see if ignitor is coming on if it is suspect the coils on gas valve or no gas to dryer if no glow possible bad thermal fuse remove back small white object on blower housing ..if no lower panel ..remove 2 screws under filter pop top 2 clips 1 each side about 2-3 inches from end..2 screws 5/16 1 each side upper corners remove lift front off
Jun 27, 2008 | Dryers
Crosley CDG6000 Gas Dryer Logo
122 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
