Question about Acer Aspire 5600 Series 5630-6951 Laptop
Problem on start up of an acer 5630
When I try to start up I get a 'smart failure predicted on hard disk 0, back up your files and replace the hdd'. Fair enough if I need a new hdd but it won't let windows start for me to access my files, just keeps going to disk check and then freezing. Even trying to start in safe,normal or last known good configuration modes same thing happens. Any ideas , much obliged.
  • HooperAL Feb 09, 2009
    Thanks for your help, Leeds are brutal !!!
  • Acer Master
  • 4,806 Answers
Hi there
The drive is corrupt so you will need to plug it to another computer as a slave drive if you need the data from the drive, once you are satisfied you have all of your data you can then buy a new drive and proceed with a clean install of windows
Good luck and thanks for using Fixya!!
Posted on Feb 09, 2009
Smart failure predicted on hard disk repair
This means either your hard disk is about to fail or it already has in which case you will need to purchase a new HDD (hard disk drive) and then contact acer to purchase recovery disks or if it is still under warranty then contact for service.
Jul 19, 2014 | Acer Computers & Internet
I plugged in a 120gb internal toshiba mk1234gax hdd2d16 hard drive and when turn laptop on it says SMART failure predicted on hard disk. how should i go about fixing this
Try turning off SMART in MotherBoard Settings (BIOS Settings) and if it won't work, Call a Computer Professional. If Warranty is alive, Call Authorized Service Center.
Mar 29, 2014 | Toshiba MK1234GAX 120GB 5400 RPM 8MB Cache...
Failure predicted on hard drive disk 0
A predict failure is just that. There is a good chance it fail. Make a backup and replace. You can also turn the SMART monitoring off in BIOS if you don't want the warning.
Dec 24, 2012 | Acer ASPIRE 5610Z2273 COMPATIBLE LAPTOP...
When I try to start my Acer Aspire 3050 notebook I get "SMART Failure Predicted in Hard Disk 0: SAMSUNG HM160JC-(PM) WARNING: Immediately back up your data and replace youre hard disk. A...
The hard drive has already failed, there are probably some bad sectors on the hardware so windows has corrupted files and can not back up. If you have the recovery disc, try and reload the operational system, it will quickly prove if the hardware is the issue. But! before you go out and buy a new hard drive have them test the old one first.
Feb 09, 2011 | Acer Aspire 3050-1733 Notebook
Acer Aspire 5570 getting SMART failure error on HDD
Definitely a hard drive problem, you'll need to replace the drive and reinstall all the software.
Apr 04, 2010 | Acer TravelMate 507T Notebook
Acer Aspire 5100: SMART Failure on Hard Disk 4
Hello there,
As per experience, SMART Utility will check your HDD for any errors that may occur.
I backed up everything and replaced a new HDD and got rid of the error.
Opened up the problematic HDD and noticed a very light scratch on its "platters".
As for me. Never ignore this warning before something might happen to your HDD and lost important data.
Mar 08, 2010 | Acer Aspire 5100 Notebook
SMART failure predicted on hard disk 0:
There is a big problem with newer conponents and Win XP versions prior to SP2. Especially with newer motherboards.
You have to make a bootable SP2 disk if you don't already have one. To do this use the slipstream proceedure specified on the Ms website. Many other websites describe the process with easier language.
Slipstreaming is a common practice now. Essentially, you copy your original install disk to the c: drive then download SP2 to C: drive then download the slipstream utility from MS. Running the slipstream utility then inserts the proper drivers (ide and HD drivers too) into the licensed copy you have. You then create a bootable disk from the slipstreamed files you have.
This approach is resolving alot of blue STOP errors and SMART errors.
ALSO, you want to make sure you are installing any drivers provided by the MB manufacturer AND Drive maker.
Good Luck
Jul 29, 2009 | Computers & Internet
Hard disk problem
Smart is a BIOS based harddrive testing utility, it is warning you that the harddrive is about to fail.
You should back up all your personal files as soon as possible and buy a new harddrive.
Jul 26, 2008 | Computers & Internet
When you turn the computer on it says SMART Failer predicted on hard disk 0: HTS54108G9SA00-(S1)
S.M.A.R.T. (Self-Monitoring Analysis and Reporting Technology) is a diagnostic method originally developed by IBM that at that time referred to as "Predictive Failure Analysis". This technology was developed for IBM mainframe drives to give advanced warning of drive failures. Based on this diagnostic, Compaq announced IntelliSafeTM, which was submitted to the ATA/IDE standards committees and the resulting standard was named S.M.A.R.T.
S.M.A.R.T. analyzes many of the mechanical attributes; over time, some failures can be predicted by detecting if the hard disk drive is moving out of tolerance. While the S.M.A.R.T. technology can detect upcoming issues, not all hard drive failures are predictable.
All this means on most modern drives is the hard drive is coming close to the maximum tolerances
I usually switch off in the bios smart monitoring.
This system is trying to predict a possible failure, which may or may not occur..
Mar 30, 2008 | Computers & Internet
Acer Aspire 5600 Series 5630-6951 Laptop Logo
139 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
