Question about ASUS P4P800SE Motherboard
I am trying to find out if my motherboard will support 64 bit OS
ASUS P4P800SE
  • 2 more comments
  • James Rucker Feb 09, 2009
    I was given the motherboard from a friend because he could not utalize it and I have got it up and running I am on it now. I have a 64 bit Vista OS I would like to install but I dont have much info on this board, I also have 4 gigs of ram and a gforce 6600 video card amd the cpu is an intel P4.
    Thank You! I will load the OS and give it a shot I am greatful for your assitance
  • ROD GANDY May 11, 2010
    NEED MORE INFORMATION PLEASE
  • Al Klein
    Al Klein May 11, 2010
    Will what?
  • 1,602 Answers
  • ASUS Master
  • 4,806 Answers
Hi there
have a look here to find out which intel processors the board supports.
http://www.cpu-upgrade.com/mb-ASUS/P4P800_SE.html
Thanks for using Fixya!!!
Posted on Feb 09, 2009
  • Lee Hodgson
    Lee Hodgson Feb 09, 2009
    Hi again
    You will need a 64 bit OS to get the full use of the 4BG ram, 32 bit OS's only recognize 3.9 GB ram so an 64 bit OS will be an advantage.
    As far as i know the board supports 64bit and core due processors
    Good luck
Can't detect XP discs in win 64 bit
Hello Joe, 64-bit processing is faster than 32-bit processing because the CPU is handling more bits at once, However, a 64-bit OS requires more resource than a 32-bit OS, A 64-bit OS requires that device drivers operating in kernel mode be a 64-bit drivers, These drivers must be available from the device manufacturer. An application is compiled to process 64-bit or 32-bits. A 64-bit OS can run either 64-bit applications or 32-bit applications, but 64-bit applications are faster also 64-bit applications cannot run on a 32-bit OS.
A 32-bit OS can only address up to 4 GB of memory, More than that might be on the motherboard, but the OS cannot use it, because it does not have enough memory addresses to assign to the physical memory. A 64-bit OS theoretically can address up to 1 terabyte of memory although in practice, most motherboards can only hold from 12 to 16 GB of memory.( A terabyte is roughly 1000 GB or 1 trillion bytes). If you open many applications at the same time and have high computing needs and enough hard drive space and memory, you can benefit from 64-bit computing. To get most out of it, the processor, motherboard, operating system, drivers and applications must all be 64-bit, and you should have installed the maximum amount of memory the motherboard supports.
Mar 16, 2013 | ASUS G74s Cd-rw Dvdrw Super Multi Drive...
4GBram Install But disply 2.75 GB
Sometimes it is possible that the full memory will not be seen unless the properties are opened to check. Please also check if the installed memory was of the right memory capacity.
Nov 26, 2011 | ASUS M2N68AM Plus Motherboard
LA P4P8OOSE FUNZIONA A 64 BIT
Could you describe the problem?
Jan 22, 2011 | ASUS P4P800SE Motherboard
What kind of cpu do i need ? i have asus p5nd2-sli motherboard with no cpu in it
Compatible Processors Pentium 4, Celeron D, Pentium Extreme Edition, Pentium D 64-bit Processors Compatibility Yes Processor Socket LGA775 Socket
Seems that you need Socket LGA775,and CPU: Pentium 4, CeleronD, Pentium D, Pentium Extreme Edition. For more Details go here:
http://www.google.com/products/catalog?hl=en&q=p5nd2-sli+motherboard&cid=13414569805758042878&os=tech-specs
Nov 16, 2010 | ASUS P5ND2-SLI Deluxe Motherboard
How do i change from 32 bit to 64 bit on a asus p5q se2 motherboard
The only way to Upgrade from 32 bit to 64 bit is to buy a 64 bit MOBO and replace it with the 32 bit MOBO.
Oct 05, 2010 | ASUS P4P800SE Motherboard
I need sound driver for my p4p800se mobo ty n advance melts92@gmail.com
Please download these drivers from
http://support.asus.com/download/download.aspx?model=P4P800%20SE&SLanguage=en-us
Regards
Ashly
Feb 02, 2010 | ASUS P4P800SE Motherboard
I have an asus dsbf-d server motherboard installed with two Intel Xeon E5410 Harpertown 2.33GHz processors and 16G ram. I have four 1 TB WD hard drives I want to set in raid 10. I want to install xp 64 bit...
http://support.asus.com/download/download.aspx?modelname=DSBF-D&SLanguage=en-us
Select Windows XP 64 from drop down box. Check for files under SATA (click the plus sign). Have you already tried the LSI MegaRAID?
Nov 25, 2009 | ASUS DSBF-D/SAS Motherboard
File P4P800SE.ROM not found
Sounds like you're trying to flash the bios..
Using ASUS EZ Flash to update the BIOS: The ASUS EZ Flash feature allows you to easily update the BIOS without having to go through the long process of booting from a diskette and using a DOS-based utility. The EZ Flash is built-in the BIOS firmware so it is accessible by simply pressing <Alt + F2> during the Power-On Self Tests (POST). To update the BIOS using ASUS EZ Flash: 1. Visit the ASUS website (www.asus.com) to download the latest BIOS file for your motherboard and rename the downloaded file as P4P800SE.ROM. Save the BIOS file to a floppy disk. 2. Reboot the system. 3. To launch EZ Flash, press <Alt+F2> during POST
Hope this helps
Chris (ziraffa)
Dec 31, 2008 | ASUS P4P800SE Motherboard
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
Dec 24, 2008 | Computers & Internet
ASUS P4P800SE Motherboard Logo
175 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
