When i boot the pc it tell me that theres no doot device i press f1 to continue no boot device i then press f2 for set up and thers is no dvd-cd rom installed or hard drive and they both are there i then reseat them and the samething happens.
CMOS BATTERY MY BE THE PROBLEM.
GO INTO BOID GO TO HARD DRIVE SETTING SELECT NEW HARD DRIVE SEE IF IT WILL REGISTER OR COME UP.
REBOOT SYSTEM.
OR
WHEN THE SYSEM FIRST COMES ON YOU WILL SEE SOME INSTRUCTION FLASH UP ON THE SCREEN PAUSE THE IMAGES OR INFORMATION TO SEE WHAT "F" KEY TO PUSH LIKE F10 FOR A FEW SECOND OR UNTIL YOU HEAR A BEEP NOISE
LET THE COMPUTER FINISH WHAT IT IS DOING AND FOLLOW INSTRUCTION INFORMATION ON HOW TO DO THINGS ARE LIST ON THE BUTTOM OF THE SCREEN AND HOW TO SAVE IT WHEN YOU ARE DONE IT IS USUALLY F10 AND Y FOR YES THAN REBOOT SYSTEM.
ROD
Either the data cable is disconnected from the motherboard (reconnect it), the disk controller on the motherboard is bad (you can buy a disk controller card, or replace the
motherboard) or, least likely, both drives went bad at the same time.
