Pioneer PDP-5071PU TV turns itself off an freezes
Ever since I have owned my Pioneer PDP TV it has turned itself off then the on/off swith flashes blue.
It also freezes up where the channel display on the TV will not autohide. If I turn the TV off and back on the TV displays ''warming up'' but it does not aways come on for a long time.
I have had it in the shop several times (Pioneer paid) but they never get the problem fixed. Anyone else had this problem and found a solution.
I think it overheats by the symptoms.
Thanks
Mike
5 Suggested Answers
info33
  • 72 Answers
SOURCE: Pioneer PDP-42A3HD - TV turns itself off...is
Here is the link for the manual - c ould be a remote set up issue or this could be puffed caps in the power supply - have a qualified tech check that out
http://tv.manualsonline.com/search.html?q=PDP-42A3HD&submit.x=49&submit.y=15
Posted on Jul 03, 2010
joeymille916
  • 143 Answers
SOURCE: Hi everyone! I have a pioneer
The Y Lower buffer is the most likely culprit. I would first try to firmly tap on the TV... about 3" below the center line on the right side front (not on the screen but right next to the screen). The Y Lower connector is there and it could be just loose. I have a Philips 50" plasma that the lower half went out and a gentle tap fixed it once. I took it apart and tightened the connectors by loosening the screws and pushing the Y Lower buffer toward the Y Main board while tightening the screws back. No problem with it since. But sometimes the buffers go bad on these units and need to be replaced. Some people replace the upper and lower at the same time while others say just replace the bad one.
Good luck and let me know what you find!
Posted on Oct 13, 2010
gopakumarg43
  • 74473 Answers
SOURCE: Problem with Pioneer PDP-6010FD
Hello
The set can be set right by repair. You must have through knoledge in electronics to do work with set. especially, plasma displays will have very complicated circuits. It Sustain-Boards suld be trouble shooted.
Posted on Feb 22, 2012
SD Tech
  • 14553 Answers
SOURCE: My pioneer pdp-5080hd plasma tv is turning off on its own for no reason. Both blue and red lights just turn off. No flashing. It comes back on afte a few minutes and there is a gray box that says
If not happening on a predictable basis it will be hard to find--some general information:
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
Posted on Apr 30, 2012
How do i connect head phones to pioneer pdp 5071pu TV
This model has no headphone out put. In the rear panel there are two monitor audio outputs which could drive headphones, but I think the volume output to a possible monitor matches the tv loudspeaker output, and may not turn off the audio separately.
Mar 09, 2014 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Pioneer PDP-5071PU red and blue light on no pic at all
According to you it is a memory card reader, they shouldn't have a picture on them.
Sep 24, 2013 | Pioneer ANP2167-A Memory Card Reader for...
Pioneer pdp 5071pu
You can get some information about your problem from service manual:
http://www.nodevice.com/manual/newmans/lcdtv/pdp-5070pupdf/get74015.html
Sep 24, 2013 | Televison & Video
Pioneer pdp 5071pu
It sounds that it is time to do a firmware update. If you wish to get more details, http://electronicshelponline.blogspot.com/ Check this link. Firmware update procedure to many brand TVs are given in detail with illustrations. Pull up older posts. If you want more assistance, be free to come by comments.
May 29, 2013 | Televison & Video
Jul 03, 2010 | Pioneer PDP-42A3HD 42 in. Plasma...
Plasma tv stopped working
hi i have a pioneer plasma tv pdpro4e all it doses is flash green red green red and on the mediar reciver as well tv dont come on help please
Dec 31, 2009 | Televison & Video
Loud pop and tv went off...
Here is a solution from the Pioneer web site:
http://www.pioneerelectronics.com/PUSA/Support/Important%3A+Updated+Information+Regarding+Free+Power+Supply+Replacement+for+Certain+Pioneer+Plasmas
Important: Updated Information Regarding Free Power Supply Replacement for Certain Pioneer Plasmas Pioneer is continuing to offer a free, in-home/office power supply replacement for certain of its second and third generation plasma models listed below for customers who experience a problem with the original power supply. If a model is not listed below, no power supply replacement is needed and no further action needs to be taken.
If you own or use a plasma listed below, please call our toll free hotline at 1-800-421-1404 to arrange a time to have your plasma's power supply upgraded at your residence or office at no charge.
Plasma Models (15 listed):
  • PDP-505HD
  • PDP-503PU
  • PDP-5030HD
  • PDP-5031HD
  • PDP-433PU
  • PDP-4300
  • PDP-4310
  • PDP-4330HD
  • PRO-800HD
  • PRO-800HDI
  • PRO-1000HD
  • PRO-1000HDI
  • PDP-433CMX
  • PDP-502MX
  • PDP-503CMX
The issue with the power supply in the plasmas listed above does not pose any health or safety risk. Pioneer has received reports that the power supply in the affected models may fail. In some cases, a loud popping sound can be heard when a power supply fails. After the power supply fails, the plasma is no longer operable.
Anyone with questions can call Pioneer's toll free hotline at 800-421-1404.
We apologize for any inconvenience.
Aug 09, 2008 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Pioneer PDP 436XDE
hi there, you have to send if for repair, tech people knows the prob., there a defective part to replaced. do some test and check up at the horizontal and power supply section. ty
Feb 18, 2008 | Pioneer PureVision PDP-4300 43 in. Plasma...
Televison & Video Logo
161 people viewed this question
Top Televison & Video Experts
Electro Med Services...
